Old 05-08-2020, 10:17 AM #1
brianjasinski2003 brianjasinski2003 is offline
brianjasinski2003 is on a distinguished road
Calling all True North Fabrication plate bumper and winch owners.
Hi all,
Can you tell me what winch you have and if you have any problem accessing the free spool with your winch install. I have heard a few reports that some are not able to access free spool. My plate bumper is coming soon and I would like to know which winch you have installed. I am hoping to put a SmittyBilt X20 10,000lb with wireless remote in there. Thanks for any helps
brianjasinski2003 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 11:49 PM #2
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
I have the very first version of their bumper and I have a Warn m8000 installed, which is the one they recommended.
I’m able to access the free spool fine, but overall I wouldn’t say it’s the most accessible design for a winch bumper. It’s kind of a pain really, getting the wires hooked up was tricky.
Can’t comment on the winch you’re looking at but the m8000 is pretty compact, which is probably why they recommended it
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
Old 05-22-2020, 10:44 PM #3
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
I found a nice lightly used m8000 so I have that and the first design bumper that TNF made. It’s kinda a tight fit to get my hand on there. Not awful I make sure I wear a glove so I don’t scratch up my hand. Since it’s modeled after the m8000 take the measurements from Warn’s website and compare it to model’s you’re looking at and see what’s close
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 01:25 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
well, prob not much help. I just got that smittybuilt (X20, 10k synthetic) but have not mounted it yet as my plans have changed a bit on bumper.
However. if you have not gotten the smittybilt I read through and it is clockable for the motor and the gear case too. Gear case was my main concern so I could rotate and make handle accessible depending on what bumper I get.
Old 09-18-2021, 07:09 PM #5
Nameless Now Nameless Now is offline
Nameless Now is on a distinguished road
For anyone else that is looking at putting a winch on their SRQ bumper hopefulky you find this useful. I have a SRQ/True North Fab open wing hybrid bumper. The internal height is about 8.1 inches. I did alot of research looking for all options that would fit the bumper, Come up, superwinch, smittybilt and a few others. the control box has to be relocated so the constraint on all these winches is the clutch lever. The only winches that I found to fit were from Warn, those being the M8000 and VR EVO 8/10/12. The zeon might fit but I am not 100% sure on that. I bought a VR EVO 10s Gen 3 and it will fit great. The clutch lever has room to rotate even though it will be an awkward reach through the front.
Nameless Now is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 08:43 PM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I too have the open wing hybrid and I'm using a Smittybilt XRC Gen 3 which BARELY fits, but fit it does. I had to clock the engagement lever backwards one "position" but if one was to perhaps use a much smaller lever as opposed to the super bulky one that it comes with I imagine you could get away with keeping it clocked as it comes. Having it backwards isn't bad whatsoever, and I can actually see how it might be easier to reach this way
That being said, I believe the 3rd gen XRC is one of the smallest winches SB makes and it fits with practically ZERO room to spare in any direction; at most I'm talking a centimeter or two on all sides. In my research I read a couple posts+talked to an individual that all claimed to use an X20 (which is slightly larger than my XRC) and they assured it would fit, but I just don't see how that is
Old 09-26-2021, 09:06 PM #7
That is good thinking on clocking the clutch lever backwards. Also great to hear it might be easier to reach in a backwards position. I was looking at getting the Comeup 9.5 and clocking it forward but the lever was going to hit the inside of the bumper.
bumper , free , plate , spool , winch
SRQ / True North Fabrications DIY Front Bumper Kit SRQ-Runner 3rd gen T4Rs 119 06-04-2021 08:44 PM
Review: True North Fabrications Hybrid Bumper Kryptoroxx 3rd gen T4Rs 2 01-07-2019 10:40 AM
Calling all Shrockworks Rear bumper owners!!!! jstim 3rd gen T4Rs 1 10-29-2018 09:30 PM
True North Fabrication Front Bumper Franky4ag 3rd gen T4Rs 9 03-27-2018 10:38 PM
Relentless Fabrication Stingray LoPro Winch Bumper MadeInMaine 5th gen T4Rs 7 10-06-2017 10:13 AM
