Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 09-30-2023, 05:03 AM #2581
ibob4tacoz's Avatar
ibob4tacoz ibob4tacoz is offline
Real Name: Kent
ibob4tacoz is on a distinguished road
ibob4tacoz's Avatar
Real Name: Kent
Totally unrelated to maintenence, any of you other Facebook users able to find the 3rd Gen Mafia group? Looks to have been zucked.
- '99 4Runner SR5 4WD 5spd
ibob4tacoz is offline   Reply With QuoteReply With Quote
Old 09-30-2023, 06:33 PM #2582
LostInNewtonCo LostInNewtonCo is offline
LostInNewtonCo is on a distinguished road
Bought a 1999 SR5 last week. Diagnosing front end steering tracking problems and clunks over bumps today and came across the part number on my front strut. I’ve been curious if these are the stock struts or not as the front end looks taller-ish than others I’ve seen, and Google isn’t giving me anything so I’m asking y’all’s help. On the shock body, behind the coil it says from top to bottom “315, warning do not heat or open, install this end down, made in USA PO31L1D” I actually can’t tell if the O is a zero or not but neither turn up on Google. The shock is blue. Can anyone help me identify it?
LostInNewtonCo is offline   Reply With QuoteReply With Quote
Old 10-02-2023, 05:04 PM #2583
barbie.the.runner barbie.the.runner is offline
barbie.the.runner is on a distinguished road
thank you so much. any reccomendations for the flywheel?
barbie.the.runner is offline   Reply With QuoteReply With Quote
Old 10-02-2023, 05:05 PM #2584
Originally Posted by TheDurk View Post
Clutch Kit- Toyota V6 3.4L 5VZ-FE 4runner, T100, Tacoma & Tundra OEM Aisin Clutch Kit (1994-2004) CKT-040
Aisin is the supplier of the factory clutches. The CKT-040 kit contains:
Pressure Plate
Friction Disc
Release Bearing (Throw-out Bearing)
Pilot Bearing
Alignment Tool
Thank you so much. Any recommendations for the flywheel?
Old 10-02-2023, 07:25 PM #2585
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Toyota is $$$$
Marlin Crawler has a nice one
LC Engineering has a nice one
I used a Sachs flywheel, ordered it with an Aisin clutch kit, same one Durk linked to you. I have no regrets.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 11:59 PM #2586
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I used a NAPA. It was smooth as silk from Day 1. And Day 1 was 2006 140k miles ago. I have heard NAPA switched suppliers but I can't confirm that.
One thing you should do is change your shift seats. It makes a world of difference. Your old ones will probably fall to pieces if they have not been done.
Heavy Duty Seats | Marlin Crawler, Inc.
My Backyard Frame Swap
Old 10-04-2023, 04:34 PM #2587
Psychlops Psychlops is offline
Psychlops is on a distinguished road
99 Tall coils on 2wd
Since the 99 Tall coils are meant for a 4wd, if I put them on my 2001 2wd would the front end possibly end up higher than the back since there's less front weight on the 2wd? I'm guessing the 4wd coils are a little stronger/stiffer to accommodate more weight?
If you think that could happen, do you think it would be enough to be obvious at a glance?
This is just a daily driver, no real offroading. Just a few light camping trips per year.
And if anyone has actually used the 99 Talls on a 2wd, please chime in and let me know if you encountered any problems with the install or later on. I've found others asking about it on these forums, but can't find any posts after they did it. Thanks!
Psychlops is offline   Reply With QuoteReply With Quote
Old 10-05-2023, 08:26 AM #2588
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I just ordered some 17x7.5 inch Toyota steel wheels off ebay for daily use and to replace the spare (17 Inch 6 on 5.5 Steel Wheel Fits Tundra Sequoia Land Cruiser X42768 T | eBay). I know I need acorn bulge style nuts, but I'm not sure if I can use normal ones (ACORN BULGE LUG NUTS - 12MM X 1.5 (VARIOUS QUANTITIES)) or if I can use the extended thread type (Chrome Acorn E/T Ultra Style Conical Lug Nut, 12mm x 1.5 (Various Quantities)). Does anyone have any experience with this?
Old 10-05-2023, 09:38 AM #2589
OpenYota's Avatar
OpenYota OpenYota is offline
OpenYota is on a distinguished road
OpenYota's Avatar
A certain clown managed to get it shut down and opened up another page under his own terms.
I believe the new page has the same name
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 02:53 AM #2590
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
ive got a 99 v6. does anyone know if the studs on the exhaust manifolds are the same as the studs used in the collectors/crossover pipe?
also, is it a good idea to replace them if they came out with the nuts?
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 04:10 AM #2591
Imhotep Imhotep is offline
Imhotep is on a distinguished road
I have a 3rd gen 3.l diesel surf which shorted out while driving. Positive battery clamp broke and touched the hood. Repaired the harness as best as I could had to run a new wire from the starter to the key switch. It starts however switches off as soon as it is placed in gear. It will start in park or neutral but the moment you put it in reverse or drive the engine immediately switches off.
Imhotep is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 05:09 PM #2592
alex9000 alex9000 is offline
alex9000 is on a distinguished road
First look over my new 99 SR5 - spotted some oil behind the transmission (?). What's leaking? Will get some better photos.
The 3rd Gen All Questions Allowed Thread-captu111222re-jpg
alex9000 is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 11:13 PM #2593
if that's motor oil then based on the location it's probably rear main seal or the oil pan. it could even be just accumulated mess from regular oil changes or a leaky oil filter.
if it's not motor oil, then the type of fluid will tell you exactly whats leaking (tranny fluid, power steering, etc.). It all looks pretty much the same once it's dirty.
Old 10-10-2023, 06:32 PM #2594
Thank you. Yeah I'll give it a clean off and see what accumulates. I need to pass an out of province inspection, hoping a good de-grease and clean does the job.
Old 10-11-2023, 07:59 PM #2595
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ is on a distinguished road
gh25_'s Avatar
gear ratio
Hey guys,
quick question here. How can I tell the gear ratio of my 3rd member when it is out of the truck? I have a e-locker rear end I got a month ago and I am trying to figure out what gear ratio it is. Since its a auto 1998 4runner it came off it's most likely a 4.30 ratio but I want to make sure it is or isn't. Obviously it's not on a truck or anything so I can't do the driveshaft wheel spin test. I currently have the 3rd member out of the housing, would I just count the teeth on the ring gear a certain way?
Thanks,
-GH
gh25_ is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
