10-20-2017, 11:35 PM
TMP's 2002 Build and Wrenching thread
Picked up this well maintained bone stock 2002 SR5 exactly 2 years ago tomorrow and have had a lot fun wrenching on these projects. Looking forward to some more mods, maintenance and exploring CO.
** lots of updates and photos to add......
October 15, 2017
TMP_2002-TR4
October 21, 2015
2002 SR5 4x4 Black, Toytec 3", Toytec diff drop, SPC UCA's, Andymod 2.0, AOR plate bumper, RCI Skids, Satoshi, Superwinch TS9500, Factor55 Fatlink, Gobi Stealth Rack/Ladder, Breather Mod, LED dash upgrade, and sometimes an iKamper.
10-20-2017, 11:45 PM
10-21-2017, 12:08 AM
Added a AVS Deflector...
10-21-2017, 12:16 AM
Andy Mod 2.0
Highly suggested mod for all the 01-02's. I pretty much have it turned off all the time.
Someday I'll make a fancy on/trac/off sticker for the button... or if someone makes a cool switch maybe I'll swap it in there.
10-21-2017, 12:30 AM
10-21-2017, 12:38 AM
November 2016
Bye bye sway bar
Ended up pulling the front swaybar off completely after all this..... and liked the way it handle off road much better.
The link that survived...prolly not for much longer!
10-21-2017, 12:48 AM
November 2016
Broken rear shock and severed ABS cable.
Dash is blowing up!
by
Broken shock bounced around and snipped the ABS sensor cable. I soldered it and cover in heat shrink.
Ready for solder... and then didn't take any more photos.
10-21-2017, 12:50 AM
November 2016
TOYTEC TIME!
*more to come......
10-21-2017, 10:22 AM
This was a really fun project. Had Toytec assemble the front coils for me and then drove down and picked everything up.
TTHA-9602 - ToyTec/Eibach 3" lift kit - 96-02 4Runner
November 15, 2016
Difference in stock rear spring and new toytec rear 3" lift spring
Shock on the right is the one that broke and was flopping around. The one on the left i bent back and forth until the top bolt snapped. Took all of about 10 seconds
Rear end done. Cleaned out those horrible top mounts and they were in great shape. If you have issues getting the spring in you can jack up one side of the axle to make it easier... No extended brake line at this time but it is on the list for future when I do a full brake system flush.
10-21-2017, 10:37 AM
Toytec install - continued
November 16, 2016
Upper control arm removed....a little paracord came in handy
Front assembly removed
Toytec in place!
SPC UCA in!
by
Upper ball joint, without boot
Free tool rentals from O'Reilly's - Ball joint kit and 4Wheel drive kit... makes this job pretty easy.
Ready to pop that ball joint out. No need to spend time cutting it if you set it up like this.
First you may think this is not going to clear the fender.....
But it does, just enough to get the socket on!
to be continued........
10-21-2017, 10:46 AM
Front Toytec install continued...
Press this in and you are ready to finish the Upper ball joint install
Ready for an alignment! I've got too much tread to swap the wheels and tires right now so just gonna deal with it. :roll eyes: 245/75/16 : came on the truck when I bought it, Cooper Discovery ATP
10-21-2017, 10:48 AM
November 22, 2016
Currently clocking in at.....
10-21-2017, 10:53 AM
10-21-2017, 10:59 AM
January 4, 2016
Made a few stops up north today to pick up the next round of mods...
1st stop....
Untitled
2nd stop....
3rd stop..... dropping off the AOR for some powder coating...
10-21-2017, 11:26 AM
January 21, 2017
The weather has been amazing so let's get that bumper mounted!
Those mounting brackets need to be cut off... but don't cut off the end of the frame or you will loose strength...
I cut around so the end of the frame was still capped to retain maximum strength. Grind it just enough for the cross member bar to fit.
Crossmember
Pulled off the rest of the grill and what not.... been secretly working on a Satoshi to add in when this all goes back together...
Getting there!
RCI
Complete!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
