Old 05-11-2020, 01:32 PM #1
4restGump 4restGump is offline
4restGump is on a distinguished road
Ebay Power antenna
Hello all
In the search of fixing my power antenna Iíve found this on eBay.
Power Antenna Kit For Toyota 4 Runner 1996-2002 Stainless Steel Mast Radio FM/AM | eBay
Just wondering if anyone has tried it? Thank you
4restGump is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 03:34 PM #2
Gull81 Gull81 is offline
Gull81 is on a distinguished road
I have not personally used that antenna, but I tried another and it didn't work. I would not have too much confidence in that, especially considering it is an aftermarket motor and not just a mast. I personally plan to do this antenna mod at some point:
3rd Gen Stubby Antenna Mod
I know the tacoma antenna whip mod is also popular.
1997 4runner SR5 3.4 2WD
171k Miles, North Carolina
Gull81 is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 03:49 PM #3
May I ask why it didnít work?
Old 05-11-2020, 04:43 PM #4
Sure, I bought just the power antenna mast and the little plastic cable that feeds into the motor was a touch small. It would grab it and bring it up and down, but the resistance at the bottom wasn't enough to give the motor the 'shut-off' signal, so it would keep spinning and grinding on the cable.
The OEM antena mast was about 30 bucks by itself. Again - no experience with this aftermarket motor, but I think there are just better solutions unless you really like the antenna going up and down for some reason.
Old 05-11-2020, 05:29 PM #5
Tha Krazy One Tha Krazy One is offline
Tha Krazy One is on a distinguished road
I have an '02 and have the same issue.. I might buy the Metra 44-PW22 universal replacement antenna from where I work. If I do I will let you know. Here is the link to the antenna from our work site...
Metra 44-PW22 Fully Automatic AM/FM Replacement Power Antenna | The Wires Zone
Tha Krazy One is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 10:39 PM #6
Sure, please let me know. The one on eBay is just as much, but I rather pay to the one that work. Thank you
Old 05-12-2020, 05:26 AM #7
O2RunnerSR5's Avatar
O2RunnerSR5 O2RunnerSR5 is offline
O2RunnerSR5 is on a distinguished road
Got this on eBay. Just the telescoping mast since my motor worked. Works flawlessly.
2001 SR5 4x4 Premium
2017 SR5 4x4 Premium
17 SR5
O2RunnerSR5 is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 05:54 AM #8
Ghostrider Ghostrider is offline
Ghostrider is on a distinguished road
How do you mount a generic one. When I did mine I grabbed one of of a junkyard but the bracket is definitely a one off.
Ghostrider is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 10:22 AM #9
Thatís good news. My motor still run, you can hear it, but no antenna movement. Do you think I can just replace with that?
Old 05-12-2020, 03:34 PM #10
You Absolutely can. Very easy swap also. Took 5 minutes.
1. Unscrew the silver/chrome ring at the antenna that has the 4 notches and take it off along with the black piece that sits between the vehicle and screw.
2. Turn your radio on, this will make the motor extend the antenna.
3. Pull the telescoping antenna out.
4. Extend your new telescoping antenna and face the cable teeth forward (towards the passenger headlight) and insert the cable into the motor until you feel resistance.
5. Have someone turn the radio off and the motor should grab on to the teeth of the cable and retract it into place.
Make sure you guide the antenna into the hole while the motor is pulling it down. They reattach the black piece and chrome screw and your all done.
17 SR5
Old 05-12-2020, 03:37 PM #11
Ebay Power antenna
Oh also put some lithium grease on the teeth of the new antenna before you install it.
This should work as long as your old antenna cable teeth didnít break inside the motor.
If the cable did break inside the motor, youíll know because the motor wonít retract the new antenna fully or at all. Worst case youíll have to take the antenna motor out and take out the broken cable from it.
My 4runner had no antenna installed when I bought it. The previous owner must have taken it out.
I like Toyota OEM stuff which is why I kept the telescoping antenna and didnít go with a stubby or a non telescoping antenna.
17 SR5
Old 05-12-2020, 06:15 PM #12
A couple of comments since I did both the mast replacement and two years later replaced the entire motor. When you remove the old mast just make sure you see which direction the teeth are pointing - helps get the new one in. If it breaks off inside (mine did also) you cannot just remove the motor. You have to disassemble it while it is still in fender well. Toyota saved a couple of pennies but making the antenna cable part of the motor instead of using a disconnect. Which brings up the last point - if you replace the motor you have to replace the cable. Don;t even try to run it where the original is. On mine it was put in place before all the cooling ducts etc. I just ran the new one under the footwell carpet.
Old 05-12-2020, 11:42 PM #13
As mentioned earlier, I tried replacing with an aftermarket ebay antena. I ran into issues due to the mismatch of the gauge of wire. Your results may vary.
Old 05-13-2020, 11:51 PM #14
Soren96 Soren96 is online now
Soren96 is on a distinguished road
The plastic finally broke on my mast and I got a well reviewed replacement on amazon (instead of the cheapest one). Didnít have too much trouble replacing it. It worked just fine, but only lasted a year and a half before the plastic broke again. I ended up pulling it out and putting in a Metra 44-TY23 and itís just like the Tacoma whip, only itís $14. The mast for it is ugly, but you can thread almost any replacement on the Metra base, which looks completely oem. I currently have the black mast from my old VW Golf on there, but am looking at some other mid sized springy options. I certainly donít miss the sound of that dumbass thing going up and down. I highly recommend the Metra!
Soren96 is online now   Reply With QuoteReply With Quote
Old 05-14-2020, 03:12 PM #15
3bears 3bears is online now
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
I replaced mine with an original equipment toyota one after reading about issues with aftermarket. I have had several winters of it being stuck down due to cold/snow/freezing and it has still been working no problem. It tries to go up...but cant when its minus 40 or so but is working fine now with temps above freezing
however i am switching to the taco whip ( have all the parts, just have not done it yet) as I dont want to bust the power antenna on low branches. I bought the mini rockers so I could turn the antenna off to avoid the issue as my antenna goes up even if just on cd or blue tooth...but never did that job either
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
3bears is online now   Reply With QuoteReply With Quote
antenna , ebay , found , power , wondering
Power antenna to whip antenna broad.named.maude Classic T4Rs 1 02-18-2020 08:40 PM
Replacing head unit: 3 antenna input question & power antenna replacement question Rancho5 3rd gen T4Rs 14 08-24-2018 06:51 PM
Power antenna to whip antenna - 2001 4runner - **PICTURES** ramonortiz55 3rd gen T4Rs 16 12-19-2017 11:48 PM
repair power antenna or replace with fixed antenna leelee Engines / Suspension / Wheels / Tires / Audio / Accessories 1 01-28-2014 03:04 AM
power antenna switch or Tacoma whip antenna? hrt4me 3rd gen T4Rs 18 07-08-2013 10:09 PM
