Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 09-16-2023, 07:58 AM #2551
OpenYota's Avatar
OpenYota OpenYota is offline
OpenYota is on a distinguished road
OpenYota's Avatar
Does anyone have a diagram/pictures or know of which electrical connections are for the transmission?
I’ve had a P0770 for ages and have tried other fixes to no avail and have read that dirty or broken connectors can lead to triggering the code.
Any advice?
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 09-16-2023, 12:28 PM #2552
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by Bad Luck View Post
Does anyone know of a quick way to determine if a 2000 SR5 came equipped with key fobs? The vehicle in question only came with 2 valet keys.
Look for the "chirper". It's in the rear corner, passenger side of the engine compartment, on the inside of the fender. (Answer valid only for '99+ 3rd gens.)
My Backyard Frame Swap
Old 09-16-2023, 07:41 PM #2553
bghawkins bghawkins is offline
bghawkins is on a distinguished road
Originally Posted by SugarRhino View Post
Don’t know how far you may be from Houston, but Restoration Station might be able to offer some suggestions.
Never met them personally, but their rehab work seems on-the-beam.
I imagine there are Texans around the boards who might have suggestions depending on where you live, too
Dropped it at Restoration Station today! This place seems SOLID. He thinks he can fix us all up without a frame swop. Will keep you posted! Thanks for the recomendation!
bghawkins is offline   Reply With QuoteReply With Quote
Old 09-16-2023, 10:30 PM #2554
Charles27998 Charles27998 is offline
Charles27998 is on a distinguished road
I need a little help
So I’m 16 and I just got my first car, a 1998 4Runner limited 4x4. I’m not very experienced with cars but would like to learn a little bit. I tried to take a picture cause I’m not sure how to explain my problem but couldn’t figure out how to get pictures to work so I’ll do my best. I’m having trouble where the wire from the fuse box connects to the positive battery terminal. The piece that connects the fuse box wire to the terminal is bent so now the fuse box wire cannot slide in. I’m not sure what to do about this I’ve tried in every way I can think of to bend it back into shape but it won’t bend. I’m sure I can just buy one of these easily but I’m not sure what the part is called to buy it lol. Would love to hear some feedback!!
Charles27998 is offline   Reply With QuoteReply With Quote
Old 09-18-2023, 07:27 PM #2555
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ is on a distinguished road
gh25_'s Avatar
E-locker sensor
Hey there guys,
I recently pulled a e-locker rear end off this guys rolled 3rd gen so I can swap it over to my 1998 2WD. I've been taking notes / part #'s of things I want to replace. One of the things I want to replace is the sensor that sits on top of the 3rd member. It looks like a knock sensor for the engine. It's the switch / sensor that tells the computer that the e-locker if it is on or off. I asked my local Toyota dealer guy for the part number and he provided #84222-12010 saying that it is the right one I am looking for From what it seems like, the same switch is used also on the transfer case as the 4WD switch. I was going to just buy an aftermarket dorman switch since it's not a crucial part & it's easy to replace if it ends up being no good, so no need to shell 88 for an OEM one, yet.... My question is should I be fine just using the 4WD switch for my e locker. The switches look identical and they are both 2 prong switches.
https://www.oreillyauto.com/detail/c...toyota-4runner
The 3rd Gen All Questions Allowed Thread-img_3273-jpg  The 3rd Gen All Questions Allowed Thread-img_3274-jpg
gh25_ is offline   Reply With QuoteReply With Quote
Old 09-19-2023, 02:02 PM #2556
TheDurk's Avatar
TheDurk's Avatar
Originally Posted by gh25_ View Post
Hey there guys,
Should be fine if the plug matches.
Old 09-19-2023, 06:48 PM #2557
taco24runner99 taco24runner99 is offline
taco24runner99 is on a distinguished road
Parts help w/ rear LCA
So i found bolt to replace rear LCA bolts Product ID: 90119-14069 but I cant seem to find it for the front bolt. Do they use the same size ? I want to keep parts from Toyota if I can rather than matching threads etc.. anyone have an answer?
taco24runner99 is offline   Reply With QuoteReply With Quote
Old 09-20-2023, 08:57 AM #2558
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It shows to be the same bolt for both ends of the rear lower control arms. TOYOTA 4RUNNERVZN185L-GKMGKA - POWERTRAIN-CHASSIS - REAR SPRING SHOCK ABSORBER | Japan Parts EU
Old 09-20-2023, 12:08 PM #2559
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
iso rear wind deflector feet
2000. have the long panel with the cut out for the 3rd brake light. but have misplacced the "feet " that attaches it to the rear hatch, and all the screws.
tried looking up part numbers, no luck. only 2 wreckers within 300 miles and none have. Posted in the forsale buy section but no luck yet. Found the full set up for 65 plus shipping....which to alaska would not be cheap im betting...just need the feet and hardware
ideas ?
Old 09-20-2023, 11:12 PM #2560
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
Currently shopping for heads for my 99 5vz.
Found some 2002 heads for sale. Supposedly the head gasket blew, he had the heads redone then at some point later he blew the crankshaft somehow.
Does anyone know if there's any difference between the 99 heads and the 2002?
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 09-21-2023, 10:30 AM #2561
I❤️4runners's Avatar
I❤️4runners I❤️4runners is offline
I❤️4runners is on a distinguished road
Hey guys. I need your wisdom. I just had a new set of 33" BFGs put on my 3rd gen, I replaced the LBJ's and out tie rods and took it to the alignment shop to get everything straightened up. Everything was fine and dandy until about 2 days after I had the alignment done, the truck started pulling slightly to the right when I was driving, even though the steering wheel was nice and straight and everything was in line, and the steering wheel shakes from about 45-50mph then goes away around 60mph.
Then I noticed yesterday morning that there was a little spot of oil under the truck. I've know my valve cover gaskets have been leaking a little bit for a while and I often get little oil drips here and there. However, upon closer inspection, I found that the oil spot wasn't motor oil but power steering fluid. Checked my fluid level and I'm a little low but nothing to be concerned about. Inspected the the steering rack and it's covered in yucky oil/road grime goop but it's always been that way, I assumed because of my leaking valve covers slowly dripping oil down around the front diff and steering rack. But now I'm wondering if it's because my steering rack is going bad and leaking. I do have a fair amount of play in the steering wheel but I'm not hearing any grinding or whining noise when I turn and the wheel doesn't feel like its binding up or anything.
So I'm just kind of wondering if anyone has had the symptoms before and found the steering rack to be the culprit. If it need's to replaced I'll do it I'd just rather hear what you guys have to say about it before I drop $700 on a new rack. Thanks guys!
I❤️4runners is offline   Reply With QuoteReply With Quote
Old 09-21-2023, 11:59 AM #2562
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
Hey there guys,
If u dont mind doing a little wiring the ones that come on the Tcase with a plug/wires can b used or vise versa
clearock is offline   Reply With QuoteReply With Quote
Old 09-22-2023, 09:46 PM #2563
MtnGoat9 MtnGoat9 is offline
MtnGoat9 is on a distinguished road
Originally Posted by MtnGoat9 View Post
Those were super useful, thanks again. Got at least 4 options.
That said, a dumb question...when the spring specs say 2in lift or whatever, is that 2in higher than stock? I'm assuming so for now, back to level ..plus 2".
I took the plunge and ordered the OME 928(?) 3” lift springs
Surprised how easy installing them was. Love the clearance and load capacity, went to Idaho fully packed and did some pretty foul roads up some big peaks. Didn’t touch bottom on anything even once.
However it’s definitely more lively and can sway on the highway I guess due to the high rate and lift.
My toy guru says it’s because the ends of the rear bar are no longer parallel to the road surface and I’m feeling ‘rear steer’ from the geometry change.
So I guess I need to order the right link extensions to get the bar geometry back to where it should be? Should I change rear shocks while I’m under there? The stock ones are extended farther now for sure
The 3rd Gen All Questions Allowed Thread-aa0fc302-67d9-4f1f-873d-41108b91750d-jpg
MtnGoat9 is offline   Reply With QuoteReply With Quote
Old 09-23-2023, 12:02 AM #2564
barbie.the.runner barbie.the.runner is offline
barbie.the.runner is on a distinguished road
Question
hey guys, new to the forum and new to owning a 3rd gen sr5 4runner. Not sure how to post on here quite yet.
I am needing to replace my clutch and not sure how to go about finding parts, I've searched everywhere for 4x4 compatible clutch kits and for some reason can't find one. Not going to do any crazy rock climbing or anything yet, so just wanting a standard replacement. Any recomendations?
thank y'all
1997 4Runner SR5 3.4L V6 manual
barbie.the.runner is offline   Reply With QuoteReply With Quote
Old 09-23-2023, 11:10 AM #2565
the-_-stig the-_-stig is offline
the-_-stig is on a distinguished road
P0300 Problem Solving
Hello, my 98 4Runner (27500 mi) has been having some issues sputtering on and off for the past 2 months as I continue to try and troubleshoot it. It’s only shown a CEL a couple of those times and I got P0300, P0306. I was hoping there might be some experience out there to help isolate what’s wrong.
I replaced the muffler on my 4Runner and because of how bad the corrosion was I also had to replace the O2 sensors (Bosch 13104). Had no issues for about 200 miles, then I started to get some pretty intense sputtering. When it was low RPMs, when I was accelerating heavily, and it would get slightly better when the car warmed up. I replaced the spark plugs and cleaned some of the fuel system. I thought I’d found the cure, drove it 300 miles before it came back. This time only after the car warmed up when I was doing heavy acceleration. Reading into things I thought maybe my O2 sensors were faulty and swapped them with the OEM (Denso 234-4154). This has not helped much and now I get slightly more frequent sputtering and when sitting idle at a stop light it will do a small shutter every 30 seconds or so.
My plan forward would be to do the wires and maybe the coils (Denso 673-1201/671-6182). If that doesn’t fix things it seems like the fuel injectors might also cause this issue, but that seems like quite the project. Please offer any advice or tips? Appreciate any help!
the-_-stig is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
