Old 05-16-2020, 01:24 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I dont think there is a fuel pump access from inside the truck...otherwise why are people dropping the tank
Old 05-16-2020, 01:51 PM #17
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Originally Posted by cashflow50 View Post
is it that little 15amp fuse in the engine bay? so if that checks out then all points to fuel pump?
Is it possible to go through the fuel pump access from inside the truck to extract the fuel?
Yeah that fuse. Did you have any luck with it starting by spraying some starting fluid in the intake? You can't access the fuel pump from inside the truck. That thing under the back seat is just a harness cover. Just drop the tank, its fairly easy, but with a half tank I'd get a friend to help you along with a floor jack and some plywood.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 03:31 PM #18
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
EFI 20amp fuse is good. As for the fuel pump access thingy I mentioned earlier, I’m using that to extract fuel from. I’ve taken out about 4gallons so far. I have maybe 4kore gallons to go. What I did was unplug the connectors and removed the 8 bolts for the cover. Lifted it up and shoved a siphon tube down. Worked so far. Getting it lighter for drop tank.
cashflow50 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 04:33 PM #19
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Ok yeah, I guess you could that way, long as you can keep debris from falling in tank. I had a lot of crap on top of mine.
Old 05-16-2020, 05:46 PM #20
cashflow50's Avatar
cashflow50's Avatar
My tank looks nice and clean. Even the gasket is immaculate. I think I’ll reuse. What’s the torque on the 8mm bolts? Just go by feel and snug tight it on?
Anyways thanks guys for helping me
Old 05-18-2020, 01:09 AM #21
cashflow50's Avatar
cashflow50's Avatar
successful tank drop. It was a faulty fuel pump. Maybe the oring had something to do with it as well, cause it was torn and ripped. All in all it was pretty easy job. Empty tank is a key, although in my case i got stuck. Truck had little over half a tank.
Installed:
Denso fuel pump (bought a while back)
Denso fuel check valve (bought a while back)
oem oring
Next up timing belt. it's due
Old 01-08-2022, 07:40 PM #22
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
Fuel Tank Drop
CashFlow,
On your 2001 did you have to remove the driveshaft? Or did you find a way around that? I will be dropping the tank on my 2001 soon - bad overfill check valve giving P0442 code. I'm sure the video you watched dropping the driveshaft was the same I watched by Fix It Angel.
Thanks.
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
TX4Running is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 11:16 PM #23
spartacus's Avatar
spartacus's Avatar
Originally Posted by TX4Running View Post
CashFlow,
Thanks.
hope fully @cashflow50 would chime in.
I did not undo the rear driveshaft on my 2000 when replacing the fuel pump. 2001 should be the same.
Old 01-08-2022, 11:58 PM #24
cashflow50's Avatar
cashflow50's Avatar
No I didn’t. Was kind of tight with the drive shaft but you have to be patient. It took me a good 30-45 minutes trying to remove the hoses to the tank. Pita but it beats taking off the drive shaft.
bad , fuel , maf , oring , pump
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
p/s pump oring #? 3bears 3rd gen T4Rs 2 05-21-2018 02:13 PM
No Fuel? Bad Fuel Pump? Bad Fuel? Aliens? Gremlins? 007Tacoma 5th gen T4Rs 12 05-04-2018 09:08 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
