Old 05-19-2020, 11:04 PM #16
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Originally Posted by nissanh View Post
I stay with Johnson control batteries as they make batteries as good as Yuasa and panasonic in Japan
Walmart sells Everstart MaXX batteries amde by Johnson control and I get FULL 5 years + service for past 10 years on all of my Toyotas.
I have 24F batteries on the 4Runner and 2000 Land Cruiser.
They make almost every lead acid car battery. I think quality depends on your region and the label it is sold under. Costco sells them with the best warranty, but I went through three in a row. They all leaked. My charging system is working perfect too.
Old 05-20-2020, 01:01 AM #17
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
It’s AGM only for me. I’m too fussy to put up with gungy terminals and corroded hold down straps.
I’ve got a Deka agm as sold at low range off-road. I found that the same deka is sold at Canadian tire as a motomaster. 2 years and so far so good. Last motomaster agm (spiral grid) lasted 10 years.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:57 AM #18
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Odyssey PC 1500 34R. First one bought in July, 2013 when I acquired the vehicle. Just changed it out ofter 6.75 years as preventative maintenance. Old one still working fine, tests perfect. Stock electrical system. No special charging routine besides normal driving. I've run the stereo for hours while camping, but this is always followed by a long drive home. I like that there's no corrosion issue, and the vibration resistance is appreciated as I sometimes drive a long distance on very washboarded roads.
pluton is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 03:01 AM #19
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
Good ol' reliable Duralast Gold from Autozone for just daily driver duty. It wasn't $300 and I just forget about it under the hood.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 04:17 AM #20
If you buy a flooded battery that has the ability to check the water level you won’t have the nasty terminal corrosion.
I always coat my terminals in a conductive grease to keep them clean.
I’ve been using this stuff for all but 40 years as an Industrial Electrician.
Old 05-20-2020, 12:19 PM #21
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I’ve had good luck with interstate from Costco and ever start max from Walmart.
I’ve run a few Optima batteries. They did no better than standard batteries other than use in high vibration applications like boats. Even then they don’t impress.
2x the cost, but certainly not 2x the battery. Maybe a 15-20% improvement at best.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 06:35 PM #22
sugjavier sugjavier is offline
sugjavier will become famous soon enough
I have the Northstar 27F and it's treated me very good for the past 2 yrs I think
There's actually a group buy again for it
**Northstar Battery - Group Buy 10.0**
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 07:25 PM #23
That battery has some serious ass.
I almost bought two of those for my Cummins.
They are
930cca
195rc
92ah
But it’s 360-400 dollars. Compared to 120 for a MTP-27f which is
710cca
165rc
If I had the money to spend id buy that battery. I forgot I seen those at Cabela’s when they first opened in Hamburg, Pa.
Old 05-20-2020, 07:36 PM #24
T.Q.. T.Q.. is offline
T.Q.. is on a distinguished road
Battery
I used to only get my Diehard batteries from sears, now I get my batteries from Sam's club Duracell because of the great warranty. Last month I was 3 days away from the 36 months and got a brand new battery for free.
T.Q.. is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 09:51 PM #25
I really miss being able to get DieHards from Sears since it closed. That's the only battery I would buy for many years and never had a single bit of trouble.
Old 05-20-2020, 11:16 PM #26
They are
930cca
195rc
92ah
710cca
165rc
Yea dude I compared the stats vs the other ones and this one has the highest ratings:
Pulse cranking amps: 1750 A
CCA rating at -18°C (0°F): 930 A
CA/MCA rating at 0°C (32°F):1080 A
Reserve capacity: 195 min
Capacity - 20 hour rate (1.75 vpc): 92 Ah
Short circuit current 5000 A
Warranty 4 years full
I just pulled up my invoice and I only paid $263.99 for the Northstar AGM 24F battery for my 4Runner. I do remember with the group buy it was a really good deal and I bet I don't have to buy another battery lol.
I also bought the CTEK (56-353) Multi US 7002 12v battery charger from Amazon since I heard AGM batteries should be charged every now and then. Also cuz I'm only on Stock Alternator.
Last edited by sugjavier; 05-22-2020 at 10:11 PM. Reason: Actually it was 24F not 27F
Old 05-21-2020, 05:09 AM #27
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
Batteries Plus X2 for me in a group 31 size with this tray from CBI 3rd Gen Toyota 4Runner Battery Tray (Group 31) | 1995.5-2002 - CBI Offroad Fab
1150 CCA’s and 100AH.
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 05:47 AM #28
Yep, the 31 size is normally in a commercial truck
Old 05-21-2020, 05:32 PM #29
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I think the OP should have posted a budget lol. Obviously the sky's the limit for CCA's and amp hours but how much does he have to spend? I'm under the assumption he doesn't want to drop $400 on a battery.
326WHP 347TQ
Old 05-21-2020, 07:13 PM #30
Yea when I seen those north star 27s at cabela’s I blew a nut until I seen the price. I tried justifying it and couldn’t. So I bought megatron plus 27 interstates. They lasted 8 years. I replaced them this past winter. I kept 1 as a spare jump battery. It tests a 650cca yet.
batter , happy , jim , recommendations , time
**NoCo Batter Jump starters Group buy** ramonortiz55 Group Buys 298 05-09-2020 10:50 PM
time for new tires, recommendations? rockwind1 General Discussions 1 03-09-2020 12:57 PM
Time to replace my Duratracs, recommendations? Bigbriman 5th gen T4Rs 18 07-03-2017 07:55 AM
Auxiliary Batter? tbryanh 3rd gen T4Rs 8 10-29-2016 11:44 PM
batter and a/t temp light constantly on, low reading on voltmeter sb5500 Classic T4Rs 1 02-22-2011 10:13 PM
