Old 05-01-2020, 10:19 PM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
Auto window up feature
Today I converted my manual (crank) windows to power windows in my '99. When I use the 'auto down' feature the window goes all the way down. When I use 'auto up' the window goes all the way up, and then back down to halfway open. Has anyone ever had a problem like this? Any ideas for a fix?
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 11:31 PM #2
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Pretty sure you motor or gear isn’t clocked properly.
Got to be a thread on here for it. But what term to search???
That up, then half down is the auto window safety feature. It will do that if you put your hand in the window and stop iit. It’s hitting resistance before it thinks it’s all the way up.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 11:51 AM #3
4Reak Show's Avatar
4Reak Show's Avatar
Most toyotas need to learn max "up" position. Run window up all the way and continue to hold up for 3-5 seconds then release and recheck.
Old 05-02-2020, 02:57 PM #4
5VZ-FE's Avatar
5VZ-FE's Avatar
Unfortunately that didn’t work for me
Old 05-03-2020, 01:42 AM #5
I’ve seen folks mention that move on forums for years, but yet to see some report that it worked.
No idea if this applies to a 3rd gen 4runner. But I believe you need to be looking for a procedure similar to this.
Kind of surprised someone hasn’t chimed in that knows.
toyota - Adjust window end position? - Motor Vehicle Maintenance & Repair Stack Exchange
auto , feature , power , window , windows
Auto window roll down feature stopped working snorto Problems & Warranty Issues 68 09-21-2023 11:03 AM
Turn off the auto-lock feature? Robb235 3rd gen T4Rs 20 04-18-2018 07:43 PM
Installed new HU, now driver's side window auto down feature doesn't work... YotaDriver Engines / Suspension / Wheels / Tires / Audio / Accessories 8 06-18-2011 12:38 PM
window Auto up/down feature kimboy 4th Gen T4Rs 4 05-12-2005 12:38 AM
