Old 05-21-2020, 10:41 AM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
How many computer modules does the 3rd gen 4Runner have?
Today’s cars are rolling laptops. Some have dozens of computer modules, monitoring and adjusting every aspect of the vehicle. My question is how many computer modules does a third gen 4Runner have? I know there’s an ECU behind the glovebox. Are there any others? My 4Runner came equipped with Securikey+. That module is bolted underneath the dash, bolted to the left of the steering column.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 12:36 PM #2
camryn.samples's Avatar
camryn.samples camryn.samples is offline
camryn.samples is on a distinguished road
There are 2 that I know of one behind the glove box which is the main ECU and the one under the driver seat.
camryn.samples is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 01:09 PM #3
'99+ has at least the following (also depends on trim, let's do a Limited for max effect):
- Engine ECU
- ABS computer
- 4WD computer
- Integration relay (interior fuse box)
- Rear door ECU
- Cruise control computer
- Auto AC control
- Gauge cluster
And probably a few others. '01/'02 adds the VSC/TRAC computer...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-21-2020, 01:11 PM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Depends what you want to call a computer I guess.
ECM, ABS, 4WD, Rear Locker, rear hatch module, maybe more? Cabin air control?
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 01:30 PM #5
I tried to find a diagram but I couldn’t find a decent one.
Old 05-21-2020, 01:35 PM #6
spartacus's Avatar
spartacus's Avatar
ecm behind the glove box
then a bunch of ecu's
drivers side box has the ign, vsc, skid control (2001-2002) and the body ecus
back door ecu
4x4 ecu
shift lock control ecu
sunroof ecu
these are the ones I can think off.
Old 05-21-2020, 04:16 PM #7
Satter's Avatar
Satter's Avatar
Oh yeah! I wonder what that does?
Old 05-21-2020, 04:48 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The earlier years 96 thru 98 have less modules then the latter. With 99 and 00 being transition years. The wiring harnesses also change in 1999 so they are almost identical in 1996 thru 1998 with a few feature enhancements like the E locker in the Limited etc. The 02 has the most circuits thus the most body electrical control units. So be very careful to match them up properly when replacing defecting ones. Mostly the Toyota Engineers change the plugs to prevent people from baking them but when sourcing for parts its better to be comparing apples to apples and not apples to grapes if you catch my drift. :-)
Hope the other users and this helps answer your question. :-)
Old 05-22-2020, 12:34 AM #9
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
they have too many
4runner , bolted , computer , gen , modules
One Touch express window modules dccgrillz 4th Gen T4Rs 15 03-30-2018 06:06 PM
Window control modules ryderaluce 3rd gen T4Rs 2 06-01-2015 02:11 PM
Viper Alarm window modules-Austin Area cminh25 4th Gen T4Rs 3 03-12-2015 07:32 PM
any 01-02 guys replace their skid control modules yet? xspsi6 3rd gen T4Rs 7 02-22-2014 04:05 AM
Directed DEI 555XW Remote Start Modules? Jay Nice 4th Gen T4Rs 1 11-25-2012 07:16 PM
