Old 05-07-2020, 01:34 AM #1
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
Instrument cluster lights not working
Hey guys,
Long story short, did the LED upgrade to my interior lights quite some time ago with no issues. Went to turn my lights on the other night and everything turned on except the gauges. The transmission indicator lights still worked on the dash but not on the shifter. The warning lights are also still functional its just the gauges. Checked all the fuses associated and none were blown. Any ideas? Could the dimmer have gone out, and if power is directed through that then thats why those lights don't work?
Thanks guys.
Sent from my SM-N975U using Tapatalk
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 05-07-2020, 08:23 AM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Regarding the dimmer. If you have a voltmeter you could test voltage at your dimmer plug. Also you could test the dimmer disconnected resistance when you turn the dial. If you're getting voltage at the plug, could jump out the dimmer too for a test. Easy enough to grab a used dimmer somewhere.
Overall sounds like your dash lights are a process of elimination, start with easy stuff 1st, which you've done some. Only has to be one tiny thing and they don't work.
If you can get a dash wiring diagram too, would help.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
dimmer , gauges , guys , ideas , lights
Instrument cluster not working, help! wahoossi 4th Gen T4Rs 15 11-29-2022 05:02 PM
Dash, Instrument Cluster Lights MAC4Runner Problems & Warranty Issues 3 05-16-2016 10:07 PM
instrument cluster lights Linford General Discussions 7 02-28-2014 07:50 AM
instrument cluster lights out , not working jkphoto58 4th Gen T4Rs 0 03-17-2011 11:02 PM
Instrument Cluster Lights GAshawn22 4th Gen T4Rs 2 03-14-2008 12:39 PM
