Old 05-18-2020, 07:04 PM #1
blairracd blairracd is offline
blairracd is on a distinguished road
Just put Eibach coils and Bilstein 5100s up front on my 1999....only got 1.25 of lif
Just put Eibach coils and Bilstein 5100s up front on my 1999....only got 1.25 of lift?
Do these take a little bit of driving to get them settled? I was expecting at least 2.
Im getting 285/75s tomorrow and now I feel like Im going to have an issue fitting them with only having got 1.25.
In the back I did OME 890 and Bilstein 5100 and got the full 3 on each side.
What gives?
Missing my 4runner...
blairracd is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 09:54 PM #2
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
What gives?
What clip did you put them on?
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 10:58 PM #3
Bottom clip, because coils are advertised as 2.5
Old 05-18-2020, 11:36 PM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
Things will likely settle (drop) a bit. The fronts are not going to get any taller. At least you can go up a notch if you want to.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo (tbd if can be resurrected)
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:34 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice
Real Name: Patrick
1999 stock front coil springs are 1" taller than other model years so that's fairly accurate. 2.5" advertised minus 1" for being a 99. Move it up a clip or two. When springs settle they only get shorter not longer. Also, a lift only helps clear larger tires at ride height. If you articulate your front suspension (flex) the suspension still follows the same arc as before you lifted the front.
2000 Limited V6 Auto E-Locker
Old 05-19-2020, 01:23 PM #6
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Measure from the center of the hub to the fender lip. "Stock" height is 20" - calculate your lift from that point. '99 4WD's start out around 21" from the factory (already 'lifted' 1").
'16 Honda Odyssey
1.25 , bilstein , front , im , put
Bilstein 5100s with eibach coils 4runnerAzGuy 4th Gen T4Rs 12 07-21-2020 09:28 AM
Bilstein 5100s and Wheelers/Eibach Coils? DaveSki 5th gen T4Rs 11 02-16-2020 10:11 AM
FS: 4th Gen Bilstein 5100s and front FJ coils, 2nd Gen Tacoma struts, $150 SoCal tony.d.bac For Sale: Suspension/Wheels/Tires 6 12-04-2017 03:29 PM
Bilstein 5100s with Eibach or TRD Tundra? atalarico 3rd gen T4Rs 23 08-17-2015 12:21 PM
Eibach/Toytec with Bilstein 5100s? bulger22 3rd gen T4Rs 9 04-29-2010 06:00 PM
