Originally Posted by gamefreakgc
If you don't have a torque wrench (good tool to start with though) tighten the idler pulley so that the tension of the A/C belt matches the power steering and alternator belts. Press on a floating section of the belt with your hand then on the A/C belt. If too tight, loosen the bolt a little, if too loose, tighten the bolt.
Thanks for the tip!
It looks to me like the dust cover (thing that site between the pulley and the nut) may not be necessary at all for the non-OEM pulley I bought. In fact, the dust cover may be pressing into part of the pulley that is supposed to turn when I tighten the nut. I'll try removing it, torquing the nut and seeing how that goes.
