Old 05-21-2020, 12:36 AM #1
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
Can I drive with the rear drive shaft off and center diff locked?
I've been fighting a vibration for a while now. From 1-10 (10 being a death wobble), it used to be a 6 and after replacing a bunch of parts (UCAs, LCAs, UBJs, LBJs, inner and outer tie rods, steering rack bushings, steering shaft, road force wheel balance, ECGS bushing), I got it down to a 1. It's a very slight vibration now when going 60+ mph. Doesn't matter if I'm on the gas or off, it's still there.
Now I'm thinking of replacing the u joints but after checking them out, the drive shaft feels nice and tight. I figure that if I remove the rear drive shaft and lock the center diff, I can see if it still vibrates. If it doesn't, then I know the rear drive shaft needs either a balance, u joint, cardan or all of the above.
Has anyone driven without the rear shaft before? Seems like it'll work but I don't want to mess it up in any way.
SeaBassHWD is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 01:23 AM #2
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
I don’t think there’s any harm in trying that. I wouldn’t put a huge load on your driveline as your front diff isn’t designed to take the full load of the vehicle, I think if you take it easy it’ll be fine. You might get some speedo/abs issues with it off but that’s probably it.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 03:07 AM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Many folks who’ve broke u-joints and other rear drive parts have drove home in front wheel drive.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 10:54 AM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
No problem at all.
Mark the drive shaft yokes before you remove it so you can re-install it the same way.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
balance , drive , rear , shaft , steering
Changed rear diff fluid and greased drive line, now trans runs hot Skunkworks 3rd gen T4Rs 11 06-20-2019 04:20 PM
VSC Stayed on with center diff locked when i got stuck Dirtrider216 4th Gen T4Rs 7 02-21-2018 03:03 PM
No VSC OFF light when center diff locked rjb75 4th Gen T4Rs 4 06-27-2015 12:11 PM
drive shaft, rear diff or tranny causing vibration? Will I Am T4R 3rd gen T4Rs 4 01-10-2012 06:32 PM
Locked the Center Diff on accident.... jeremysoca 4th Gen T4Rs 7 09-18-2007 09:20 PM
