Old 03-18-2021, 06:23 AM #1
fathousecat_ fathousecat_ is offline
fathousecat_ is on a distinguished road
Clutch Slave Cylinder
Hello,
I believe my clutch slave cylinder is leaking, meaning the seal is no longer viable. I am going to replace, however, would this be a good time to replace anything else along with it? From my understanding the transmission will need to come out so would it be a good time to get a clutch kit? I have 261k on the odo and am unsure if/when the clutch was replaced. I do not hear noise wen the clutch engages.
Thank You
fathousecat_ is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 08:28 AM #2
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
There is no need to drop the transmission to replace the slave cyl. It is bolted right to the side on the driver side.
When I replaced mine I also replaced the master cylinder as well. If the seals inside broke down and contaminated the fluid is can ruin the seals in both cylinders. The parts are cheap enough where I would replace both if you can.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 08:59 AM #3
HiLife HiLife is offline
Change that hose to while your there.
Old 03-18-2021, 09:00 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you can I would flush the fluid before and after changing parts just to get rid of any possible contaminants before installing new parts
Old 03-18-2021, 09:46 AM #5
Thanks for the clarification. Believe I will replace both parts.
Old 03-18-2021, 09:57 AM #6
Do you have a preference for clutch fluid?
Old 03-18-2021, 11:04 AM #7
Real Name: Patrick
Real Name: Patrick
Dot 3. Any brand will do in my opinion as long as the bottle hasn't been opened
clutch , good , replace , slave , time
Clutch Slave Cylinder Over Extending YotaLac 3rd gen T4Rs 0 01-19-2014 11:12 PM
Clutch Master and Slave Cylinder 85JTRunR Classic T4Rs 5 11-15-2013 02:09 AM
is my clutch slave cylinder bad teachme 3rd gen T4Rs 4 06-26-2013 05:34 PM
Clutch slave cylinder Brina Classic T4Rs 5 05-03-2013 11:52 PM
Master Cylinder, Slave Cylinder Issue bomhour Classic T4Rs 6 01-10-2010 09:14 PM
