Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 10-30-2020, 03:46 PM #151
spartacus's Avatar
spartacus's Avatar
Originally Posted by Dial4toRun View Post
is this where I can post my dumb questions, coo, just bought a 3rd and when I gas it while at high RPM's I hear an extremely loud whistling. which sounds like it is coming from middle bottom......nope not a turbo!
Could be a simple vacuum leak and you should be able to duplicate it, by reving the engine at high rpms and listening. If it only happens while moving it could be differential front or rear, drain the diff fluid and look for metal. Replace the fluid to see if it helps.
Old 10-31-2020, 10:46 AM #152
HiLife HiLife is offline
I experienced that same whistle/screem at high rpm. Mines ended up being bad alternator bearings. Swaped out alt fixed my issue.
Old 10-31-2020, 05:37 PM #153
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Is it possible to move/twist the steering knuckle so it's less likely to collide with the springs, or is my only hope to take off the strut and rearrange the coil?
Or are there better aftermarket knuckles?
Old 10-31-2020, 06:25 PM #154
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Cylceandsurf that frame has been terribly welded and patched, look at the weld on the rear control support to frame, a blind man could weld better, run from that vehicle it's finished IMO.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 06:22 PM #155
Dial4toRun Dial4toRun is offline
Real Name: AJ
Dial4toRun is on a distinguished road
Real Name: AJ
oh ok, will do this today, thanks
Dial4toRun is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 03:01 AM #156
Doc3g Doc3g is offline
Doc3g will become famous soon enough
This is probably a stupid wiring question but here goes. I know that on the rear of the truck I plan on mounting a few things that will require power (extra backup lights, a set of rear work lights, and a set of hazard flasher lights for sure). So, instead of running a bunch of single wires along the length of the truck, I figured I would run two main cable runs. The first would be a decently heavy gauge black wire from the battery, which could then be tapped into for power. Then I would also run a jacketed wire with 4 individual wires inside (something like this Amazon.com: 250FT Outdoor UV Protection Rated Professional Speaker Audio Cable 14AWG Direct Burial 14/4 Bulk Spool (250FT, 14/4): Electronics) that I would run to my switch panel inside the cab. Am I missing something or is this viable?
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 09:57 AM #157
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I'm assuming you are using relays at the rear main power/ground to control it? Otherwise you would still be flowing the full current through the switch and it would be pointless to run a main power and ground to the rear.
Old 11-02-2020, 09:58 AM #158
Real Name: Patrick
Real Name: Patrick
Your knuckle is hitting the springs or the upper control arm? It's rare for the knuckle to hit the spring, but the only real solution is rotating the spring assembly.
Old 11-02-2020, 10:45 AM #159
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Yes, on the spring, at full droop, can take a pic later if you want. It's to my understanding with the TRD lift the springs should be orientated in a way to prevent this (something I didnt know when installing them), I was just curious if there was a fix without breaking the strut down again. Not that big a deal, not long ago we got a coilover machine at my work I've been wanting to use
Old 11-02-2020, 10:47 AM #160
Real Name: Patrick
Real Name: Patrick
Most people hit the upper control arm with the spring, but the couple I read that hit the knuckle rotated the spring and that fixed the problem for them. One guy took a couple tries if I remember correctly.
Old 11-02-2020, 06:28 PM #161
Right, like a relay box in the back with room for 4-6 relays or something like that, just so that if you are going to go through the trouble of routing cables, you only do it once, and then if you decide to add something else to the back of the truck, you just throw in another relay and wire up your accessory.
99' SR5 HRU
Old 11-02-2020, 06:40 PM #162
Real Name: Patrick
Real Name: Patrick
That makes sense to me. I don't see why it wouldn't work and that's a good way to do it if you have several things in the rear to power and control in my opinion. Good idea!
Old 11-02-2020, 07:39 PM #163
Here's sort of a mockup of what I was thinking but in the real scenario there would be something like a 6 slot relay bank in the bank (several things I have planned already, plus room for future expansion).
99' SR5 HRU
Old 11-03-2020, 11:34 AM #164
Real Name: Patrick
Real Name: Patrick
Photo isn't working for me
Old 11-03-2020, 01:04 PM #165
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Sounds like a good plan, same as wiring a sound amp. Size main fuse for wire size, size branch fuses for each load.
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
