Old 05-11-2020, 06:05 PM #1
Tha Krazy One Tha Krazy One is offline
Tha Krazy One is on a distinguished road
Looks like I can maybe do plug n play fog lights?!
OK 3rd genners... So I recently installed a new radio and noticed I had an extra harness plug by the traction off button. Something told me that my runner had the option for fog lights. So I,looked under the bumper and I see a harness hanging off the signal wires on both sides. Does this mean I can install fog lights for my runner as long as I get a switch and the lights with mounting hardware? That would be great if this is possible. If anyone has done this please advise.
Tha Krazy One is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 06:14 PM #2
What year?
Old 05-11-2020, 06:56 PM #3
99-02 yes, 96-98 no.
Lights, fuse, relay and new light control stalk should be all you need if you have the right year(s).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-11-2020, 07:12 PM #4
It's an '02. Sorry that I didn't mention that before. I noticed the extra harness when I removed the lower panel under the steering column while running the bluetooth microphone. I have heard of a replacement stalk with the fog switch. Does that mean on the column should be another harness for use with the upgraded stalk or am I relegated with a switch on the lower left panel where I found the harness...
Old 05-11-2020, 07:47 PM #5
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
The light stalk with fog switch is plug and play. As long as you have the correct on for our model year. Then, as stated above, mount the lights and plug in, add the relay, and good to go. The extra plug you found is unrelated.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 02:41 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
agree with above.....for your year it is plug and play just need to find the correct stalk. They did do a change and I beleive you will have to have one for a 2000 or newer.
I converted my 2000 to factory fogs...bought all from a guy..however the stalk he sold me did not fit my 2000...his was off of a 99 I think. So when I went to the wrecking yard to find a correct one it actually came off a 2002.
the difference is in the male part of the plug in and you cant make one fit the other. The handle "stalk" look the same so cant go by that.
Old 05-12-2020, 02:50 PM #7
I converted my 2000 to factory fogs...bought all from a guy..however the stalk he sold me did not fit my 2000...his was off of a 99 I think. So when I went to the wrecking yard..mine actually came off a 2002.
Exactly. Also, a number of other Toyotas use the same stalk. Mine is a '99 and I used one used off a '99 Solara (lots of them had factory fog lights, so the stalk is cheaper than the "4Runner" ones that were on Limiteds only).
Part numbers:
Fog lamp relay: 90987-02012
Fog lamp fuse: (standard - see fuse box lid for value)
Headlight switch '99: 84140-20560
Headlight switch '00+: 84140-14120
Old 05-12-2020, 10:25 PM #8
Real Name: 3 Bears
Real Name: 3 Bears
Part numbers:
very true....he will need the realy and the fuse...and yes the solara...and maybe some others will fit also..you can prob plug in the part number and see what other models so that if a person is going to a pick and pull
good points you brought up
Old 05-18-2020, 02:24 PM #9
Thank you all for the info. Next time I hit up Pick your Part, I will look into that. Now I have to figure out the rear hatch window switch on the center bezel and I should be good to go.
Old 12-18-2020, 06:10 PM #10
sgsquints sgsquints is offline
sgsquints is on a distinguished road
Any idea on what kind of fog light will fit into the factory bumper? looking to do the same thing, just cant seem to find a light. (its probably just me)
sgsquints is offline   Reply With QuoteReply With Quote
Old 12-19-2020, 04:08 AM #11
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Do you mean the little 2" round cutouts that are plugged, which is where the factory fogs would go?
There are a bunch on amazon that will fit, I haven't quite decided on which I'm going to use yet but I'll let you know when I do. I truly considered the factory fog lamp route but from my research, they aren't that good, to begin with, and for the amount of money it costs to get the parts you can buy a good light bar or set of fogs that have way better output. Crappy used ones are going for $100+ per set on eBay and then you'd have to replace the bulbs, and buy the switch. I figured that a meh set of factory lights in total was going to cost $250+ and you can buy a lot of lightbar for $250. Plus, if you don't plan on keeping your factory bumper forever, the factory fogs will be useless if you upgrade, whereas you can move a set of aftermarket lights to the new bumper.
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
fog , harness , lights , plug , runner
96 vs 97 ecu plug n play? 96-Runner 3rd gen T4Rs 4 02-26-2021 11:44 AM
FS: Baja Designs Squadron-R Sport LED Fog Lights Plug and Play Kit - Seattle $250 2064R For Sale: T4R Items 8 08-27-2019 01:43 AM
Plug and play used NAV for 05 SR5? Groovechild Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-13-2011 03:41 PM
Plug and Play? Theory2 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-14-2006 12:18 PM
