Old 05-19-2020, 02:57 PM #1
SamSquantchT4R SamSquantchT4R is offline
SamSquantchT4R is on a distinguished road
Factory five star tire width question
I’ve got the factory 5 stars 16x7 and i am curious what size tire i can go with a little pounding and trimming without cutting out the wheel well as i have seen some doing.
Plan is 2.5 radflo/Sonoran steel lift kit + 1inch body lift. Hoping 305’s will fit...
Those that have the factory 5 stars with larger Tires please shed some light!
SamSquantchT4R is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 03:44 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
https://www.google.com/search?newwin...4dUDCAw&uact=5
Old 05-19-2020, 10:19 PM #3
Originally Posted by Bad Luck View Post
That’s no help bad luck. I know how to use google and the search function. I have been following threads here for years and follow many people on Instagram. What i have read is some people will tell you not to put 305’s on 16x7’s and some say it is perfectly safe. That aside, my original inquiry was to see if anyone has tried 305’s on stock 16x7’s successfully without rubbing after performing the standard massaging to fit larger tires. Most people with larger than 285’s have gone aftermarket on wheels.
Old 05-19-2020, 10:54 PM #4
Big-B1975 Big-B1975 is offline
Big-B1975 is on a distinguished road
You need to look at the tire manufacturers rim size recommendations for the tire you want, because one companies 305 isn’t the same as another company’s 305.
Big-B1975 is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 10:50 AM #5
Real Name: Patrick
Real Name: Patrick
Your original question was "i am curious what size tire i can go with a little pounding and trimming without cutting out the wheel well as i have seen some doing." You then mentioned you hoped 305's would fit and you have 5 star rims. If you want to know the answer to "if anyone has tried 305’s on stock 16x7’s successfully without rubbing after performing the standard massaging to fit larger tires" try phrasing that as a question. We can't read your mind.
Try these links from google then: https://www.google.com/search?newwin...4dUDCAw&uact=5
Old 05-20-2020, 06:20 PM #6
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
a 305 mm cross section is just about 12". That's a bit too wide for a 7" wheel, at least by the way I was taught. The rule of thumb ( was, at least) tread width of 2"-4" wider than the wheel. At 5" wider than the wheel, I think you'll get really ballooned out sidewalls.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
factory , kit , lift , stars , tire
Tire width mikekapelus 4th Gen T4Rs 4 11-09-2015 10:02 PM
Tire Width or Height PhdNPrerunners Engines / Suspension / Wheels / Tires / Audio / Accessories 7 07-27-2012 06:24 PM
Best overall offroad tire width Jester4kicks Off-Roading 20 10-09-2011 09:42 PM
tire width Run'n'Gun Off-Roading 0 07-26-2007 07:04 PM
20's-22's Rim width/Tire selection question? The Razor Engines / Suspension / Wheels / Tires / Audio / Accessories 9 03-16-2005 07:43 PM
