Old 05-28-2020, 11:06 PM #1
Mikeyt Mikeyt is offline
Mikeyt is on a distinguished road
Need some help hiding an amplifier
I wanted to put this on the audio side but not much traffic there. I've got a 2k1 4runner sr5 with out the JBL system. I'm building the sub box, have done the head unit and internals, now I need a good place to hide the amp. It measures 12"x8"x 2.4" in height for reference. I wanted to put it under the driver side seat and mount it to a piece of ABS plastic then wanted to mount that to the seat frame holes but they are odd in position, not just four hole straight down on the floor and the floor pan isn't really flat under there. So my next place I was thinking was on the driver side in the rear panel behind the second row of seats. Has anyone done this? I know there's plenty of depth just be measuring, but I haven't taken the panel off yet yo see what I've got. I was also thinking about using that little cubby on the passenger side but I actually have stuff in there and use it so that's really out.
Mikeyt is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 12:30 AM #2
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
Mount it under the seat using a plastic cutting board. Board goes under carpet but not drilled into the floor. So, board under carpet and the amp screwed on top. Works great!!
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 04:34 AM #3
That's a great idea, I've never heard anyone mention that! There's a natural slit in the carpet for wires to come up to the electric seat. My assumption is you used that slit to run your wires up through? Second when you mounted it, I'll assume you poked holes in the carpet then ran bolts through with nuts on the bottom side of the cutting board to fasten it together or something like that. Finally I'll also assume you ran the wires in looming or not to the amp. I guess if I wanted to, I could use a bushing of some type between the carpet and the amp to sit it off of there, that way I could run the wires under the amp. Do you have any pics of this, I'd be interested to get a visual.
Old 05-29-2020, 12:07 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I agree with this idea!
There is room on the driver's side rear cargo panel, space forward of the air vent and above the wheel well. However if you ever want to make any adjustments on the amp unit you'll have to tear the entire cargo area apart again. Under the seat makes it much easier and there's a lot of room down there if you don't have rear heat.
326WHP 347TQ
Old 05-29-2020, 08:05 PM #5
Real Name: Bill
Real Name: Bill
Here are a few pics. I don’t have any of the cutting board but just go to the Dollar Store and cut it to size. $1!!!
My 4Runner build:
Old 05-29-2020, 08:53 PM #6
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
I run two amps. The 1500W Mono sits in the passenger side well between the inner and outer sheet metal. It's help in place by a few bolts drilled through the sheet metal. The second amp is a 4 channel that sits under the drivers seat. 0 AWG power runs from the battery to under the drivers seat where a bus bar sends a positive lead to both amps. I can't find any photo's of the amp under the seat but it's big and barely fits.
As far as needing access to the mono block I've never had to. Once it's tuned it's a set it and forget it type of thing. Just make sure your gains are set correctly and put the panel back on. I haven't touched it in 3 years and it still sounds perfect. The sub it powers is actually in the passenger side storage door. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 10:56 PM #7
1984keen's Avatar
1984keen 1984keen is offline
Real Name: Joaquin
1984keen is on a distinguished road
1984keen's Avatar
Real Name: Joaquin
I like that box!
1984keen is offline   Reply With QuoteReply With Quote
floor , panel , place , side , wanted
Hiding spots for spare key? 4Runners 4th Gen T4Rs 25 03-18-2021 04:15 PM
Interior Hiding Spots in 4th Gen? JustSomeName 4th Gen T4Rs 16 07-08-2012 08:59 PM
Coming out of hiding JCAZ 5th gen T4Rs 6 04-03-2010 10:57 PM
Focal FP 5.500 hiding place jeffrosheen Engines / Suspension / Wheels / Tires / Audio / Accessories 5 12-11-2008 06:28 PM
Hiding a key? biskit 4th Gen T4Rs 6 02-25-2008 07:49 PM
