Old 05-09-2020, 12:39 PM #1
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR has a spectacular aura about infamousRNR has a spectacular aura about
What the F did I just break?
Reaching up to grab my oil filter this morning, barely grazed something with the back of my hand...
I look up & see this sensor type thing broken!!
Ugh. So much for a quick oil change this morning...
So what is this sensor thing? I started the truck after and it ran fine with no CEL
What the F did I just break?-8cc78a2e-5731-4556-a231-57f03b996b45-jpeg  What the F did I just break?-ac96db1e-4f49-4386-9fa7-eebcebfec350-jpeg  What the F did I just break?-2a501615-5942-4d2a-a541-e5e33540b6aa-jpg
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
1999 Imperial Jade Mica Toyota 4runner SR5 4x4 - SOLD
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker. . .Build Thread//
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
ARB Bumper, TOYTEC ultimate w/ 9 wraps, TRD Supercharger, e-locker retrofit, TBU, GOBI rack. . .Build Thread//
infamousRNR is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 12:50 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
Oil pressure sensor and its connector.I would think the default for the ECU to illuminate the oil lamp on the dash but guess not.
Maybe you and Tim can do a vid? Probably not necessary.
Hope you are enjoying the new tight shifter...
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 01:30 PM #3
19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough
Yep oil pressure sensor.
Pull the Alt and battery and it becomes easy to get too.
Now is your chance to buy the adapter and install an oil pressure gauge.
Old 05-09-2020, 04:57 PM #4
alumarine alumarine is offline
alumarine will become famous soon enough
Maybe your oil light is burned out?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 07:18 PM #5
The sensor provides the ground for the bulb. No connector means no light.
Old 05-09-2020, 09:25 PM #6
HiLife HiLife is offline
HiLife will become famous soon enough HiLife will become famous soon enough
No cel, and no low oil light.
Electrical lead to the oil pressure switch broke off.
Once you get the special socket to that area it's an easy fix.
Old 05-09-2020, 11:01 PM #7
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
If i'm not mistaken can't you get to it with a long 3/8 extension and a deepwell socket? I think its a 19mm? I don't remember having to use a special socket..Especially now with the wire being busted off It should be easier then ever to take it out since you won't have that still connected. Not a big deal just a oh s*it what just broke lol. The plastic gets pretty soft/brittle where the plug/wire is so it's no surprise that it happened.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 10:50 AM #8
A regular socket would work. No special socket.
Old 05-10-2020, 01:32 PM #9
I think a 7/8 deep socket works just fine. I used my O2 sensor socket and Im pretty sure its a 7/8
Old 05-10-2020, 07:28 PM #10
Here is what it would look like adding a pressure gauge.
Old 05-11-2020, 01:17 PM #11
I went to the hardware store & a 27mm deep socket fits on the end to tighten,..
Old 05-11-2020, 05:58 PM #12
Maybe I used my oil pressure socket I bought for the Jeep Grand Cherokee. There is no way I used the O2 sensor socket if you needed a 27mm.
Old 05-11-2020, 07:24 PM #13
I def agree with this, but I wanted to avoid pulling as many things as much as possible...
how did YOU get onto the sides of this oil pressure sensor thing to unscrew it? it's never been removed I can imagine & it's pretty locked on there.. been giving it some penetrating oil over the last day or two & trying again.... I am attempting with some vice grips but I am just not getting the right bite with such little & I don't have a 27mm socket... plus it's tight in there, so a deep socket will pretty much require removing the alternator...
so much for an easy morning oil change... this oil change has transpired into a radiator replacement, trans cooler install, drive belt replacement, thermostat replacement (found an aftermarket 79 & my OEM one has the TEQ stamped on it with 82) & skid plate painting & a ton of brake cleaner to clean up all the gunk that has accumulated from I am assuming sloppy oil changes & leaking valve covers....
Old 05-11-2020, 08:20 PM #14
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe has a spectacular aura about Kanoe has a spectacular aura about Kanoe has a spectacular aura about
Kanoe's Avatar
Here is a homemade oil pressure sender tool. It’s just a $10 deep socket I trimmed to fit with an angle grinder.
I needed it for my corolla which hides the sender behind the exhaust manifold. Works just as well on the 3rz and May for you also.
Ratchet wouldn’t fit in so now I can use an open wrench on it.
What the F did I just break?-e2d8a0e7-d016-4e02-8519-da258a55a8af-jpg
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo (tbd if can be resurrected)
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 08:43 PM #15
Removing the battery and Alt was the only way I felt I could get to it to put a wrench or socket on it.
Since the engine was new it came out easy. But I dont remember having problems removing it (on the engine stand) from the 258,000 engine to get it rebuild.
morning , oil , sensor , thing , type
What did I break? CXS 4th Gen T4Rs 8 02-16-2015 11:16 PM
Did I break something? knightsfs4 4th Gen T4Rs 5 07-25-2011 03:58 AM
hard break during 'break in' phase Fareastplaza 5th gen T4Rs 3 04-05-2011 12:16 PM
Break in ikT4R New Members 0 02-25-2011 10:55 AM
