Old 05-23-2020, 05:00 PM #1
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
New suspension installed yesterday - grease spurting from inner axle boots
I noticed this after I picked up the rig yesterday. Did a full wipe-down today under there and within 5 miles a fresh batch of grayish-tan grease is all over the suspension components. Did they forget clamps on the outer ends of the inner boots? Is it due to stress (mild 2" Billy 5100/881 lift)?
Edit - looks like they totally forgot the CV boot clamps -D'OH.!! I have 2 choices with what I have at hand: super burly zip ties or standard hose clamps. What do you recommend?
The shop not open weekends....
Old 05-23-2020, 05:33 PM #2
Real Name: Blair
Real Name: Blair
Edit #2 of this one-man clown show. So, there are boot clamps installed - just hard to see. I read somewhere else that this is not at all uncommon and will resolve itself after a while. Hopefully enough grease remains. What is weird is that I haven't even used the front drive axles yes. Will go for a spin in 4H and see what happens. I should probably just delete this post and stop embarrassing myself, but it may help another Joey down the line...
Old 05-23-2020, 05:57 PM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Front axle spin if the tire spins unless you have locking hubs.
The higher operating angle tends to cause your issue.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 06:36 PM #4
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
metal ties are the best but zip ties will do for a quick fix, the same thing happens to many 3rd gen guys when they install a mild lift, myself included with the same exact kit, what happens is your angle has been increased so your boots on the outside will hold less grease by nature. Because of this you will lose some grease but ive had my lift for almost 8 months and I havent had an axle go yet or give any symptoms of failure. I am also running larger 33 inch tires in addition to my lift which were installed on the same day so even with that in mind my axles are still running strong.
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 08:09 PM #5
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
Yeah its a typical issue with the front axles being at a higher angle. You can try to stretch the boot out somewhat and tighten the clamps down. I ended up buying some worm clamps from mcmcaster carr that are smooth on the inside so it doesn't tear up the rubber as you tighten them down. I've repacked and replaces my inner rubber boots twice. So far the aftermarket rubber boots are doing pretty good! Good luck.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 10:02 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Ive noticed some do a diff drop even with a 2" lift. Even Sorren Steel 2 inch lift kit includes diff drop pucks and bolts.
Curious as I have a 2 inch lift in the plans
Old 05-23-2020, 10:12 PM #7
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I have a 1.5 inch spacer lift and run a diff-drop. I haven't seen anything negative about running it, so having the peace of mind that the CV angles were close to stock as possible was worth the little bit of added cost.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 11:51 PM #8
Real Name: Blair
Real Name: Blair
Thanks for the feedback, guys. This symptom should be added to a 3rd Gen lift sticky somewhere. I'll just monitor it now that I know it's not all that unusual. Maybe I'll do aftermarket boots and a diff drop at some point. I had done a skid-plates-off engine, diff, and suspension clean-up before I took it to the shop and even hit key bolts with a little PB. it was just a little shocking to see the grease all over when admiring the new parts! Took her out and went through all the 4X4 modes for about an hour and it didn't spew any more grease that it already had from what I could tell. Cheers
Old 06-01-2020, 08:07 PM #9
Real Name: Blair
Real Name: Blair
Update - the grease issue vanished after a couple hundred miles. I cheaped-out and didn't get an alignment (mistake) because I thought I was going to get some tires real soon (bank account non-compliant). There were a couple clunks at near-lock, a lack of a sure-footedness and visually it looked off (caster/camber). Anyway i found a Big-O Tires Groupon for $100 of alignment work for $50. A 4-wheel alignment is $100 out the door at that place. Thing is rock-solid now, no clunks, all good. Recommended! Later in the day installed a Spiker hood strut kit. Making progress.......
So far:
New valve cover gaskets, plugs, and wires
New OEM UBJs and LBJs.
New gear oil throughout.
5100s and OME springs all around.
Magnaflow muffler
New Maxpower (? - The ones made in Carlsbad CA) hatch struts and Spiker hood struts mod.
Need:
Tires
Radiator
Battery
Taking a road trip to Bend OR and through the Cascades/Mt Hood in July.
Old 06-02-2020, 06:18 PM #10
D_T_F D_T_F is offline
D_T_F is on a distinguished road
Many thanks for the post. I am about to lift and this gives a bit to watch for once done.
D_T_F is offline   Reply With QuoteReply With Quote
boots , clamps , grease , suspension , yesterday
New CV Axle or New Boots? smooth boar 3rd gen T4Rs 2 04-18-2019 06:52 PM
CV Boots- Adding grease and changing clamps BPo001 4th Gen T4Rs 9 07-05-2013 12:21 PM
Installed Cooper LTZ's (yesterday) StevieT4R Engines / Suspension / Wheels / Tires / Audio / Accessories 7 02-24-2011 05:00 PM
New Daystar 2.5/1.5 installed yesterday Rover+Runner 4th Gen T4Rs 24 09-26-2009 09:26 AM
Axle boots leaking grease through the clamp! msanta Problems & Warranty Issues 1 03-15-2009 09:44 AM
