04-04-2013, 03:34 PM
Real Name: Mason
Real Name: Mason
Painting Sliders. What is the best way to go about this?
I bought some HD-SKO sliders to weld onto my Runner. I bought these in case I get into a situation I would need them. I don't plan on going down trails where I know I will need them. So they are kind of insurance more then use you could say.
I have been told I should powder coat them if they will not be used that much. Steve over at Sonoran Steel (bought though him) told me to use no primer and just spray ACE Hammered on them. So far taking his advice but want to hear other thoughts. Two of my 4Runner friends have these sliders and used the Hammered rattle can paint. Both have rock chips from highway/ dirt road use.
I think I should also sandpaper the metal so the paint has a better chance of holding up. Will steel wool #2 do the trick if I paint them with the Ace Hammered?
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
04-04-2013, 04:02 PM
The method I used to paint my sliders is tack everything into place on the truck finish weld them off the truck, use a scotch bright pad to clean the metal, rubbed it down with acetone, primed then painted with semigloss black paint.
I have no experience with that hammered paint, but normally you should use primer when painting bare metal.
I also see no need to powder-coat them unless that's the look your going for. Mine have no dings, or scratches from debris hitting them, a spray can will do you just fine.
1996 SR5 3.4 4x4 Auto My Build http://www.toyota-4runner.org/3rd-ge...ld-thread.html
-Toytec Coilovers Eibach Springs on Adjustable Bilstein 5100+diff drop, Rear OME 861 coils+Panhard bar drop w/Black Tokico Shocks-285/70/17 Goodyear Duratracs -17" Procomp 7105 -Shrockworks Front Winch Bumper -Light Racing Upper Control Arms, 231mm Tundra Brakes-Energy Suspension Poly Steering Rack Bushings-4xinnovation DOM sliders,JBA Cat-Back
1974 FJ40 - Restoration In Progress
04-04-2013, 04:20 PM
Real Name: Kevin
Real Name: Kevin
I would use an etching primer first, then several coats of the Rustoleum of your choice - I like the hammered finish too. The nice thing about rattlecanning them is you can touch them up when (not if) they get scuffed.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
04-04-2013, 04:24 PM
Real Name: Johnny
Real Name: Johnny
im my opinion, powder coating armor is a complete waste of time and money. why? well the whole point of armor is to protect your vehicle, so it will be getting scratched, scraped, dented, etc.
i like to use a semi gloss black rustoleum w no hammer finish business in it. its usually found at every store that has paint, and is always cheap. the key is making sure you let the paint cure before stepping on it. i paint mine right before i wheel, so i can see the contact they are getting..
if they are bare steel, just clean them w acetone first and make sure theres no dirt, oil, etc on them. thats really all you need to worry about. and yes, i pretty much always always use primer.
FYI, if you are planning on standing on these ever, consider matte or flat vs gloss. gloss is slippery.
2000 4Runner SR5, 5vz-fe, 5speed, 246k miles, bfg 35's on stock 1985 4runner wheels
04-04-2013, 07:03 PM
Real Name: Mason
Real Name: Mason
Thanks for the input guys.
Going to scratch the powder coating off the list.
So this is my plan so far...
-Scrub them with some steel wool #2 so the paint sticks
-clean them with some acetone
-apply 2-3 coats of the hammered flat/gloss black with time between coats.
Will I be alright with this?
04-04-2013, 07:19 PM
Real Name: Ben
Real Name: Ben
I plan to do self etching primer with VHT chassis & rollbar paint. Stuff looks good and has held up on my PH bar well. Now I just need the damned stuff to get here lol
04-04-2013, 07:22 PM
Real Name: Ben
Real Name: Ben
Get some "cheese cloth" ad wipe them down after the steel wool to remove any leftover particles
04-04-2013, 07:23 PM
What I did was wipe them down really good with Denatured Alcohol, then take 320 grit sand paper and scruff them up a bit, then wipe down with denatured alcohol again.
I used the Rustoleum Professional paint and primer.
I put on a first very thin coat of primer, wait about 5 minutes then another very thin coat, 5 minutes then a decent coat, wait 10 minutes then another good final coat of primer.
Then do the same with the Black, 2-3 very thin coats then 2 or 3 decent coats.
Then use the non skid tape on the entire top.
Did mine 2 years ago, still looks like I did it a week ago.
2002 3.4L 4X4 Sport Edition
04-04-2013, 07:38 PM
Real Name: Mikhail
Real Name: Mikhail
Did you paint yours on or off your 4runner?
-2001 Sport Edition 4runner 4x4 2nd gen Supercharged-
-1985 Toyota Hilux (Pickup) DLX Turbo - 4x4 5speed w/2LT Turbodiesel
Build Thread
04-04-2013, 10:53 PM
Real Name: Mason
Real Name: Mason
Went to Ace and bought this stuff...
-320 grit sand paper to scuff up the sliders
-Acetone to clean them
-Rustoleum Hammered black. Seems kind of glossy but I didnot see a flat black.
Painting tonight!
04-04-2013, 11:18 PM
My sliders are arriving on Monday from Savage. Done some extensive research here and elsewhere on what to do. One of my clients is a professional auto painter and discussed many options with me. His powder coating guy said $150. wmeredith posted a great thread on painting and installing his sliders. powder coating is brittle and will chip. I'm taking mine to the Line-X fella. He said $175 and far more durable than painting or powder coating. I have different concerns, for I live in the great salt belt. If I get chips, I will get rust. I too, don't intend on going on trails that require them (if possible), but it does happen. I only get to play in the rocks a few times a year but insurance is good.
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
04-04-2013, 11:49 PM
Real Name: Trae
Real Name: Trae
Paint is always easy to touch up. Powder coating and spray liner looks great, but not as easy to touch up when you get some trail rash.
I prepped mine HD-SKO's with acetone, adhesive promoter from Autozone and then a few coats if Krylon satin black.
I've already got some trail rash, but no worries, a touch up of Krylon will take 2mins!
2003 T4R Limited V8, Stock-wife's-SOLD
2001 T4R SR5 with 3.4, Budbuilt skids, 265/75R16 Cooper ATP, uni-strut load bars, OME 2.5 with heavies in the front and mediums out back, Stubbed-SOLD 7.18
2005-GX470-Metal Tech sliders, Power coated Tundra wheels with LT265/70 Cooper A/T’s
1980 FJ-40 Hard top, Stock 2F, Weber 38, Steric rocker guards, Atlas 9500, rear ARB -Hope I never have to sale
04-05-2013, 11:54 AM
I painted them after they were welded ON.
04-05-2013, 12:35 PM
Real Name: Devin
Real Name: Devin
Had anybody considered bed-liner?
Love that stuff.
04-05-2013, 01:17 PM
on my 94 I used the rattle can spray on bed liner stuff and it did not seem to be any stronger then regular paint, just textured. I was talking to a guy who did his utility body truck with rhino liner, that you can buy your self, and painted a enamel gloss coat over it to protect it and he said it has been on there for years with a lot of metal scraping it, and he loves it! I was thinking of buying some and doing my bumper and sliders with it!
2002 4runner Sport Edition-camburg mid travel set up,shrockworks front bumper and lot more!
2002 Tundra limited-Toytec lift, Teflon wheels and 35's
1994 4Runner- 4.88s, Grizzly locker, Old man emu,Surco roof rack and 8 working lights, 204k on the clock!
My build thread- http://www.toyota-4runner.org/3rd-ge...ld-thread.html
