Old 05-16-2020, 01:03 PM #1
gbb gbb is offline
gbb is on a distinguished road
gbb gbb is offline
gbb's maintenance thread
The purpose of this thread is to document the maintenance, modifications, and adventures of my 2000 Limited w/ the factory rear locker. Its my daily driver, ski, fishing, hunting and camping rig. My objective is to keep this vehicle as close to stock as possible while making modifications that I believe Toyota would have made were they still building 3rd gens today.
Maintenance and mods list. All parts are replaced with OEM components unless noted otherwise.
  • 152,830 -- New radiator, Toyota red coolant, thermostat, upper and lower radiator hoses, lower ball joints, inner and outer tie rods, air filter, wiper blades
  • 154,610 -- Cooper ATW tires in 265/70r16 size
  • 154,700 -- Kenwood double din aftermarket head unit. Added switch to manually control the power antenna
  • 155,000 -- replaced rear axle seal
  • 157,970 -- oil change with Rotella tsynth 5w-40
  • 161,500 -- new accelerator cable
  • 162,853 -- oil change with Rotella tsynth 5w-40
  • 162,853 -- tires rotated
  • 169,026 -- oil change with Rotella tsynth 5w-40
  • 170,720 -- tires rotated
  • 171,795 -- replaced rear O2 sensor
  • 173,587 -- oil change with Mobil1 5w-30
  • 173,587 -- 199mm tundra brake upgrade
  • 179,440 -- oil change with Mobil1 5w-30
  • 179,500 -- tires rotated
  • 180,278 -- replaced air filter, cleaned MAF, cleaned throttle body, diff fluid change (front, rear, and trans) with Mobil Delvac 75w-90, new fill and drain plugs and washers, transmission drain and refill w/ Valvoline maxlife full syn, power steering drain and refill with valvoline maxlife full syn, coolant drain and refill w/ Toyota red, new spark plugs, and new spark plug wires
  • 180,278 -- suspension refresh with Bilstein 6112 on the 5/4 perch upfront and Bilstein 5100 paired with Dobinsons c59-137v in the rear. Replaced lower control arm bushings with Whiteline poly bushings. Replaced steering rack bushings and sway bar bushings with energy suspension kit. Replaced steering rack guide
  • 180,278 -- hitch flip mod
  • 180,278 -- added a Scangauge using the Paranoid fab bracket in the ash tray
I purchased this in the fall of 2017 from the original owner with 152,000 miles. She had received the rig as a college graduation present, had never taken it off road, and kept immaculate service records. It had a bit of surface rust underneath and a few dings on the body, but seeing this stack of service records was all the convincing I needed.
A few photos:
gbb's maintenance thread-mxvesf3vt7-r2-qjsadbva-jpg  gbb's maintenance thread-95wjb0xpsh-v2tdxsnsdea-jpg  gbb's maintenance thread-hefqice1qxumxzv9pncvnw-jpg
gbb is offline   Reply With QuoteReply With Quote
change , drain , oil , rear , replaced
Doc's maintenance/build thread Cow_doc.308 3rd gen T4Rs 8 09-17-2016 12:08 AM
Red Runner maintenance thread yota-runner 3rd gen T4Rs 1 11-10-2015 05:07 PM
Not another maintenance thread.. CentralFL4Runner 3rd gen T4Rs 5 07-27-2015 04:15 PM
Winter Maintenance Thread...... 77'911 Classic T4Rs 13 12-26-2013 07:30 PM
4Runter's Maintenance Thread 4Runter Classic T4Rs 5 12-07-2012 05:11 PM
