Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 01-31-2023, 03:03 PM #1981
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
Does anyone use any kind of rubber conditioner or some other substance on their cv boots to make sure they stay healthy for a longer time?
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 03:25 PM #1982
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by DJRodriguez88 View Post
yeah i thought the same thing, but 2 youtube how-to's in a row pulled the mounting bolts
I'll try the stud first, thanks!
For what it worth I've been doing BJ's since before YouTube and net was invented. I'm old.
Old 01-31-2023, 03:50 PM #1983
Let's call it "experienced" =]
Old 01-31-2023, 05:42 PM #1984
Real Name: Mark
Real Name: Mark
Haven't heard of it being done.
01 bought @ 198k mi original boots/shafts. Did 2.5-3" lift with diff drop 10k mi give or take one of the four broke.
Old 02-01-2023, 02:00 PM #1985
Boom_ROASTED Boom_ROASTED is offline
Boom_ROASTED is on a distinguished road
so I'm rebooting my steering rack. Driver side boot was torn but no issues with the steering at all.
I can tell my inner tie rod on the driver side seems a little more stiff than the passenger side. Can I just slop some more grease on and reboot? Is there anything I can look for that would indicate things will go south quick? There's no roughness or looseness at all, just slightly harder to move around compared to the passenger side.
also, because the boot was torn there's a bit of a mess in the driver side end. Any reason I can't spray the crud out with some brakeleen?
Boom_ROASTED is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 05:41 PM #1986
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
IMO if I was doing all this work I'd just replace all my tie rods, unless they have just been done, if they have an unknown or a known high miles why waste all ur time and effort...
clearock is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 05:47 PM #1987
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
If the boot(a) are torn, replace them. You don't want debris getting into the rack.
If the inner tie rods are bad, replace them. Loose doesn't mean bad, check for play and replace if out of spec. I usually replace them in pairs vs each if one is bad.
JM2C
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 01:00 AM #1988
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is online now
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The good tie rod is tight so the one with more play is the suspect one, if anything. If you get your hands on a new inner or outer, that’s the first thing you’ll notice. They almost don’t move without significant pressure being applied.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is online now   Reply With QuoteReply With Quote
Old 02-02-2023, 07:12 PM #1989
wtfdissux2 wtfdissux2 is offline
Real Name: Chuck
wtfdissux2 is on a distinguished road
Real Name: Chuck
Cool Protune rear arms
Has anyone used protune rear adjustable upper and lower arms with adjustable panhard bar? About to lift it after putting it off for last 5 years and now since I need to replace a lot of bushings anyways figured might as well
wtfdissux2 is offline   Reply With QuoteReply With Quote
Old 02-04-2023, 12:19 PM #1990
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you are talking about these: Upper & Lower & Track Bar Arm For 2-4" Lift Kit 4-Runner FJ Cruiser 03-09 I would be very skeptical about the fitment as they don't list what years of 4Runner they fit.
Old 02-04-2023, 04:26 PM #1991
Don't change the trailing arms for adjustable ones, there really isn't much adjustment possible given the clearances of everything back there.
I went with Rokman lower trailing arms, personally, beefy with new bushings. The upgraded, fixed length arms Sonoran Steel sells are nice too. The stock uppers are also pretty good, replacing the bushings is a chore.
I've always favored the eimkeith PCK over adjustable panhard bars, personally - weld it one and done. One less thing to come loose or unadjusted.
JM2C
Old 02-05-2023, 08:51 AM #1992
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
JM2C
But what about an adjustable panhard bar with the PCK?
Sent from my SM-T220 using Tapatalk
Old 02-05-2023, 08:27 PM #1993
Real Name: Chuck
Real Name: Chuck
JM2C
The uppers are both bent and all bushings about shot figured adjustable even threaded all the way in would be more solid than OEM.
also wanted to retain the original pinion angle for rear diff when I drop it 4inches, also the reason for the adjustable panhard.
If could find a beefy set of 4 arms and the adj panhard would likely go that route since it is also my DD and budget is a concern the set I was looking at made good sense but havent heard of the brand before.
Old 02-05-2023, 08:42 PM #1994
Real Name: Chuck
Real Name: Chuck
similiar but the ones I saw were a different part number and did list 96-02. dont matter though since they went from 6 in stock to sold out the day I posted the question.
Old 02-05-2023, 10:41 PM #1995
Real Name: Patrick
Real Name: Patrick
Strange. That’s the only part number they show on their website for 4Runners.
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
