Old 05-14-2020, 10:49 PM #16
nissanh nissanh is offline
The aftermarket U-joints are mostly GMB and.... Just drive your OEM's as those are far superior even worn than a new GMB.
Phattyduck was right about the 2WD drive shafts. Those came without greasable joints and slides into the transmission as most 2WD rear wheel drive vehicles do.
Story about GMB:
I installed a GMB into the pinon end on front drive shaft on a solid axle 1990 hilux LN 106 (part time 4wd). It has may be tops 20 miles of 4WD. After a year that U-joint was almost about to disintegrate.
Old 05-14-2020, 11:11 PM #17
4Reak Show's Avatar
4Reak Show's Avatar
Let's weigh the driveshaft u-joint options
Originally Posted by phattyduck View Post
All the 4WD keep forgetting (or never knew) that the SHAFT ITSELF, not just the u-joints on the 2WD can wear out. The center section of the shaft is two concentric tubes with rubber between them. The rubber wears out at some point and the shaft can no longer be balanced or used. No amount of u-joints can fix it once the rubber wears out.
Aftermarket replacement shafts are solid (no rubber to wear out). OEM would give the best NVH and performance long term. But they are more expensive... so that's a choice you have to make.
This is true. However, he was very clear on the 2wd being temporary. Seems foolish to me to invest in a temporary driveshaft for long term performance. But everyone is different.
Story about GMB:
Napa's website claims GMB is an OEM supplier. No idea if that's true, it's just what they claim. That being said, I've used the "brute force" u joints (napa heavy duty) many many times with great results. I think they are made by spicer which is a very old company that has been reputable for decades.
Again, all this repair is temporary as his 2wd is not long for this world. So again, why invest anything other than day-to-day unless the time frame for its lifespan is significant? I would replace the u joint with decently priced ones, and roll with it. Save the $400 for other 4wd conversion parts.
Edit: looks like "brute force" is a line from SKF which is a company I've had good luck with on other bearing items. But it not connected to spicer as I claimed earlier. Wanted to clarify
Old 05-14-2020, 11:21 PM #18
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Just read this and agree. Just purchased 2 Spicer joints actually prior to reading it. Not bad price point. Swap the one I know is bad up front, when I pull it if the rear is bad I have one to swap there too...otherwise just keep stocking parts for the 4wd swap. Was going to skip OEM shafts for the conversion and jump to Tom Woods right off the bat for that anyways. I'll report back on the spicers once I do the repair. Hopefully this weekend.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 02:27 PM #19
If the shaft is bad (not just the joints), the only two choices left are new shaft or don't drive...
I agree with putting in cheap (errr... non-OEM) for his purpose, as there is a reasonably high likelyhood of needing to replace the whole driveshaft soon even if he stays 2WD for another couple years.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-17-2020, 08:22 PM #20
G_Raw's Avatar
G_Raw's Avatar
I ended up finding a 2wd in junk yard this morning. 60 bucks for the driveshaft, still nice and black unlike mine. It was surface rusted from living near the ocean. U joints are solid on this thing and appear to be OEM. At least non greaseable like OEM u joints. Swapped it in and everything is nice and solid. Returning my 40 bucks a pop spicers. No play what so ever. Hopefully this cheap easy fix will hold out till the conversion...
Still have a slight vibration but. Definately not as violent as it as pre shaft swap. But while I was swapping my driveshaft I noticed a couple adhesive weights appear to be missing from my front drivers wheel. Getting wheels balanced tomorrow and hopefully all vibrations are resolved.
Old 05-18-2020, 07:48 PM #21
G_Raw's Avatar
G_Raw's Avatar
Shaft in all nice and snug, no play in u joints. Tires are balanced all notable sound and vibrations subsided. So now...
Old 05-18-2020, 08:38 PM #22
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Glad you got it working!
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 08:02 AM #23
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Originally Posted by alumarine View Post
I don't know if the part numbers are the same but for my
2000 4WD I used Napa UJ285 ujoints that are made by SKF.
SKF makes a good product and they are $32 ea.
I expect I will never have to replace them.
Just bought the UJ285 yesterday for $26, will eventually need to replace my current rear u-joint if I can't get this zerk problem I'm having sorted out. Have you had any negative results with this joint so far, or is it still running strong? I've heard good things about the NAPA one, so I have high hopes it'll perform well once installed
Old 03-18-2021, 11:04 AM #24
Spicer or SKF is my choice. I use Spicer solids in my cummins. They are stronger than the greaseable joints.
cost , front , joints , options , part
4wd Front Driveshaft U-Joint Replacement dgbull3 4th Gen T4Rs 3 03-30-2018 03:28 PM
Rear driveshaft Universal Joint bad Hippo393 3rd gen T4Rs 10 02-11-2018 11:30 AM
Cardan joint in rear driveshaft kgbdonkey 3rd gen T4Rs 29 02-12-2017 11:19 PM
rear driveshaft DBL U-Joint Swivel Bearing? 4x4TR1998 3rd gen T4Rs 1 04-07-2014 11:11 PM
Video of Driveshaft - Bent or bad U joint? jmrwd3 3rd gen T4Rs 6 04-06-2009 10:57 AM
