05-07-2020, 03:43 PM
help, antifreeze puddle
so, I came out to see a huge puddle of antifreeze under my truck and it's not coming from the hoses or radiator. it looks like it's coming from behind the bottom pulley. and the radiator is of course empty.
265/75/R16 Bridgestone Dueler
A/T Revo
LED headlights upgrade
interior LED upgrade (red)
05-07-2020, 03:47 PM
Probably the water pump.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
05-07-2020, 03:54 PM
I was afraid of that.
A/T Revo
05-07-2020, 04:48 PM
It's not too hard to remove the top timing belt cover and pry back the bottom one.
That will let you get a better look at the water pump.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
05-07-2020, 05:25 PM
Real Name: Patrick
Real Name: Patrick
Another vote for water pump
05-08-2020, 10:30 AM
Look like a water pump / timing belt job is in your near future. It's really not that bad at all if you want to do it yourself. A complete parts kit is in the $250 range and it can easily be done on a Saturday if you want to save some money.
Depending on where you live, the price to have a shop do it is usually between $700-1000.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
05-08-2020, 10:47 AM
update; I dont have the place or all the tools, unfortunately, to tackle this big of a project, so off to the shop she went. New hoses, drive belts, timing belt, and water pump, to the tune of $1300. oh well, glad I didnt spent all of my Gov't check until now! thank you for the quick responses and help for my problem. this forum has given me a wealth of information and at times saved me a ton of money. y'all are a great bunch of people.
A/T Revo
05-08-2020, 04:34 PM
Real Name: Tim
Real Name: Tim
Too bad you don't have the space to work on your rig. A quality timing belt kit with everything you need, including the camshaft and crankshaft seals that I bet the shop didn't replace for you runs around $270. That means you could have saved around $1,000 buckaroonies doing this job yourself, and you can buy a whole lot of tools for $1k. Oh well, hopefully one day you'll have a garage or outbuilding with lots of space and tools to do your own work.
05-08-2020, 04:39 PM
one day, and im sure I'll reference your videos as I have in the past. you've saved me money more than a few times, thank you!
A/T Revo
05-09-2020, 07:33 AM
Real Name: James
Real Name: James
Bummer on the bill...I did my water pump about a year and a half ago. When I pulled it off, the pump wasn't even bad. It was the gasket. I still put the new pump on, but just goes to show you, an $800 job might've been a $15 job.
Another thing to keep an eye on, is the coolant lines that go to the rear heater. Mine started leaking at a bracket holding them to the frame. The old lines are steel, but the replacement part was either aluminum or stainless. On my '98 4 cyl auto, they ran along the exhaust and up into the body on the passenger side. They see a lot of salt spray, and are easily overlooked when searching for leaks.
98 Base Model 2.7L
05-09-2020, 07:47 AM
I dont have the rear heater, but would those lines still be there? I've never thought about looking for them.
A/T Revo
05-09-2020, 07:52 AM
Real Name: James
Real Name: James
Doubt it, but can't say for sure.
98 Base Model 2.7L
