Old 05-15-2020, 12:06 AM #1
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
ABS Fuse Safety Issue (Brake Failure) !!!
So I decided to clean my coolant reservoir on my 2001. When trying to remove the bolt of the battery/reservoir holder bar, the head of the bolt snapped . Since I have somewhat of a rust issue the tapout did not help to extract the remaining bolt. I decided to drill it out and put a helicoil.
When drilling I accidentally went too deep and punctured the wiring harness directly underneath. . When I started the car the VSC, ABS, VSC OFF, e-brake warning lights were on. I immediately realized that something got shorted (I thought I fried the ABS ECU). Nevertheless the car started and was driveable so I decided to head home (I was only 4 miles away). About one minute into the drive a loud, continuous alarm started emitting from the dash. I still continued driving. About 200 feet before I reached home my brakes failed . I lost power to the front brakes and was relying on the rear drums only.
Luckily I made home safe.
First I was sure that I lost my entire (and very expensive) ABS/Brake unit, however after some pondering I checked the fusebox and noticed 2 blown fuses: 60 Amp ABS 1 and 40 Amp ABS 2. The latter was just a pull to remove, however removing the 60 amp fuse requires its own write-up. Long story short, you have to take apart the whole box and unbolt it from underneath.
After replacing the fuses, everything seems to be back to normal. Warning lights are off and no beep. I haven't taken the car out on the street yet, but brakes seem fine around the parking garage.
So my concern is, how can a broken fuse lead to a brake failure? Is this a design flaw? Has anyone experienced this?
ArmArak is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 12:15 AM #2
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Doesn't make any since to me. You can pull those fuses to disable the ABS and the brakes work fine.
Was your brake pedal very hard?
I think the ABS pump would have to somehow be in a position to block the hydraulic path to the front calipers. It would seem that blockage would result in a harder than normal pedal.
Your E-brake should have still worked fine.
You should consider buying a few set screw collars to use as depth limiters for drill bits while drilling.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 12:58 PM #3
Ummmm... how is the fuse at fault? It protected your truck from burning down after you damaged the wiring harness!
I hope you fixed the harness while you were at it...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-15-2020, 01:04 PM #4
camryn.samples's Avatar
camryn.samples camryn.samples is offline
camryn.samples is on a distinguished road
Fuses are like a bridge in a electrical circuit I don’t know if your breaks actually failed I think they may have locked up possibly it’s hard to say.
camryn.samples is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 02:13 PM #5
ArmArak's Avatar
ArmArak's Avatar
No the brake pedal was not hard at all. There was just nothing from the front brakes. Also the E-brake worked fine, only the dash light was on when it shouldn't have been.
Old 05-15-2020, 02:15 PM #6
ArmArak's Avatar
ArmArak's Avatar
I fixed the wiring harness.
Ya, the fuse really saved the truck. But I'm wondering why a broken ABS fuse caused the brake issue.
Old 05-15-2020, 02:21 PM #7
The '01/'02 brake system uses an electric pump to operate/boost the brakes. You did the equivalent of using your brakes a number of times after an engine is turned off (no more vacuum boost) in a normal braking system.
So, you used up the safety reservoir of braking power, and that's when all the warning buzzers and stuff happened.
So, if that had happened during a normal drive, you would have had plenty of chance to stop the truck and pull over to a safe location. Instead, you chose to *start* driving a vehicle with 4 warning lights on the dash...
abs , brakes , decided , fuse , home
Issue with Neutral Safety Switch Dianna 5th gen T4Rs 10 06-10-2022 03:39 PM
Bilstein 5100 Failure and Warranty Issue Help snivilous 3rd gen T4Rs 8 01-13-2020 02:08 PM
Lift Kit causes safety issue with new Toyota PoquePro General Discussions 10 12-27-2012 01:06 PM
2008 Dash Light Safety Issue stlsailor 4th Gen T4Rs 16 10-21-2008 12:39 AM
