Old 05-17-2020, 11:00 PM #1
T4topher's Avatar
T4topher T4topher is offline
T4topher will become famous soon enough T4topher will become famous soon enough
T4topher's Avatar
Oil filter stuck
I guess the dealer tightened the crap out of the oil filter on the last oil change. Not really sure what to do at this point seeing if anyone has any ideas. Itís in a super tight spot on my 2015 v6 Chevy Silverado (I know itís not a t4r but you guys are pretty resourceful and I figured Iíd ask here..)..
Hereís a picture of whatís left of the filter..
Basically it got like this from me sticking a screw driver through it and when I tried turning the screw driver it just ended up ripping the metal can instead of unscrewing the filter.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 11:13 PM #2
Dieselchessy Dieselchessy is online now
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Spanner wrench, or trash a pair of needle nose pliers using them poked in the oil ports on the flange???
Were you turning the correct direction?
I prefer the oil filter removers that cup the end of the filter and fit a ratchet. Your well beyond that now though.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is online now   Reply With QuoteReply With Quote
Old 05-17-2020, 11:21 PM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light
T4R2014's Avatar
The joys of DIYing.
Try to get it turning with a screwdriver and hammer.
Old 05-17-2020, 11:43 PM #4
T4topher's Avatar
T4topher's Avatar
Originally Posted by T4R2014 View Post
The joys of DIYing.
Iíve dealt with some stuck oil filters but this one for sure takes the cake.. lol.. tried that but I might try more tomorrow, itís in a super tight spot I need to Jack the truck up a bit higher to give myself more space to swing.
Might give the needle nose pliers a try. 99% sure I was going in the correct direction lol..
Old 05-17-2020, 11:53 PM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Yeah as others said, I'd try some locking needing nose pliers, inserting each one into one of those holes, preferably at opposite sides, then once locked well, pointing straight down, I'd put a screwdriver sideways thru the plies for turning leverage, turning counter clockwise (as one looks up at it).
Luck.
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 05-18-2020, 12:01 AM #6
FunBobby's Avatar
FunBobby FunBobby is offline
FunBobby is on a distinguished road
FunBobby's Avatar
Yikes, can you get a welder to it?
FunBobby is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 12:06 AM #7
T4topher's Avatar
T4topher's Avatar
Luck.
Good idea with the screw driver between the pliers, thank you.
Yea, was thinking about welding one of my spare 4runner cv axle nuts on there.
Old 05-18-2020, 01:21 AM #8
shazbot shazbot is offline
shazbot is on a distinguished road
shazbot is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 01:43 AM #9
spartacus's Avatar
spartacus is just really nice spartacus is just really nice spartacus is just really nice spartacus is just really nice
spartacus's Avatar
Use the holes with this.
Oil filter stuck-20200517_234731-jpg
Old 05-18-2020, 02:11 AM #10
FunBobby's Avatar
FunBobby's Avatar
This would what I would try if you can keep from burning thru the filter housing
Old 05-18-2020, 02:41 AM #11
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
if the above ideas dont work here is another one
some of those nipples are replaceable...come out of block...keep that in mind
so take a dremel with a cutting bit..can be a spiral cutting bit like used in wood or drywall....sure they make them for metal or a grinding stone or disc
start at one of the holes and work your way to the nipple...then with the grove cut into it, spread it apart and expand it around the nipple
if needed drill a couple of holes in a line and use that and cut between the holes to make a "crack " to split...if needed do it from two sides...like 6 and 12...or just a couple holes near the nipple not as far as the existing holes and try to expand the filter housing around the nipple
If you hit the threads with the dremel and bit you might be able to rethread it...or thread and weld a nut on and back it out and install a new nipple if replaceable but dont count on that .I would go for trying not to damage the nipple and clean the threads if damaged.
Also gravity should work with you but be prepared to suck out any shavings that might have wanted to travel in
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 05-18-2020, 08:40 AM #12
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough
Real Name: Patrick
I would try using a chisel and hammer on one of the filter holes to see if you can make it spin. Might have to use a cut off wheel to remove the rest of the mangled filter.
2000 Limited V6 Auto E-Locker
Old 05-18-2020, 10:24 AM #13
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough
TheDurk's Avatar
How about a bolt extractor into the pipe nipple that threads into the block? Seems to me it would grab pretty well......
It also might be worth driving an old Chinese screwdriver between the gasket and the block. Try not to screw up the mating surface. That's where it binds, so you could reduce the contact area by half on the near side. You might be able to break the seal on the far side with the right size bar and levering the flow hole away from the block. In any case, take a big drift punch and go around the outside edge and pound on the metal from the top. Might help to break that seal.
My Backyard Frame Swap
Old 05-18-2020, 10:46 AM #14
nissanh nissanh is offline
nissanh will become famous soon enough nissanh will become famous soon enough
Chisel and hammer method:
Place the chisel on one of those tiny holes and gently hammer it to loosen the filter. Try to hold the chisel parallel to the filter gasket surface to transmit the power to spin the filter.
Old 05-18-2020, 02:43 PM #15
T4topher's Avatar
T4topher's Avatar
Well guys thank you for all the suggestions. Tried needle nose pliers in the holes with a screw driver for leverage and tried banging on it with a hammer/screwdriver.. The thing that got it was the nipple extractor, the filter was in there extremely tight even after I got the nipple loose once it started unscrewing the top of the filter it got really tight.
Simple oil change turned into a 2 day multi hour process and almost lost the side of my finger. Picture doesnít do the cut justice, there was a lot of blood lol..
driver , filter , itís , oil , screw
Oil filter cap stuck DeadPool 5th gen T4Rs 42 06-29-2019 01:42 PM
Stuck oil filter.... Bucket81 3rd gen T4Rs 40 01-08-2018 09:24 PM
Cone washers stuck stuck stuck 4eigner 3rd gen T4Rs 14 04-03-2015 03:49 AM
Stuck fuel filter crash813 Classic T4Rs 1 05-26-2014 10:24 PM
Fuel Filter Stuck!, any Suggestions? WildMountainBoy Problems & Warranty Issues 1 03-24-2011 09:20 AM
