Old 05-21-2020, 07:18 PM #31
cleanrunner's Avatar
cleanrunner cleanrunner is offline
cleanrunner is on a distinguished road
im on my 2nd Interstate in 10 years of owning my Runner. Ive had Interstates in many other cars prior with similar results.
Don't Text And Drive
cleanrunner is offline   Reply With QuoteReply With Quote
Old 05-22-2020, 02:30 PM #32
Here is my spare starter battery I kept from my 94 ram with the diesel. It’s marked that I bought it January of 2010. It still tests at 88% of its rated 750cca. My MidTronics tester tests it at 660cca. I used it last week to jump start my neighbors truck when his battery smoked to test his Alt output. Yea, a dead battery running at 14.5v and only pushing 1a into the battery. “It’s dead Jim.”
No barnacles on the posts and you can still see the remnants of the terminal grease.
Old 05-22-2020, 02:38 PM #33
Old 05-25-2020, 09:27 AM #34
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
Originally Posted by gamefreakgc View Post
I think the OP should have posted a budget lol. Obviously the sky's the limit for CCA's and amp hours but how much does he have to spend? I'm under the assumption he doesn't want to drop $400 on a battery.
You're right! I'd say my budget is around $200 or so but less is better. I think I'm just going to go with a flooded battery like I currently have in it.
I like the 31 adapter from CBI... any issues with a 31 series battery on an OEM alternator???
5-speed swap stuff available here!
https://www.toyota-4runner.org/for-s...isc-stuff.html
Silver Supra is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 10:56 AM #35
A 27f should fit it’s the same height as the 24 just longer.......I think.
Old 05-25-2020, 07:11 PM #36
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Correct, 24Fs are *usually 10" while the 27Fs are 12". Width and height are pretty close, 4th-gens use either depending on the engine.
Interstate Batteries | M-27F
*Here's what I mean by "usually", depending on what line there's a 3/4" difference in length, same group size.
Interstate Batteries | MT-24F
Interstate Batteries | MTP-24F
Old 05-25-2020, 07:27 PM #37
The MTP is the Plus battery. Higher ratings. I can see it being slightly bigger.
If the group 65 had an F reverse post option I’d buy that. It beats the 27 hands down and what Dodge went to for their group 65 batteries in their diesels because they had higher AH/RC rating.
I do not like buying a battery with less than 150rc.
Old 05-26-2020, 11:22 AM #38
The MTP-24F looks like a great option. Is anyone using this? Are the terminals reversed?
Thanks!
Old 05-26-2020, 01:07 PM #39
Thanks!
That is exactly what I have in my 97.
Old 05-26-2020, 01:24 PM #40
Just got back from my local Interstate distributor and put the MTP-24F in. Thanks for all the advice and input!
Old 05-26-2020, 03:05 PM #41
Time for a new battery - recommendations?
I thought there was an issue with my interstate until I found out the Fog Light harness was not assembled properly and was causing a large parasitic drain on the battery. Thanks to Durk I rewired the relay and all is well. I bought mine in June of 2017.
My next battery will be a 27f when this current battery craps out.
batter , happy , jim , recommendations , time
**NoCo Batter Jump starters Group buy** ramonortiz55 Group Buys 298 05-09-2020 10:50 PM
time for new tires, recommendations? rockwind1 General Discussions 1 03-09-2020 12:57 PM
Time to replace my Duratracs, recommendations? Bigbriman 5th gen T4Rs 18 07-03-2017 07:55 AM
Auxiliary Batter? tbryanh 3rd gen T4Rs 8 10-29-2016 11:44 PM
batter and a/t temp light constantly on, low reading on voltmeter sb5500 Classic T4Rs 1 02-22-2011 10:13 PM
