Originally Posted by gebomartin
2002 with 247k that has had regular ATF changes. Only pan drop and fills. Used Amsoil for about 160k and Toyota Dexron III for the last 15k. Every now and then I get a few second delay engagement of the AT when backing up from a cold start. Otherwise, shifting is perfect from that point on. Should I go back to a synthetic ATF like Amsoil or Mobil Synthetic ATF? Of is this just an old age problem. I have never cleaned the filter as I always changed my fluid every 30-40k.
Any suggestions? Should I be worried?
Mine does this, but it doesnt matter if it is cold or warm. Ever since I have owned my truck for the past two almost 3 years it has had a 2 - 4 second delay before actually engaging reverse. PO said it did that while he owned it as well. I just got used to it over time. Change your filter out. Might be a little clogged.
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
