05-07-2020, 12:40 PM
Any good step sliders??
After toying with the idea of taking the factory running boards off I've come to the conclusion it will be pretty hard for the kiddos and the wifey to get in the runner. Especially after I lift it. Does anyone out there make a good "step" slider? I had All Pros on my tundra and my last 4runner but that tube design is slicker than owl poop especially after a good rain.
05-07-2020, 01:18 PM
Real Name: Greg
Real Name: Greg
I've got All Pros on my 4R, and I agree they're too slick. I should have gotten the fill plates too.
My cousin had his sliders coated in bedliner to give it more grip. Seems like a good move, regardless of what direction you go.
05-07-2020, 01:21 PM
I think RSG make a great choice, mine are angled, but they do make flat also.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
05-07-2020, 01:37 PM
Any of the sliders offered for 3rd gens can work as a step, it just won't be as low as the factory running boards. You'd want to have it flat instead of angled up if you wanted it to function more as a step. For grippiness, grip tape would give the most traction. Traction plates are better than nothing but my diamond tread plates are still pretty slick when it's wet. Aside from that, it's a matter of what design you like and if you want a bolt or weld on. You can pretty much weld any slider on but shrockworks is the only company I'm aware of that offers bolt on specifically for 3rd gens. 4crawler has a diy kit that is bolt on.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
05-07-2020, 01:58 PM
Real Name: Blair
Real Name: Blair
"shrockworks is the only company I'm aware of that offers bolt on specifically for 3rd gens."
Anyone have an opinion on these (bolt-on) sliders? I don't own a welding rig anymore.
Edit - actually the Rocky Roads 3rd Gen bolt-ons look good too, and an $80 shipping deal is going on......
05-07-2020, 02:37 PM
Real Name: Eddie
Real Name: Eddie
Another vote for the RSG's. I needed step functionality for my elderly Mom and these work well for that purpose.
Mine are welded on and angled and still work as a step.
Good luck,
Eddie
2001 T4R SR5 - 180k miles and counting.
05-07-2020, 03:42 PM
I also forgot to mention White Knuckle offer bolt on sliders for 3rd gens which has a kickout.
05-07-2020, 05:56 PM
The Shrockworks stuff is good quality... Just keep in mind you will be drilling to install them. (true for whatever bolt on option) I actually welded them on - I liked the fill plate design best. I haven't had the pleasure of actually bashing them on rocks yet, so I'm not the best source of a real review.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
05-07-2020, 08:30 PM
Schrockworks. Do it right the first time.
05-08-2020, 10:23 AM
My buddy welded these onto my 4X sliders. They add some much needed grip and look great IMO.
Painted
5-speed swap stuff available here!
https://www.toyota-4runner.org/for-s...isc-stuff.html
05-08-2020, 10:30 AM
Real Name: Tony (no surprise)
Might want to consider the "new" Savage sliders. Part of the input into the design was family, kids and also dogs.
Rock Sliders with Kick Out, 96-02 4Runner — SAVAGE OFF-ROAD
Probably nothing stronger out there, all US steel too. Expect a lead time though....
2000 Limited, E-locker
Maintenance/Build Thread
05-08-2020, 05:15 PM
Yeah I had mine powder coated and that was a BAD idea, so much slicker. I took skateboard grip tape and that worked pretty good but eventually starts to kind of peel up since it's a rounded surface. I like the look of those RSG's.
05-08-2020, 09:39 PM
I’ve got the savage sliders a post or two up but had Roy add a second set of kick outs so there is a step for front and rear. They look pretty sweet. Cleaned them thoroughly, auto self etching gray primer and then truck bed liner.
