Originally Posted by SamSquantchT4R
I’ve got the factory 5 stars 16x7 and i am curious what size tire i can go with a little pounding and trimming without cutting out the wheel well as i have seen some doing.
Plan is 2.5 radflo/Sonoran steel lift kit + 1inch body lift. Hoping 305’s will fit...
Those that have the factory 5 stars with larger Tires please shed some light!
That’s no help bad luck. I know how to use google and the search function. I have been following threads here for years and follow many people on Instagram. What i have read is some people will tell you not to put 305’s on 16x7’s and some say it is perfectly safe. That aside, my original inquiry was to see if anyone has tried 305’s on stock 16x7’s successfully without rubbing after performing the standard massaging to fit larger tires. Most people with larger than 285’s have gone aftermarket on wheels.
Your original question was "i am curious what size tire i can go with a little pounding and trimming without cutting out the wheel well as i have seen some doing." You then mentioned you hoped 305's would fit and you have 5 star rims. If you want to know the answer to "if anyone has tried 305’s on stock 16x7’s successfully without rubbing after performing the standard massaging to fit larger tires" try phrasing that as a question. We can't read your mind.
Try these links from google then:
https://www.google.com/search?newwin...4dUDCAw&uact=5
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
