Old 05-23-2020, 12:27 PM #1
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Can't get front brake bleed screw to stop seeping fluid
Hi all,
I'm having a hard time figuring out how to get one of my front bleeder screws to stop leaking from the threads!
I'll try to make this clear and step-by-step:
I am running 199mm 01-02 Tundra calipers up front, which have a 1.0x10mm thread pitch brake bleed screw.
I just put some Stoptech SS lines up front, and an extended Toytec line in the rear.
I did a full brake fluid flush with OEM Toyota Dot fluid.
I did a full bleed, and the pedal feel is now excellent.
I crawled back under after riding around some, and noticed my front passenger bleeder screw had a stream of brake fluid coming out of the threads. I cranked down on it with a proper flare nut wrench, and it didnt help the leaking at all. I probably tightened it way too much to be honest.
No fix.
Went to the auto parts store and got a new bleeder screw--- Didnt fix it
Wondering what the heck to do now. Really not wanting to get a new caliper if I can help it Hoping the bleeder seat isnt screwed up? How could I tell if it is?
Thanks!
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 12:56 PM #2
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
Originally Posted by WeakSauz View Post
Hi all,
No fix.
Thanks!
What about just using some thread sealant?
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 01:03 PM #3
Not a bad idea, but Brake fluid will eat thread sealant. It would be a bandaid. Brake bleeders don’t seal at the thread, they seal at the seat.
I’m thinking I trashed my seat when over tightening. Live and learn!
Old 05-23-2020, 01:38 PM #4
Dom8706's Avatar
Dom8706's Avatar
Valid point. Hopefully someone else will have a better idea so you dont have to redo everything.
Old 05-23-2020, 01:58 PM #5
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
It's usually the bleed screw taper being damaged from overtightening, but since you have already replaced it there might indeed be a seat issue. I've been able to see into the seat with a flashlight when I've had this issue - I had a Porsche caliper half that was mis-manufactured (drilled off-center) once - had to replace the caliper half to correct it.
Where did you get the calipers?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 12:29 AM #6
These are Napa reman units
I was a little perplexed on this since I ran these calipers about 20k miles with no leaks. I went back to Napa today and got a new passenger caliper.
Had to really crank down on the bleeder on this one too- even with the supplied screw. However no more leaks!
I must have screwed up my previous calipers seat- I can’t think of anything else it could have been, since the new one is good to go now
bleeder , brake , fluid , front , screw
Talk me through brake bleed/fluid replacement j_h_cole 4th Gen T4Rs 32 10-18-2021 04:01 PM
Brake bleed/fluid swap noob - need some answers OnTheEllipse 3rd gen T4Rs 17 06-28-2017 02:45 PM
DIY: Brake Fluid Change / Bleed Using a Scan Tool m85476585 4th Gen T4Rs 9 04-10-2017 10:49 AM
Best way to bleed/flush brake fluid. poser General Discussions 5 10-26-2014 02:07 PM
Best way to bleed/flush brake fluid. poser 3rd gen T4Rs 4 09-29-2014 10:47 AM
