Old 05-16-2020, 03:54 PM #1
HunterG425 HunterG425 is offline
HunterG425 is on a distinguished road
Opinions needed- 3rd gen rust
Hey yíall,
Iím in the market for a 3rd gen. I came across a listing for a 2001 SR5 with only 146k. It has all of the records for maintenance. Asking price is 6000. The only downside is that there is some rust on the underside. Iím not too experienced with rust repair, so I wanted some opinions on whether I should go for it and fix the rust myself, or keep looking.
Thanks!
HunterG425 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 04:19 PM #2
Ok here's the pictures because it wont let me upload/add them
Imgur: The magic of the Internet
Old 05-16-2020, 04:23 PM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Keep looking, where you are located you should be able to find a rust free truck.
Old 05-16-2020, 04:36 PM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe has a spectacular aura about Kanoe has a spectacular aura about Kanoe has a spectacular aura about
Kanoe's Avatar
Those photos are mostly the front part of the undercarriage which does not rust as bad as the rear. I'd like to get a look at it in person if it was me, it might not be that bad. At the very least some photos of the rear half of the truck where the rust is likely to be the worst.
How far away is it to look at?
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo (tbd if can be resurrected)
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 05:28 PM #5
Crazy09sage's Avatar
Crazy09sage Crazy09sage is offline
Crazy09sage is on a distinguished road
They arenít the best pics but Iíve seen worse. Iíd get some pictures of the frame around the rear control arm mounts and next to the muffler, and a good shot of the rear to make a better determination. If you do a quick search of the forum youíll see some of the rust restoration projects others have done and trouble areas.
2002 4Runner SR5 4x4 - StockĒishĒ, ISR Mod, LED interior, 99 coils, Bilstein 4600ís, Walker exhaust.
Crazy09sage is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 12:49 AM #6
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
That rust is really not bad. But, agreed with the above. You need pics of the rear control arm mounts, rear frame rails, and rear axle housing. Thatís where the rust will typically be the worst
BrianK14 is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 08:57 AM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
... wanted some opinions on whether I should go for it and fix the rust myself, or keep looking.
Not bad from a central texas standpoint.
yet as others said a personal inspection is best, rear is usually worse.
Take a nice sized piece of cardboard so you can comfortably lay down to inspect well, don't just peak from the edges....
You can use what ever you find to negotiate down, but what is there wouldn't really be called rust penetration, its 'surface rust', nbd...
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 05-17-2020, 09:48 AM #8
Serhey Serhey is offline
Serhey is on a distinguished road
This is a really helpful thread as someone who's also in the market for a 3rd gen and live in one of the worst areas for rust, the Midwest. I am open to buying one anywhere in the US though. What would be the best place in everyone's opinion? I've read that Washington/Oregon get the least wear and tear. Is that true?
Serhey is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 02:04 PM #9
BostonJon BostonJon is offline
BostonJon is on a distinguished road
the seriousness of rust seems to be somewhat subjective. I live in the midwest and that rust wouldnt scare me at all. Yes, I'd like to see the rear control arm mounts and some more pics of the back, but i've seen much much worse on 20 year old trucks.
BostonJon is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 02:05 PM #10
Hey yíall,
should have mentioned - the price seems a bit high to me but that's a regional thing and maybe they are in higher demand in your area.
Old 05-19-2020, 02:26 PM #11
rivenbbe rivenbbe is offline
rivenbbe is on a distinguished road
You can definitely Find rust free ones. I happened to come across a 97 in Va (which is terrible on frames).. however it was purchased by the dealer on auction and had spent its life in New Mexico. Frame is immaculate. Just do some digging. I got super lucky considering I was only looking for a manual.
rivenbbe is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 02:34 PM #12
SamSquantchT4R SamSquantchT4R is offline
SamSquantchT4R is on a distinguished road
Do not buy a 3rd gen with rust. The car will not be worth the time/ money you put into it for another 20 years. This is not a 50k collector car if you restore it... yet. Also- there is always more rust than you can see. So if what you are seeing gives you pause- remember there is likely double that hiding elsewhere.
SamSquantchT4R is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 04:27 PM #13
Hardizzy Hardizzy is offline
Hardizzy is on a distinguished road
I had to perform patch repairs around the lower control mount by the exhaust on all four of my Northeast 3rd gens. This frame actually looks pretty amazing by my standards. There seems to be a good bit of surface rust on the axle housing. A wire wheel and some home depot spray paint will fix her right up! I very much doubt you have any frame rot, only way to know for sure is to stick your hand up there and feel around. ;)
Hardizzy is offline   Reply With QuoteReply With Quote
3rd , gen , iím , opinions , rust
Opinions on rust / frame condition tyrenta 3rd gen T4Rs 39 05-27-2020 10:01 AM
Looking at a Used 5th Gen - Rust Opinions Needed! altreezy 5th gen T4Rs 7 12-13-2018 05:59 PM
Your opinions on this undercarriage rust please Reptile Christ 4th Gen T4Rs 2 04-04-2018 10:20 PM
IS THIS TOO MUCH RUST ? Opinions needed jreask 3rd gen T4Rs 15 06-13-2016 10:52 PM
Opinions - is this rust bad? Animportant 3rd gen T4Rs 9 01-27-2015 12:02 AM
