Originally Posted by Tha Krazy One
The rear defroster does work that I know for a fact. Is there something else I should look at? I took it apart again the other day to look for a loose harness.Everything else on the bezel has a harness except the window switch.
Like I said, there is no "rear switch harness". The harness to all controls in that area (ECT, defroster, rear window) connects to the switch assembly via that white square C23 connector. So either your switch is not working, or something is wrong further downstream in the wiring or the actual window motor. But it can't be an issue of a loose harness behind the bezel, not if your defroster is working.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
