Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Old 11-25-2022, 12:55 PM #1711
Boom_ROASTED Boom_ROASTED is online now
Boom_ROASTED is on a distinguished road
Nope not rotten eggs. Maybe more like the smell of metal polish in a way. You can't breathe too much of it or you feel like you're damaging your lungs (at least that's how it makes me feel) or best case scenario get high.
Thank you for all the responses.
Some googling leads me to believe it could be fuel filter related so I'm going to replace that asap. No matter what I'm sure it needs to be replaced.
Boom_ROASTED is online now   Reply With QuoteReply With Quote
Old 11-25-2022, 12:58 PM #1712
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Lots of options: 2000 4runner speaker isntall - Google Search
jrm is offline   Reply With QuoteReply With Quote
Old 11-25-2022, 08:14 PM #1713
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by Manifestdestiny View Post
I've been searching youtube and this forum and can't seem to find a good guide on how to install new speakers in the front. I had a nice new head unit installed by a shop years ago but speakers are dying on me. Are there any recent posts on how to most easily install new speakers? thanks for yalls help!
I'm ready to pull trigger on this pair of 5.5 inch mid-range speakers, leaving the factory crossover and tweeters in place:
DS18 PRO-X5.4BM Loudspeaker - 5.25", Midrange, Red Aluminum Bullet, 300W Max, 150W RMS, 4 Ohms - Premium Quality Audio Door Speakers for Car or Truck Stereo Sound System (1 Speaker) https://a.co/d/fpb8Gf1
My factory speakers are actually still in good shape, I'm not in a rush to replace them, yet..
That being said, I also installed an 8-in subwoofer under the driver seat:
Recoil SL1708 240 Watt 8" Under-Seat Slim Amplified Car Subwoofer with 99.99% Oxygen Free Copper Installation Wiring Kits https://a.co/d/6jlZ3Rk
The sub really rounds out the bottom end, and my Pioneer Bt4200 has a loudness feature that almost obviates the need for a subwoofer.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 02:04 PM #1714
Trent4r's Avatar
Trent4r Trent4r is offline
Real Name: Trent M
Trent4r is on a distinguished road
Trent4r's Avatar
Real Name: Trent M
Hey everybody, just bought a 2000 T4R Limited and am excited to join the community. Have only done a few minor things so far: new nokian outpost tires (road force balance was NEEDED and made a huge difference with shaking at higher speeds), replacing rear hood struts as soon as they come in, and will be doing front brakes and rotors with akebono pads and centric rotors.
No big plans for it yet, but feel free to send any tips for upgrades that made a huge improvement over stock. Only has 109k miles with mint factory paint and I'm amped to see where it takes me.
2000 4Runner Limited 2WD
Trent4r is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 06:26 PM #1715
Bad Luck Bad Luck is online now
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Welcome to the forum. The two biggest failure points are the transmission cooler located in the radiator and the lower ball joints. When either of those fail it gets very expensive.
If your radiator plastic is brown or the coolant looks gross then I would suggest replacing your radiator and radiator cap. Generally recommended service interval for an OEM/Denso radiator is 10 years/100k miles. When the transmission cooler in the radiator fails it causes coolant to get into your transmission and ruins the transmission unless caught very quickly.
If you don't know when the lower ball joints were replaced (if they have been replaced) then I would recommend replacing the lower ball joints and lower ball joint bolts with OEM only. To accurately check your lower ball joints for wear is a whole procedure and requires a dial indicator. It's easier just to err on the side of caution and replace them if they are old or unknown. Generally recommended service interval is 10 years/100k miles. When a lower ball joint failure happens it gets very ugly and dangerous very quickly. site:toyota-4Runner.org/3rd-gen-t4rs/ lower ball joint failure - Google Search
Timing belt should also be checked/replaced around 100k miles. You can pull the 10mm bolts out of the upper timing cover to look at your timing belt condition. If it's cracked then it's time for a replacement timing belt/bearings/water pump/thermostat.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 11-29-2022, 07:34 PM #1716
Trent4r's Avatar
Real Name: Trent M
Trent4r's Avatar
Real Name: Trent M
Thank you! Will definitely look into both of those as well. Going to do most of the work myself, but found McGeorge Toyota has a lot of good deals on OEM parts.
Old 11-29-2022, 08:25 PM #1717
alanz alanz is offline
alanz is on a distinguished road
I just purchased a 1997 4runner and the previous owner replaced the trans with a used one and the trans did not shift. the gear will not engage at all. I open the pan and the #1 solenoid was not functioning after testing. I replaced and stile not engaging. what els can it be? please help.
alanz is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 08:28 PM #1718
transition not engaging
Old 11-29-2022, 09:09 PM #1719
I love 4runners I love 4runners is offline
I love 4runners is on a distinguished road
My new 4 runner restoration
I am restoring a 1996 toyota 4 runner limited 4wd and I want to put a front bumper on it but I don't want it to be a full bumper just a half bumper with a winch mount. This is my first car and I just turned 14 and I don't really know what to do.
I love 4runners is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 10:10 PM #1720
Do your research, take your time, look up Amped Up fabrication
Old 11-30-2022, 12:27 AM #1721
Real Name: Patrick
Real Name: Patrick
Check amayama.com, partsouq.com, and parts.Toyota.com as well for pricing. Amayama and partsouq are overseas so shipping takes longer but they usually are cheaper even with shipping in my experience.
Old 11-30-2022, 11:14 AM #1722
Trent4r's Avatar
Real Name: Trent M
Trent4r's Avatar
Real Name: Trent M
Does anyone know what could cause it to not start as strong when doing a warm start? Cold start it fires up and sounds strong, but after getting to temp and letting sit for a few minutes and restarting it doesn't start as strong. Takes about the same amount of time to start and doesn't require multiple tries or anything, just kind of stutters a little bit but runs just fine after. Fuel pump issue?
My old 2000 tacoma did the same thing but never looked into it.
Old 11-30-2022, 11:20 AM #1723
Trent4r's Avatar
Real Name: Trent M
Trent4r's Avatar
Real Name: Trent M
Perfect. Will check those as well. Thank you.
Old 11-30-2022, 01:09 PM #1724
jrm's Avatar
jrm jrm is offline
jrm jrm is offline
jrm's Avatar
2000 4runner - Sony WX 920 BT - Complete Harness?
I purchased the Sony HU from crutchfield, and it included an metra adapter harness with instructions. Installation involved splicing 14 wires between the 16 pin sony connector and the two toyota connectors. I did the best i could to forge a good connection but it just looks kinda jury rigged and half assed.
So im thinking i might try either making my own harness and copy the pin assignments OR just buy a plug and play complete and be done with it. So i want to ask if anyones made there own harness OR found a 2000 4runner sony HU compatible harness> Im looking at these but not sure if it will work or not: Amazon.com: Sony Aftermarket Radio Install kit (Compatible with Toyota and Subaru) - Direct Wiring Harness for aftermarket Stereo Compatible with 4runner, Sienna, Tacoma, Tundra, BRZ, WRX, and Impreza : Electronics
Old 11-30-2022, 05:29 PM #1725
Dubz25_ Dubz25_ is offline
Dubz25_ is on a distinguished road
My 1999 limited started whistling/squealing while accelerating. It tends to start around the 20mph mark and gets loudest when I take my foot off the accelerator. Anyone know what could be causing this?
Here’s a video that captures the sound:
Whistle identification - Album on Imgur
It sounds like it’s coming from the passenger side but I can’t tell for sure. I also previously had a code for a lean air/fuel ratio however I replaced a vacuum hose about 800 miles ago and the code hasn’t returned since so I don’t think it’s from a vacuum leak.
Any ideas?
Thanks!
Dubz25_ is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
