Old 09-11-2021, 07:37 AM #1
WrenchTech's Avatar
WrenchTech WrenchTech is offline
Real Name: Matt S.
WrenchTech is on a distinguished road
WrenchTech's Avatar
Real Name: Matt S.
Questions about transfer cases for my manual transmission swap
I am ready to start collecting parts for a manual transmission swap into my 99 runner. I have been told that I can reuse the transfer case which is currently behind my automatic transmission. I haven’t been able to find much information about the transfer case Toyota used for this application. I noticed that car-part.com has separate listings for transfer cases for manual, SR5 auto, and limited auto, all with the V6 engine. What do I need to know to get the right part?
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
WrenchTech is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 08:14 AM #2
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
If the transfer cases are the same and would bolt right up to either a manual or an automatic transmission, then it seems to be a matter of the transfer case shifter. Can I reuse my transfer case and make it compatible with the manual transmission by swapping out the t-case shift lever?
Old 09-13-2021, 02:11 PM #3
The manual shift lever is different as you noticed, and the manual t-case has one or two fewer sensors (needed for auto trans control). That's why the listings would be different. You can use your auto t-case on the manual trans with the right shift lever.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-14-2021, 12:44 PM #4
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Because you have an SR5, I assume you have the standard j-shift transfer case. When swapping to a 5-speed you need to do one of two things to get the shifter to work, either get a shifter from a j-shift manual transmission, or if you want to fabricate something you can use your current shifter, flip it around 180° and cut/shorten/weld the kink.
I did a manual swap in my 1999 Limited which has the multi-mode j-shift transfer case. I swapped the shifter with a 5-speed shifter and relocated the AWD button on that was on the side of the shifter to another location.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 12:27 PM #5
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
I bought a whole package of manual trans swap parts from a seller that I found in the classifieds in this forum. I got the transfer case that came with the five speed manual from the factory. It should have the correct shifter. When I pull my automatic out to install the manual transmission I will be able to compare them.
Old 09-26-2021, 04:04 PM #6
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
When I did my manual swap I reused my auto transfer case and just flipped the shifter, works fine
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 06:24 PM #7
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Thanks for that information. I could have saved a little bit of cash if I didn't get the transferase that came with the manual. I felt better getting the complete set up though.
auto , cases , manual , transfer , transmission
07 transfer case/transmission swap deputydan 4th Gen T4Rs 10 12-06-2020 04:19 PM
Electric to Manual Transfer case swap? Link12 3rd gen T4Rs 5 04-25-2020 01:37 AM
Manual Transmission & Transfer Case Fluid: GL-4 vs GL5? nobb 3rd gen T4Rs 8 04-15-2019 12:33 PM
2001 manual transmission swap questions Project_toothless 3rd gen T4Rs 25 11-21-2015 11:30 PM
Transfer case or manual transmission fluid leak help offroadwill 3rd gen T4Rs 8 11-11-2013 01:35 AM
