10-14-2022, 03:02 PM
#1546
Real Name: C8H18 Mike
Originally Posted by connorms
Kind of a stupid question, but I'm planning on setting up an auxiliary fuse panel in my engine bay soon, and am in the process of planning everything out right now. I have the Big 3 mod done, and I'm mainly looking to clean up all of my wiring and have some questions about circuit breakers. I was talking about my plans for it with a coworker and he brought up some points that make sense to me, but I don't know enough about electrical to know if it's a good idea or not.
So I was planning on using this fuse block that has two separate circuits, and I was going to set it up with one having constant power and one having switched. If I went this route, I was planning on running each power wire through a 50A circuit breaker, since the fuse panel is rated for 100A. Then I'd need a 120A circuit breaker for my power cable between my alternator and battery, and another for my amp/subwoofer setup. I didn't really want to have to run 4 different circuit breakers, especially when space is tight already, so I guess this is where my question comes in. My coworker said that I don't have to run a circuit breaker between my battery and my fuse panel, as long as the fuses in the panel don't allow the total draw to be over 100A. He said if I use 2 or 4ga wire for the main power wire, which according to 12voltguy's chart, either should easily be able to carry 100A without getting melty (or could I go even smaller if I'm running 50A to each circuit?). This makes sense to me since any connection drawing power would be fused anyways, and as long as I'm careful with it to not exceed 100A total it makes sense that the cable wouldn't fry. But like I said earlier, I don't know electrical stuff well enough to know if that makes sense, so any advice is appreciated!
A self resetting circuit breaker inline wouldn't suck. Calculate the gauge cable to feed the block based on amps * distance, either 8 ga or 4 ga, most likely if contained within the engine bay.
That fuse block is a single circuit, btw
Also, if any of the circuits you are going to create need relays, like lights, amps or subwoofers, you might want to consider fused relay blocks, like this Nilight 6 Gang Switch Panel Car Circuit Control Relay System with Fuse and Wiring Harness https://a.co/d/cfP1KD7
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
10-14-2022, 03:22 PM
#1547
Real Name: Patrick
Real Name: Patrick
Originally Posted by BretMann
Although I've participated in forums for years, I just joined this one and am already lost. I just want to post a new thread to ask a question but I tried the new thread button and it says I can't. I'm allowed to reply though, I think. Odd.
How do I post my question regarding my 3rd gen 4Runner?
Thanks.
Ask it here. That's the purpose of this thread. You can't start a new thread until you have 15 posts or somewhere around there, but please don't spam threads to get your post count up.
10-14-2022, 03:59 PM
#1548
Thanks.
There's a post requirement before you make a new thread to prevent spam & people making a ton of threads asking the same question. I think it's something like 10 or 15 posts. There's a thread for new members so you can always post some replies on there until you reach the requirements. I had to go through the same thing and it's kind of annoying to do but it seems to help a lot against spam
Long travel '97 Limited - build thread
10-14-2022, 04:28 PM
#1549
Oops haha posted the wrong one. I meant to link this one, which from what I can tell it looks like it's got 6 fuses on each circuit. But do you think it's worth taking the extra safety measure of having the circuit breaker? I figured (as long as I have the correct gauge wire) if I put it in it would just take up unnecessary space and complicate things further, especially if I have it set up to where individual fuses would start blowing before it gets close to 100A? I'd much rather deal with a cluttered fuse panel than an electrical fire, but also if it's completely redundant I would rather save the money and space. Also good idea with that relay kit, looks like a great deal
10-14-2022, 06:11 PM
#1550
Originally Posted by Bad Luck
Autozone suggested repairs are the only thing more worthless at fixing a vehicle than the autozone employees themselves. P0451 code is either a problem with the vapor pressure sensor or the wiring for the vapor pressure sensor. In extremely rare cases it could be the ecm as well but very rare cases.
Like I said, I tested the wiring harness and it was in acceptable ranges - went ahead and grabbed a new OEM sensor off ebay for about $85.
2001 SR5 Glacier Metallic ~265k - OME 883 & 891 // Bilstein 5100s // 3rd gen Tacoma Off-Road 16" wheels // BFGoodrich A/T KO2 265/75R16
2023 Tacoma TRD Off Road Double Cab LB
10-15-2022, 09:02 AM
#1551
Thanks badluck & connorms. I get it but 15 times seems a bit much. I wasted a lot of time hunting around for an answer until thought to just ask within a random post. Maybe I missed it but I don't remember seeing a "Welcome" statement mentioning new members have to do that, so I think it would be good to add one.
Well, I guess I could just yabber away here or try to post some helpful replies to other questions - I guess they all count towards the required 15 anyway.
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (W59)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
10-15-2022, 12:53 PM
#1552
For all new members, you can say hi here, please dont litter other threadsa
10-15-2022, 10:00 PM
#1553
Real Name: Patrick
Real Name: Patrick
Or you could just ask it here…
10-15-2022, 10:37 PM
#1554
Real Name: Devan
Real Name: Devan
Anyone use Dobinsons 675v and can compare them to the 210v coils? Debating switching it up next year. Some say they're shorter, some say they're the same, some retailers will give two different measurements...
10-17-2022, 01:24 PM
#1555
I understand the problem with spam, however it does impede those with legitimate questions.
Not to spam, but I hope someone could help me with this question that I previously posted regarding ignition coil wiring harness connector boots.
Thanks to everyone!
10-17-2022, 03:16 PM
#1556
Real Name: Patrick
Real Name: Patrick
Thanks to everyone!
We will need to know the year and engine of your 4Runner to help
10-17-2022, 03:38 PM
#1557
Thanks to everyone!
I'd put your full question again along with your model year and engine. It may also be helpful to post a picture as I am struggling to understand what exactly you are trying to find.
10-17-2022, 04:23 PM
#1558
I hope someone could help me out with this problem.
Startup/running is rough for the first few minutes when there is significant humidity/fog,
This indicates moisture is impacting the connections/ignition.
I sprayed the ignition coil connectors (wiring harness side) and the coil connectors (ignition coil side) with electrical contact cleaner and it fixes the problem for a month, then the problem returns.
The problem is that the ignition coil connector (wiring harness side) has cracks in the soft rubberized connector part (that keeps out moisture) - this needs to be replaced and I cannot locate the part number in my reference material.
Anyone have the part number for the replacement connector or have an alternative option for replacement?
Thanks again everyone!
10-18-2022, 08:46 AM
#1559
Fair enough
Startup/running is rough for the first few minutes when there is significant humidity/fog; this indicates moisture is impacting the connections/ignition.
Anyone have the part number for the replacement connectors or have an alternative option for replacement?
1997 4Runner SR5 4WD Automatic 3.4L
10-18-2022, 08:54 AM
#1560
Real Name: Patrick
Real Name: Patrick
Fair enough
I don't have an EWD for a 97 and the connectors are different from my 2000. What about filling the connector with silicone where the weather seal is?
