Old 05-18-2020, 01:08 PM #1
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
OEM eBay Valve Cover Gasket Kits
I need to replace my VCGs, and am looking at the OEM kits some eBay users put together. Anyone have any experience with these? Some of the prices seem too good to be true, but claim and photograph all OEM parts.
New Valve Cover Gasket Set Truck 4Runner Tundra Tacoma Fits Toyota 3.4L V6 OEM | eBay for $33
GENUINE OEM TOYOTA VALVE COVER WASHERS GASKETS SPARK PLUG TUBE SEALS 5VZFE NEW | eBay for $29
TOYOTA OEM KP Complete Valve Cover Gasket Set Made in Japan & PCV Valve - Cam | eBay for $52 w/ PCV
I see other kits for almost $100 more. Thoughts?
RumHam26 is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 01:46 PM #2
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
Here's a thread for you:
Valve cover gaskets replacement kit
Ishino Stone is the OEM for VC gaskets. The kit can be found online for around $60 or so.
Those eBay gaskets are definitely NOT OEM. Whether or not they are junk - who knows.
'96 Toyota 4Runner Limited 4x4
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 02:21 PM #3
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
I recently got these
TOYOTA OEM KP Complete Valve Cover Gasket Set + (2) Intake Plenum Made in Japan | eBay
Seemed pretty good. Comes with the plenum gaskets you will need. If you were to buy all OEM from Toyota it would be around $125-140. And that's online from Camelback or Conicelli
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 02:41 PM #4
Thank you - unfortunately I can't find the Ishino kit in stock anywhere. Any leads?
Old 05-18-2020, 02:42 PM #5
Thanks! I'll check that out
Old 05-18-2020, 02:57 PM #6
Maybe this is the "Ishino Stone" kit now just branded at Stone?
New Stone Engine Valve Cover Gasket Set JVS10420 Lexus Toyota
Old 05-18-2020, 03:08 PM #7
It says right in the listing, "Stone is a brand of Corteco Ishino Corporation"
Old 05-19-2020, 12:18 AM #8
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
I used the Ishino over a year ago from previous thread recommendations.
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 05-21-2020, 02:14 PM #9
I ended up going with this kit from Stone -
New Stone Engine Valve Cover Gasket Set JVS10420 Lexus Toyota | eBay
It seems to be the same Ishino Stone kit recommended above (and in other threads) that they used to sell on Amazon. Seems legit, made in Japan, all the right packaging etc. It came with the VC gaskets, the 16 washers, the 6 spark plug tube seals, 2 cam plugs, and the PCV grommet. Had to order plenum gaskets and PCV valve separately. Not bad for ~$60.
The Stone part # for the kit is JVS10420. Hope it all fits. Here's what showed up
Thanks for the suggestions!
OEM eBay Valve Cover Gasket Kits-img_20200521_124219321_2-jpg  OEM eBay Valve Cover Gasket Kits-img_20200521_124150621_3-jpg
Old 05-28-2020, 12:36 AM #10
johnpdfw@gmail.com johnpdfw@gmail.com is offline
johnpdfw@gmail.com is on a distinguished road
Advice on tracing a leak
Hey guys,
Was hoping for some advice in tracing a leak.
Local shop changed the oil and thought it was a tranny leak.
Im thinking its the Valve cover gasket, but im just a noob...
Any advice would be much appreciated.
2001 2wd 3.4l Limited
Photo's attached:
OEM eBay Valve Cover Gasket Kits-img_3114-jpg  OEM eBay Valve Cover Gasket Kits-img_3108-jpg  OEM eBay Valve Cover Gasket Kits-img_3111-jpg
johnpdfw@gmail.com is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 01:50 AM #11
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Yup sure looks like valve cover gasket change is in your immediate future. Sure looked like mine.
cashflow50 is offline   Reply With QuoteReply With Quote
claim , ebay , kits , oem , photograph
Valve Cover Gasket / Spark Plug Gasket Repacement Jeremy556 5th gen T4Rs 17 03-21-2020 08:43 PM
Fake valve cover gasket kit on eBay nissanh 3rd gen T4Rs 11 11-13-2019 03:50 PM
Valve Cover Gasket? mdominic 3rd gen T4Rs 4 04-08-2015 09:53 PM
Can the Valve Cover Gasket and Intake Gasket cause milk shake in the radiator? TheMikeOfMikeness 3rd gen T4Rs 18 07-04-2014 01:05 AM
valve cover gasket t4r4life 3rd gen T4Rs 10 01-08-2010 04:02 PM
