11-03-2020, 08:44 PM
#166
Originally Posted by Bad Luck
Photo isn't working for me
How about now, it should be attached to the post
11-04-2020, 09:59 AM
#167
Real Name: Patrick
Real Name: Patrick
That's better! That's about what I had pictured in my head. If it were me, I would use the main ground wire for the relay grounds rather than run the relay ground all the way back up front to the battery. I'd run an inline fuse by the battery on the main power cable to the rear similar to if you were powering an amplifier.
11-04-2020, 12:50 PM
#168
Admin??
Is there a dedicated Admin for the 3rd gen section??
11-04-2020, 05:27 PM
#169
Yeah, that makes sense actually and should save some wiring. Are there any good tutorials that you know of for amp installs? I've never actually done one.
11-04-2020, 06:32 PM
#170
How do I go about cleaning the inside of the engine bay? I've been slowly detailing my 4runner and the engine bay is the last thing, but I am scared to spray water in there even though I've read that it's perfectly fine. My dream is to keep this baby fully stock and looking brand new.
11-04-2020, 06:58 PM
#171
Real Name: Patrick
Real Name: Patrick
I've only even uninstalled amps in my vehicles lol I would imagine that crutchfield.com should have some tutorials on install
11-04-2020, 06:59 PM
#172
Real Name: Patrick
Real Name: Patrick
If you are looking to make it immaculate then check out this youtube video: How to SUPER CLEAN your Engine Bay - YouTube
11-05-2020, 09:55 AM
#173
Hey all,
I have a 2002 limited and looking to get a new set of tires. There are so many different suggestions my head is spinning. Michelin? Nitto? KO2? Falken? Yoko?
Is there a consensus on what the best AT tire is for mostly highway, limited off road that won’t make too much noise?
Thanks in advance.
11-05-2020, 10:01 AM
#174
Tires Tires Tires
Hey all,
Thanks in advance.
11-05-2020, 01:14 PM
#175
Real Name: Devan
Real Name: Devan
Originally Posted by Monkeyrunner
Hey all,
Thanks in advance.
Falken Widepeak, never look back
11-13-2020, 01:44 AM
#176
Anyone ever removed this faux wood stuff? I hate the look of it and actually replaced my climate control panel because I marred up the original so badly trying to remove it. So, any tips for how to remove it without ruining my dash?
11-13-2020, 08:48 AM
#177
Real Name: Devan
Real Name: Devan
Originally Posted by zasuwasu
Hello all I just got a 1998 Toyota 4 runner sr5 today and it seems to be leaking oil when it is running and only when it’s running I checked the oil cooler but that looks completely dry
Any help would be appreciated!
Valve covers?
Where is the leak roughly, or where do you notice it? Look for wetness.
11-13-2020, 12:37 PM
#178
Get yourself a good heat gun. That's clearly aftermarket there and I'm right there with you on the faux wood. It's gonna be some glue residue and once heated up everything should come off cleanly but you'll have to scrape and pull off remaining stuff. Take some soap and water to it at the end and that should really clean things up. Good luck and hope this helps.
11-14-2020, 11:56 PM
#179
Real Name: Devan
Real Name: Devan
The OEM front skid off an 01-02 will fit a 99-00, right? Looove how they look and wouldn't mind a little protection around there
11-16-2020, 10:47 PM
#180
Looks like the front skid plate takes 7 bolts. Mine only had 4 when I got it. I had to remove for radiator swap. Just got the rear two bolts back in, having trouble with the other two..
how many bolts does the front skid plate truly need?
2023 TRD Offroad Premium, nautical blue
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
