Old 04-30-2020, 05:15 PM #1
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
Gas light on
Hey I was wondering how many miles you can drive when the gas light comes on? While driving on back country roads. So not a lot of stop and go driving. I own a 01 3.4
TheShowtime is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 05:54 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Well that number will vary due to lots of factors. Mine goes about 250 but some closer to 300 and others down by 200....
Old 04-30-2020, 06:43 PM #3
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
Also depends if your runner had the gas gauge replaced as it may have been part of the recall. I did not own mine during the recall and it was not taken in. I can get 250 before the light comes on but I think the furthest I've gone over that is maybe 50. But when I fill the tank I find that I still had 2 or 3 gallons left.
Sent from my SM-N975U using Tapatalk
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 07:00 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mostly all Toyotas have between 2 to 3 gallons of gas in the tank when the gas light comes on.
Old 04-30-2020, 08:00 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I have a 98, and my light comes on around 225 ish miles at 15-16 combined MPG's. I normally have 4+ gallons left in the tank. We have 18.5g capacity, so if you know your MPG's and reset the trip odometer each time you fill up you can figure out how far your range is. Just simple math at that point.
I can push 300 miles on one tank, but I am only confident enough to do that when it's all highway driving. I can get up to 20 MPG's highway so that means it's roughly a 360 mile range if I were to run it dry.
326WHP 347TQ
Old 05-01-2020, 05:53 PM #6
So it’s safe to say you’ll get about 50 miles after the gas light comes on. Thanks for the help guys!
Old 05-01-2020, 07:30 PM #7
CWccw CWccw is offline
CWccw is on a distinguished road
Yours comes on? Lucky
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 09:05 PM #8
I don’t like running the fuel to the light. It exposes the fuel pump and to me it can cause pump failure from heat.
Old 05-01-2020, 09:31 PM #9
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Yea you will need to fill up and reset your trip odometer and then drive it until it comes on. Do it when you are on your normal driving routine because different driving conditions can have different results. This way you can get an understanding of your avg mpg for your vehicle. Don't be surprised if it changes drastically if you drive under windy conditions or up lots of mtn roads.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 09:32 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I wouldn't run it down to the light alot as you can overheat the pump. Down to a 1/4 is enough.
If your rig gets 15 mpg you only have 30 to 45miles of gas. Your light comes on immediately fill your tank.
Old 05-01-2020, 11:25 PM #11
Sometimes it’s that way because I live out in the country. Not a lot of gas stations around me sadly.
Old 05-04-2020, 11:39 AM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So do I. However, you can mostly run by a station around 1/2 or 1/4 tank. Its up to the owner though. Changing the fuel pump is not a fun job and if in the rust belt, can be very costly.. :-( I have pulled 2 3rd gen Tanks thus far.
Old 05-04-2020, 01:21 PM #13
The gas flowing through the inside of the pump cools it off, not so much the fuel on the outside - No need to worry too much about it as long as you don't run it dry.
Filling up around 1/4 tank is good for other reasons though - like always being prepared to drive a reasonable distance without needing to get gas first (say, for an emergency).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-04-2020, 02:17 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It's never recommend on any vehicle out there to constantly run it down to the gas light. Granted there is some fuel there to cool the pump down. I just dont advise doing this to a 20 plus old fuel pump. However, it's a up the the rigs owner. I just dont like pressing my luck..;)
Old 05-04-2020, 02:40 PM #15
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
There were a couple of times while driving my 3rd Gen on CA Rt 5, with long straight boring miles, when I spaced out and didn’t plan my fill ups. The fuel light comes on and I didn’t know how far the next gas station was. Keeping speed down and anxiety high I drove about 50 miles to the next station. Not a comfortable situation but after the fillup I figured I still had almost two gallons left in the tank.
driving , gas , light , lot , roads
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
Airbag light, ABS light, Slip light, O MY!?! adio3x 5th gen T4Rs 3 09-16-2016 12:25 AM
