Old 05-13-2020, 12:05 PM #1
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Let's weigh the driveshaft u-joint options
Short story: My front u-joint gave out on me...and now im weighing out my options.
Long story: started getting a slight driveline vibration when releasing gas pedal at 60+ mph. This was months ago. This past month a rehearsed to 4.88. Shortly after the slight vibration turned to heavy vibration when driving at 70+. My thoughts were lift changed the angles and what not that the u joints had been sitting for decades. New gears added more stress to joints with the ability to turn wheels with more power. Sure carrier bearings improperly installed crossed my mind but and I was hopefully that the u joints might just need a regressing to relubricate but then I got under the truck and found this...
That's right front u joint seals are toast. I did pack with new grease knowing it would spray more but hopefully slow the progression until you folks chime in on my options as I see them.
Options:
1: replace front u joint only . OEM part cost $100
2: replace front and rear u joints...back one is likely to go out shortly although no play is noted. OEM part x2 cost $200
3: after market driveshaft replacement. Has both front and rear u joints replaced, also takes care of potential 2 piece coupler rubber seal that is also 20+ years old on current shaft. Labor to swap is easier, quality of parts may be unquestionable. Cost $330 - $400.
4: OEM drive shaft replacement. Same reasons as option 3 but takes away questionable parts. Cost $500. ( I know! Knot as pricey as you thought right!? Considering u joints from dealer are $100 each).
Now before you folks tell me $300 on Tom Woods and I'm good to go. His site specifically states he doesn't do 2wd drive shafts, which is what I need. And like an ass hole I still emailed to verify that he won't make it.
4wd conversion is in the works so the driveshaft will be obsolete at some point ( @phattyduck situation haha, he knows what I'm talking about). I just don't have a timeline on when the conversion and part collecting will be complete.
So with that said. If you were in my boat, how would you proceed? No right or wrong answers just want to hear from the community to help weigh the options.
Let's weigh the driveshaft u-joint options-20200513_080551-jpg  Let's weigh the driveshaft u-joint options-20200513_080558-jpg
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 12:17 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Are you sure the u-joint grease seals are toast? The splay of grease under the rig is normal to see from greasing the u-joints. The extra grease that squeezes out of the bearing cups gets flung out do to centrifugal force. Does the joint have detectable play?
Old 05-13-2020, 12:33 PM #3
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I had my local driveline shop replace my front u joint and rebalance for under $180 OTD on my 1996 2WD back in like 2013. I believe he used Spicer. I drove that truck until 2015 when I bought my current 2000 4wd T4R so it lasted me a couple years and was doing great when I sold the vehicle. Not the worst option if you don‘t want to do the work or swap with another used driveshaft that would last an unknown amount of time due to mileage. Lifted angles are not kind to the u joints.
Recently my double cardan on my 2000 4wd was making a ton of noise and vibes and since they’re not rebuildable, I replaced it with a Tom Woods for $500 OTD. If you’re doing a 4wd swap, it’s not the worst option since anything you get used is likely on borrowed time, again, due to the front u joint angle on a lifted rig.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 12:41 PM #4
Tim, OEM 2WD u-joints are sealed and 'maintenance free' - no grease zerks to be found. The shaft is a very different design than the 4WD one (no double cardan, slip yoke into trans, etc.).
If you do know that you are going 4WD in the near future, just get the u-joint replaced. It is maybe 50/50 that this will be good enough for a few years. The vibration you have gotten already may have worn out the rubber...
I ended up getting a whole new shaft (before the 4WD swap was planned) for ~$400 from a local shop (all new), then sold it used maybe 10k miles later for something like $200.
PS. The rear upper arms are different 4WD vs 2WD - if/when you do the swap, swap those arms too.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-13-2020, 12:49 PM #5
G_Raw's Avatar
G_Raw's Avatar
False. Both my front and rear have zeros. Which means they've been replaced by previous owner ( my in laws) with after market or OEM do have zerks... either way @mtbtim i do have play from the front but not rear.
Old 05-13-2020, 12:51 PM #6
They were replaced then. Much more likely your driveshaft is toast then...
My original shaft had the u-joints replaced twice (when my dad still owned it), then was just relegated to around-town (under 50mph) use until I took ownership because of the vibrations.
Old 05-13-2020, 01:12 PM #7
G_Raw's Avatar
G_Raw's Avatar
I guess now the question is. Since you've gone through this...OEM shaft? Or aftermarket? If so chime in on reputable after market ones to go with.
For those who come across this in the future with regard to Tom Woods drive shafts the deal breaker is if your vehicle uses a slip yoke. They need both sides to use a flange connection ( like 4wd) which is why they generally state they don't make 2wd ones. 2wd commonly use slip yikes at the front end.
Old 05-13-2020, 01:14 PM #8
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Why not buy a Napa U-Joint and put it in yourself? It's a gamble but not much cash involved. And it is already F-ed. As you say, it is temporary.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 01:31 PM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
[QUOTE=phattyduck;3488390]Tim, OEM 2WD u-joints are sealed and 'maintenance free' - no grease zerks to be found. The shaft is a very different design than the 4WD one (no double cardan, slip yoke into trans, etc.).
I did not know this. Interesting choice from Toyota.
OP, if the front u-joint has play, replace the u-joint and carry on. I personally like to go with Toyota OEM u-joints but there are good aftermarket options out there.
This video was done on the rear u-joint for a 4wd model but it will give you an idea of how to replace it yourself if you have the desire, space and tools to do it.
Old 05-13-2020, 01:47 PM #10
HiLife HiLife is offline
Hey G_Raw, that nice Sacramento Toyota yard is a short drive from where you are in Oakland. If can, you should just replace the 2wd shaft with a used unit from there. No must, no fust in R&R'ing a 2wd driveshaft. Go to go for a couple of years.
Or the cheapest option is to r&r the u-joint yourself. Not that bad of a job but, not as easy as just swapping out the shaft.
The best is to go with a rebuilt unit. But is some situations it's cost prohibitive.
Old 05-13-2020, 03:50 PM #11
That's highly personal, and really depends on how long you are going to be using the shaft.
If you are gambling man, get some NAPA u-joints and put 'em in there. And keep them greased from now on. If you still have vibes, you need a whole new shaft.
I just checked RockAuto - they have complete 2WD shafts available for around $350 shipped, so if you can't find a local shop to do it, they are still easily available.
I don't see a reason to go with an OEM shaft unless you are going to put another 200k miles on it. An aftermarket shaft will be solid and rebuildable.
Old 05-13-2020, 07:52 PM #12
G_Raw's Avatar
G_Raw's Avatar
Locally shops are selling at $430. Honestly anoth $70 won't brake the bank to go OEM. Same for rock auto 350 plus shipping totals $430ish. Same scenario. Thinking I'm going to go Napa feasible for $50ish for both joints. Hope they last till the conversion, if not next decision will depend on how much I have stock piled for the conversion.
Old 05-14-2020, 12:01 AM #13
4Reak Show's Avatar
4Reak Show's Avatar
I'm pretty sure there's a "heavy duty" napa version. They should be greasable as well which should aide in longevity. I would go that route. Even if it was $100 for the pair you could do the job 5 times before equaling an OEM driveshaft. And if they only last a year per set (which is terrible and unlikely, and they will likely last longer if installed correctly) that buys you at least 5 years before equaling an OEM driveshaft. Is the 4wd swap 5 years away? If so, then any route you take is monetarily similar long term.
Old 05-14-2020, 12:12 PM #14
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I don't know if the part numbers are the same but for my
2000 4WD I used Napa UJ285 ujoints that are made by SKF.
SKF makes a good product and they are $32 ea.
I expect I will never have to replace them.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-14-2020, 01:00 PM #15
All the 4WD keep forgetting (or never knew) that the SHAFT ITSELF, not just the u-joints on the 2WD can wear out. The center section of the shaft is two concentric tubes with rubber between them. The rubber wears out at some point and the shaft can no longer be balanced or used. No amount of u-joints can fix it once the rubber wears out.
Aftermarket replacement shafts are solid (no rubber to wear out). OEM would give the best NVH and performance long term. But they are more expensive... so that's a choice you have to make.
cost , front , joints , options , part
4wd Front Driveshaft U-Joint Replacement dgbull3 4th Gen T4Rs 3 03-30-2018 03:28 PM
Rear driveshaft Universal Joint bad Hippo393 3rd gen T4Rs 10 02-11-2018 11:30 AM
Cardan joint in rear driveshaft kgbdonkey 3rd gen T4Rs 29 02-12-2017 11:19 PM
rear driveshaft DBL U-Joint Swivel Bearing? 4x4TR1998 3rd gen T4Rs 1 04-07-2014 11:11 PM
Video of Driveshaft - Bent or bad U joint? jmrwd3 3rd gen T4Rs 6 04-06-2009 10:57 AM
