Old 05-05-2020, 03:53 AM #1
szulbor szulbor is offline
szulbor is on a distinguished road
rear long travel issue
Hello Guys
can you advise me what I did wrong.
I have installed long travel on the rear but it seems that when I installed king shocks and I've extend bumbstop in fact i have reduce the wheel travel not extend.
thank you in advance for any suggestions.
szulbor is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 09:50 AM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Chromoly Adjustable Rear Links | TOYOTA 4RUNNER 1996-2002 | TOTAL CHAOS FABRICATION
That link setup from TC isnt referred to as a long travel setup, just stronger and adjustable to correct for lift angles.
In the pictures you posted, it looks like the rear shocks are too long. What length stroke are they?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 10:14 AM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Don’t know the shocks specs, but.
Aside from brake lines, locker harness, ect... travel is from the bump stop at the top, to the full length of the shock at the bottom.
If you put on longer shocks and longer bump stops you should have increased down travel and reduced up travel. You would then need taller rear coils to move the axle down to a position more central in the travel range.
Or like mentioned above, your shocks are too long for your current coil setup.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 11:01 AM #4
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
You would have less travel if you still have stock coils/no rear lift.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 11:24 AM #5
Big-B1975 Big-B1975 is offline
Big-B1975 is on a distinguished road
Cool looking Runner! Did you swap out the original rear springs? because if you just bolted on lower control arms and king shocks with original springs that’s not going to give you more travel.
Big-B1975 is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 11:34 AM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I don't own a 3rd gen, so take this for what it's worth, but I agree with the above. Your shock might be too long and has no "up" travel, there by reducing your overall wheel travel. It looks like your not even going to get into your bump but about a 1/2" before your shock fully compresses. Your ride height looks pretty good, so maybe your springs are where you need them, but also like mentioned above, if you didn't upgrade your springs, all that shock travel won't do you any good. It also looks like your lower link will contact the reservoir on full compression of the shock. I would say any 4 link set up like this needs almost as much "up" travel as "down".
Here is a link to my custom length 4th gen I built with some shared knowledge from some of the Cali members. It cycles pretty well but it still needs more "up" travel, the back end still gets a little bucky which ain't fun at 40 to 60 mph. https://www.youtube.com/watch?v=OoJUF02t4bo&feature=youtu.be&t=60
Hopefully someone with more than my limited knowledge will post up and help you out.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 12:10 PM #7
We definitely need a full accounting of what parts you have on there... Also, looks like a 1" body lift too?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-05-2020, 01:03 PM #8
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
Originally Posted by szulbor View Post
Hello Guys
What front fenders are those??
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 02:40 PM #9
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is online now
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
96-01 Toyota 4 Runner 4" Flare Off Road Fiberglass Fenders
– McNeil Racing Inc
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is online now   Reply With QuoteReply With Quote
Old 05-05-2020, 03:14 PM #10
So regarding to my build tread:
I have full longtravel front and rear with TC and King, regarding to the spring I have installed toytec superflex +3''
right now I figured the option to add move the shocks socket
Rear 2.0" Shock Mount Kit | TOYOTA TACOMA PRERUNNER / 4WD 1996-2004 | TOTAL CHAOS FABRICATION
but now the issue is how to replace shock caps to allot side mouting, any ideas?
extend , installed , long , rear , travel
Unending Soft Brake/Long Pedal Travel Issue Jhiggs33 3rd gen T4Rs 14 08-23-2019 07:54 AM
Long Travel Rear with KDSS Issue adam2562 5th gen T4Rs 54 07-27-2018 09:49 AM
Rear long Travel twitchee2 3rd gen T4Rs 31 10-06-2016 06:22 PM
Rear Long Travel Tooltime19 4th Gen T4Rs 0 03-21-2016 06:05 AM
