Old 04-29-2020, 10:31 PM #1
CWccw CWccw is offline
CWccw is on a distinguished road
Why would I need a full size starting battery?
I want to do the dual battery tray set up but Im having a problem deciding on what battery to get. I want to do an ultracap bank with a SLA battery hybrid with a small flexi solarpanel on the hood for the starting battery. Any reason Id need a bigger full size battery? My thinking is reduce the size of the starting battery and in turn get a much bigger secondary battery.
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 11:52 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Sounds reasonable. Probably only need 400-450 CCAs under 'normal' ambient temps. How much would that battery have?
Old 04-30-2020, 12:49 AM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Are you splitting off the cabin air fans and headlights so they don’t pull from the starting battery?
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 01:10 AM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I tried to check compression on a 5VZ-FE out of the engine bay (so no tranmission) with a battery with 375 CCA. It could not turn over the engine in 90 degree weather. I'd shoot for at least 500.
Have you thought about just using a deep cycle battery like the Optima Yellow Tops? I have one now and absolutely love it, I just use it for my stereo for when the car is off. Starts strong even after discharging. Just be sure to also own an AGM battery charger for when you get home or else it'll slowly lose capacity.
326WHP 347TQ
Old 04-30-2020, 07:57 AM #5
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
I know what you are chasing. I have a stock size starting battery and a trolling motor for my secondary battery. I get ~20 hours of fridge life with a large Dometic fridge and other accessories off and on. The trolling motor was an easy setup and is charged through a controller so when the motor is on the trolling motor gets charged.
Risking getting stuck in the back country with a battery that cannot start the rig is a real issue if you go too small. I would run the trolling motor secondary. They are purpose built for deep cycle and lots of amp hours.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 09:00 AM #6
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
In the process of doing the same thing. Installed a simple solenoid, triggered by a key on power source. That will feed juice to a fuse block in the back. I'll also attach a deep cycle battery to that to supply power to overnight loads, i.e. a fridge, minor device charging, disco ball for the campfire party, etc.
Not looking to shift any existing "car" loads over so the stock size battery for starting etc will be kept.
Make sure to fuse any runs from either battery.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 09:42 AM #7
The supercapacitor bank parallel with the small battery is what provides the cranking amps. I started and drove mine around on just the bank for a few days on a full load for a test. It passed wonderfully. Also ran it all on just the bank to see how long it would drain, did a constant crank test w/o starting, and it cranked for like 15 seconds, or longer, its been a while since ive done anything with my yota. Because I used a balance board, which was pointless on a 16v cap bank that doesnt charge past 13.8v, the bank would drain off way too quickly when the truck was sitting.
Once I remove that board the only drain will be from whatever in the yota when its off.
Old 05-02-2020, 08:30 PM #8
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
I also have a Dometic fridge, recently purchased. If you have details on your trolling motor set-up posted somewhere, can you direct me please? If in your build/fix thread, I'll read through it. Thanks.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 05-03-2020, 12:02 AM #9
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
But what if an EMP happens?
Old 05-03-2020, 07:54 PM #10
tx_shooter's Avatar
tx_shooter's Avatar
Yes, my build thread has the basics. I will try to get some pics of my setup and specs to send over.
Old 05-03-2020, 07:55 PM #11
tx_shooter's Avatar
tx_shooter's Avatar
Then we all have bigger problems.
Old 05-03-2020, 08:38 PM #12
TonyB66's Avatar
TonyB66's Avatar
Left-off on page 10, and will resume soon. Thanks much!
Old 05-04-2020, 01:45 AM #13
Then the super caps explode!!!
Old 05-04-2020, 01:09 PM #14
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Not the same situation, at all, but I've been using teeny tiny batteries on a couple of my other cars.
An Odyssey PC680 on my 1963 Volvo. The battery is about 7X7X3, weighs about 15 lbs. Alike any AGM battery, it could be installed in any position. No issues at all with how it works, engine cranks normally, and while the old car doesn't use as much electricity as a newer one would, no issues at all.
And on my goofy 1993 Volvo - I have a Braille 14115. About 6X6X3.5, weighs about 11 1/2 lbs. This car has an LS engine swap - the Braille has no problem cranking that over.
The Braille just costs a bit more than the Odyssey.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 03:27 PM #15
TonyB66's Avatar
TonyB66's Avatar
John, a nice reminder as I have have an SLA in MINI Cooper S, and it sounds like the same one as in your Volvo at 11.5 lbs and those dimensions. I'm quite sure I can fab a platform and mount for such in the driver side rear behind that panel, here removed...
Find a way to dual charge it via engine and solar and I'd be all set... Since that battery should be dead, I'm going to remove it from the MINI and use it for mock-up purposes. Thanks for chiming-in....
battery , bigger , full , size , starting
Starting Problem, Battery Good! Pauly67 3rd gen T4Rs 12 06-21-2020 03:09 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Starting/Battery Cable Issues walkerwl Maintenance/Detailing 1 11-11-2014 03:16 PM
Wiring battery in "aux" position to be starting battery... joneseyyy 5th gen T4Rs 6 06-09-2013 11:10 PM
Video of starting/battery problem???? hdoggie24 3rd gen T4Rs 2 09-20-2011 01:19 AM
