Old 01-17-2020, 01:06 AM #1
3RDGENGuy's Avatar
3RDGENGuy 3RDGENGuy is offline
Real Name: Matt
3RDGENGuy is on a distinguished road
3RDGENGuy's Avatar
Real Name: Matt
A few questions
So my truck likes to pull to the right when braking hard on un even terrain. I was told the calipers were bad based on assumption and research. I replaced the rotors pads and got OEM used calipers. Well it still pulls to the right when braking hard. Did I just buy another bad caliper ? Haha. I noticed the inner cv axle boot is torn. I don’t know if that has anything to do with it. I also have another question about the horn and cruise control. I replaced the clockspring thinking that was the culprit. The horn worked for a little bit and than stopped working and blew a fuse. The PO installed reed horns so my guess is a bad ground?? I’m stumped
280k 4x4
3RDGENGuy is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 09:23 AM #2
BetterontheMtn BetterontheMtn is offline
BetterontheMtn is on a distinguished road
What is the condition of the rubber hose and metal lines?
My tundra pulls under braking even after new calipers etc, I have a known kinked hard line though that was supposed to be replaced but is going to require lots of soaking and time I didn't have at the moment.
BetterontheMtn is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 10:28 AM #3
Tommy854runner Tommy854runner is offline
Tommy854runner is on a distinguished road
2nd vote for brake hose issue. Had the same problem on a 1st gen 4runner.
Tommy854runner is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 10:58 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Bleed brakes
If it brakes OK under light to medium stops yet not on hard stops, I'd suspect some air in the system, try bleeding all lines before anything else.
Luck and enjoy the Runner.
Old 01-17-2020, 11:47 AM #5
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You mentioned nothing about the rear brakes. Uneven braking in the rear can make your rig pull. Jack up the rear end of your rig, pull off the left rear tire and then remove the drum. If a rig pulls to the right and the rear brakes are the cause, it will be a problem with the left rear not grabbing as effectively as the right rear. The reason why I know this is it happened to me. It's how I figured out I had a leaking rear axle seal. My brake shoes were coated and gear oil and not grabbing well.
mtbtim is online now   Reply With QuoteReply With Quote
Old 01-17-2020, 12:43 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Worn lower control arm bushings can also cause a pull during braking. Have someone brake hard from about 5 mph while you watch each front tire from outside the vehicle to see if it changes in relation to the body.
Old 03-09-2020, 01:04 PM #7
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Thanks guys for all the great info! Forgot to respond !
Old 03-09-2020, 05:44 PM #8
Toy2play Toy2play is offline
Toy2play will become famous soon enough
Did you ever figure out what it was?
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 07:04 PM #9
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
No I haven’t had the best weather but was gonna tackle the brake hoses first than check the rear.
Old 04-07-2020, 10:45 PM #10
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Front Brake hoses didn’t fix it. Bled them 3 times. Gonna take it to a Toyota specialist
Old 04-08-2020, 08:00 AM #11
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Before you do that pull the rear drums and at least make sure they are adjusted properly, often the self adjusting system doesn’t work or will only work on one side and can cause uneven rear breaking. That will also give you a chance to check for evidence of gear oil in the rear brakes like Tim suggested
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 08:54 AM #12
igetfortunota igetfortunota is offline
igetfortunota is on a distinguished road
With this kind of mileage you should absolutely inspect the lower control arm bushings. Depending on the last time they were replaced(dealer probably only does the whole arm to a pretty penny) these things are probably pretty worn. Worth inspecting all load bearing bushings, these are a cheap fix if youre doing your own work.
This assuming all your standard steering components are otherwise in good shape
igetfortunota is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 05:43 PM #13
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
A few questions
Hey guys. So I rotated the tires and cleaned the rear brakes. No signs of gear oil on the pads I didn’t adjust them because my e brake clicks about 7-8 times didn’t think it was ideal. The drums look fine no gouges. I am braking downhill and I get a severe vibration in the back. Happens at highway speeds when slowing down. It happened before all this btw. Any help would be great!
Thanks have a good weekend!
Old 05-01-2020, 06:25 PM #14
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Also does a front bent sway bar front end link affect anything? I noticed the right front one is bent
Old 05-01-2020, 07:26 PM #15
HiLife HiLife is offline
Do you get the same vibration slowing down just with the ebrake? It can't be the rear brakes if you don't get the same vibration slowing down.
bad , calipers , hard , horn , replaced
2001 4runner tranny questions possible swap questions. Did search samario1984 3rd gen T4Rs 5 06-09-2017 01:27 PM
Sub questions Funner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-04-2011 01:54 PM
some 3.0l questions sgtarky Classic T4Rs 4 12-22-2005 03:30 PM
New and have a few questions Jay 3rd gen T4Rs 5 09-20-2005 09:46 AM
Garmin iQue voice nav questions and Topo maps questions. Expat Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-11-2005 09:49 PM
