Old 05-19-2020, 07:38 PM #1
uogecko uogecko is offline
uogecko is an unknown quantity at this point
a/c idler pulley replacement question
Hey there! I saw a recent thread about this topic but it didn't answer my specific question.
I have a 1997 SR5. This is the most tinkering I've ever done with the engine and so I'm for sure a noob!
I loosened the bolt that applies tension to the belt and pulley and removed the pulley. I purchased a new pulley and went to replace it today.
I slid the pulley onto the bolt that it rides on, then slid a dish-shaped washer thing onto it, and then put the nut on. There were no other parts.
My question is:
1) how hard should I torque the nut on (won't it keep the pulley from turning if I make it too tight)?
and
2) how much tension should I put on the belt?
I took a guess at each and I hear a slight squeak when the engine is on.
Thoughts?
Thanks!
uogecko is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:09 PM #2
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
One question - did you buy an OEM pulley or aftermarket? The aftermarket one I purchased, Dayco I believe from RockAuto, did not fit correctly, and is now in the trash. I then went to the dealer and purchased an OEM - the mounting surface was different and did not allow free spin.
2000 4Runner Sport - TRD&AEM SuperCharged
SoloLT & KING 2.5 adj-resi & bumps, 4th gen w/ disc brake rear axle & KING 2.5 adj-resi 12's
F+R ARB's & OBA, 4.88 Yukon's, STT Pro, Shrockworks Front, Homemade Rear, BudBuilt-Lil Skip-Lotus Skids & 4xI Sliders
Post Long Travel Sale!!! CVs and a sway bar https://www.toyota-4runner.org/for-s...-arms-etc.html
rideexileex is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:16 PM #3
Skulking Skulking is offline
Skulking is on a distinguished road
I've not done it myself, but you might find this video helpful. It covers all of the drive belts including the AC belt.
Skulking is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:24 PM #4
Thanks - the pulley is not OEM. I got it from Oreilleys
Old 05-19-2020, 08:37 PM #5
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt will become famous soon enough
jbtvt's Avatar
Can't recall that pulley specifically, but typically the washer rides on bearing inner race and pulley will spin free with bolt tight. Google "torque values metric" if you want an exact torque value, or look in FSM, but not critical here. Lube up that adjusting bolt while you're down there if you're in the salt belt.
'85 4Runner, 22re 5spd, built trailer queen; '90 4Runner, 5spd, 3.4 swap
'98 GS400 V8 1uz; '07 GX470 V8 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 09:22 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
This video will help you out. You torque the AC Idler pulley nut to 29 foot pounds.
Old 05-20-2020, 01:16 PM #7
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all
Real Name: Jerod
If you don't have a torque wrench (good tool to start with though) tighten the idler pulley so that the tension of the A/C belt matches the power steering and alternator belts. Press on a floating section of the belt with your hand then on the A/C belt. If too tight, loosen the bolt a little, if too loose, tighten the bolt.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 05-20-2020, 01:28 PM #8
Super helpful, thank you!
Old 05-20-2020, 01:29 PM #9
Thanks for the tip!
It looks to me like the dust cover (thing that site between the pulley and the nut) may not be necessary at all for the non-OEM pulley I bought. In fact, the dust cover may be pressing into part of the pulley that is supposed to turn when I tighten the nut. I'll try removing it, torquing the nut and seeing how that goes.
belt , bolt , engine , pulley , question
No. 1 idler pulley replacement h1p 5th gen T4Rs 3 02-26-2019 03:23 PM
Idler Pulley and Belt Tensioner Replacement Bearing Sizes tjhaf2007 4th Gen T4Rs 29 12-16-2018 04:59 PM
Idler pulley replacement. Smobien 4th Gen T4Rs 23 12-14-2018 04:11 PM
Idler pulley (bearing replacement) in '96 3RZ-FE? fazeka 3rd gen T4Rs 1 03-17-2012 04:23 PM
a/c idler pulley question godzilla 3rd gen T4Rs 0 08-01-2010 10:54 PM
