Old 05-08-2020, 05:11 PM #1
DesertRoads's Avatar
DesertRoads DesertRoads is offline
DesertRoads is on a distinguished road
Stripped Transmission Pan Bolt: Replace Pan or Tap?
So I decided to change my auto transmission fluid today--drain and fill only. No filter, drop the pan, etc. Upon putting the bolt back in, it never tightens. It turns, and will come back out again, but won't tighten. I'm guessing the last person to do the transmission flush overtightened the bolt. So, is this something I can just get a tap kit for and re-do threads? Or will I need a new pan? Thanks!
1999 Toyota 4Runner Limited, 4WD, Center Locking Differential
DesertRoads is offline   Reply With QuoteReply With Quote
Old 05-08-2020, 05:32 PM #2
spartacus's Avatar
spartacus's Avatar
I threaded my oil pan and helicoiled it with bigger plug 10 years ago and have had no
issues. Don't see why not the atf pan.
Old 05-08-2020, 05:34 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What do the drain plug threads look like?
Old 05-08-2020, 09:08 PM #4
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
If you know some one that knows how to weld or braze they could take a nut and a fix it to the pan.
plcfcng is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 06:00 AM #5
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
That's what I would do.
tvpierce is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 07:18 AM #6
The 97 puppy hauler had the plug threads messed up. It looks like the bolt is softer than the pan. The pan threads were good so I just ordered a new drain plug and gasket from the local dealer.
Old 05-09-2020, 06:29 PM #7
Reidabook Reidabook is offline
Reidabook is on a distinguished road
I over tightened the drain plug and it stripped the plug instead of the pan. So you might only need a new plug.
Reidabook is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 10:11 PM #8
roger65 roger65 is offline
roger65 is on a distinguished road
If there is room I like Time Serts over helicoils. Solid metal insert vs coil of wire.
roger65 is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 12:51 AM #9
Johnnie Johnnie is offline
Johnnie is on a distinguished road
your post isnt very clear about whether its a pan bolt or the drain plug. If its a pan bolt then it needs a helicoil, easy to find at a napa or even a home depot, if you've never done one before then check it out on you tube. if its a drain plug then you probably need a new pan
Johnnie is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 02:05 PM #10
Thank you all for your response. The plug seems to be fine, but the threads in the pan seem to be off. Maybe I'll try a plug first, then the inserts. A new pan is $167 from the dealer-- plus I'd need a $25 gasket for the pan. A new plug is cheaper than the pan, so I'll start there.
Old 05-10-2020, 03:51 PM #11
Thank you all for your response. The plug seems to be fine, but the threads in the pan seem to be off. Maybe I'll try a plug first, then the inserts. A new plan is $167 from the dealer-- plus I'd need a $25 gasket for the pan. A new plug is cheaper than the pan, so I'll start there.
Clean the threads in the pan with a tap or thread chaser.
Old 05-14-2020, 03:57 PM #12
I finally sourced a new plug from the dealer. Unfortunately that didn't fix the problem. So Looks like I might have to tap the hole and go with a bigger plug. A new pan is $166 from the dealer, and there doesn't seem to be much in the way of aftermarket engine/transmission support for these pans. Frustratingly.
Old 11-24-2020, 05:53 PM #13
artcell1620 artcell1620 is offline
artcell1620 is on a distinguished road
Hi, did you end up doing the tap kit? My transmission pan (2000 SR5 4x4) is also stripped, along with the drain plug. A transmission shop told me that these pans have a welded bolt on the inside of the pan and if the plug is stripped, the bolt is probably stripped as well, and he can't tap the bolt. He is recommending replacing the pan entirely. Any thoughts?
artcell1620 is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 09:45 AM #14
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Find a new tranny shop. There is no "welded bolt" on the inside of the pan. Perhaps they are thinking of the newer toyota transmission pans that have a goofy way of draining them but yours is not like that.
You can either buy a new pan/plug or try the methods described above (heli coil or weld a nut over the damaged hole).
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 09:56 AM #15
For me the pan was fine and just the bolt stripped. When I bought the 97 limited puppy hauler the drain plug in the pan didn’t feel right threading the trans the first time I drained it. The second time it stripped. But I had already bought a new drain plug.
back , bolt , pan , tap , transmission
Stripped transmission pan bolt zach1288 4th Gen T4Rs 12 04-17-2017 07:52 AM
stripped bolt hole eanema 3rd gen T4Rs 15 11-20-2015 08:28 PM
Top hat bolt stripped help! Chubbs22 3rd gen T4Rs 3 09-30-2014 02:41 PM
Transmission pan drain bolt stripped! :( quicksilvr 3rd gen T4Rs 8 02-11-2011 12:48 AM
Stripped bolt chunderboy Off Topic 7 06-04-2005 01:23 PM
