Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 12-01-2023, 10:47 AM #2701
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by bpenguin View Post
I just tested the battery with a multimeter: 12.29 volts so still going strong.
You need to do what's called a load test to determine battery health. Testers can be bought for pretty cheap and autozone/napa/etc might offer it for free. Be careful with them cause they get hot, they're basically a giant fuse with a meter on it. Oversimplified; they basically hook up to your battery and put a major impedance across it, and how the batt reacts will tell you about it's lifespan. Takes no more than 60 seconds all said and done.
Just prodding with a multimeter won't tell you much - when dead cells occur more often than not resting voltage will check out perfectly fine in nearly every situation but cold cranking, when it's experiencing the most load.
They look like this.
To me it sounds like a dead cell; in my experience starters are almost always either will-start or no-start, and you only start hitting that "maybe it will start maybe not" window after they've been dying for a while and you've hit them with a hammer 5 or 6 dozen times. But that's just my opinion.
The 3rd Gen All Questions Allowed Thread-20211201_165925-jpg
Old 12-01-2023, 12:14 PM #2702
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That is low for battery voltage. I'd get it tested at your local parts store.
Old 12-04-2023, 01:50 AM #2703
Ruben02runner Ruben02runner is offline
Ruben02runner is on a distinguished road
Hey everyone I'm new to the forum, I had a couple questions about gearing and tires size I can't seem to find a strait answer I got this rig and put some 33x12.5x15 tires on it and need to re gear so I picked up a a carrier today for 150$ with 4.10 gears in it.My question is would that be fine to use for just Dailey driving mainly highway use? The gears in it now are 3.something's and is way to slow for my liking. (2002 4Runner SR5 3.4v6 auto 2wd)|
Ruben02runner is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 03:58 PM #2704
Real Name: Patrick
Real Name: Patrick
Most 4wd 3rd gen 4Runners came factory with 4.10's and those people choose regear to 4.56/4.88 when they go to 285's (33 inch tires). Swapping to 4.10's will help but it will still be a slug.
Old 12-05-2023, 11:27 PM #2705
What 4 runner came with 4.56 or if any did.
Old 12-06-2023, 03:04 PM #2706
cvtvm cvtvm is offline
cvtvm is on a distinguished road
Can I run Falken Wildpeak A/T3W tires in a 265/70 r17 115t SL RBL spec? I'm looking to move on from a set of BFGoodrich All Terrain T/A KO2 tires in the following spec LT265 /70 R17 112S C1 RWL
No added bumpers/weight, refreshed stock height suspension, daily driver with an occasional trip up the mountains/snow.
cvtvm is offline   Reply With QuoteReply With Quote
Old 12-07-2023, 02:47 AM #2707
WARunner WARunner is offline
WARunner is on a distinguished road
I pulled my steering rack out and let every little bit of PS fluid/ATF drain out. How should I go about filling it back up without a mess or dry running the pump?
With the batt unplugged I put about 0.7 QTs into the res and moved the wheel lock to lock for a while. The fluid level is maxed out and doesn't seem to be dropping. Would prob have to turkey baste some out to get it to the cold line.
WARunner is offline   Reply With QuoteReply With Quote
Old 12-07-2023, 08:12 AM #2708
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Start the car and move lock to lock. Add more ATF until it reaches the full mark and call it a day. PS pumps are tough, it won't hurt them to run them slightly dry for moment
Old 12-07-2023, 04:25 PM #2709
Real Name: Patrick
Real Name: Patrick
4wd/4cyl/automatic did but it's a very rare combo.
Old 12-07-2023, 04:27 PM #2710
Real Name: Patrick
Real Name: Patrick
Yes. They will work.
Old 12-08-2023, 02:04 PM #2711
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Is there some sort of trick to pulling ABS codes that I'm not remembering?
I jumped the E1 and TC ports with a paperclip and pulled the shorting bar but got nothing. Tried it with the shorting bar, and still nothing. Even shaved down the paperclip to make sure it fit well but it didn't help either. I just did this like a year or two ago and it was totally hassle free?
I've been riding without ABS for some time now and it's been great until the last couple weeks as I noticed my brake pedal getting a little softer and softer. Then yesterday it was SUPER spongey out of nowhere - on slightly wet pavement I was stopping like was on a few inches of snow. I'm hoping to see if turning ABS on and letting fluid cycle will change anything.
Fairly certain the cause is for a wheel speed sensor I damaged when i broke my steering knuckle but I can't even pull the code to check now lol
Old 12-08-2023, 03:10 PM #2712
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ is on a distinguished road
gh25_'s Avatar
Almost a fire
Hey guys,
One of my good friend just got a 1st gen tundra last week and we were trying to attach some lights but things didn't really go right. When I bought my TRD style grille for my 4runner it came with raptor lights but I didn't want them so I didn't use them. I told my friend he could have them since I didn't want them. So a couple nights ago we tried to wire them up and everything was going alright and then it didn't. For this little job we went to O'Reilly's and got a Sylvania wiring harness, and a 3-prong Dorman switch. I'll include a link to the raptor lights too but they are generic and all the same. I didn't buy them from amazon but they are the same. So, we crimped butt ends onto the raptor lights and then attached them to one of the outputs on the wiring harness and then put the wire thru the boot on the firewall and then cut off the harness switch put three butt connectors on and attached them to the new dorman switch. After we had everything together, attached the positive and ground to the terminals on the battery. we decided to test them out. Flipped the switch and they turned on went and looked at the lights and then went back and turned them off. Then about 10 seconds later I smelled electrical smell and I started seeing smoke coming from the extra cord of the harness, knew what was happening and quickly disconnected it from the battery. Just from that it completed ruined the harness, it melted and burnt it all together. I am wondering if anyone can tell me what I did wrong? I've done something that is exactly what I did on my truck and it turned fine. Same thing same wiring harness, except I have pod lights instead of raptor lights and I used a toyota OEM fog lamp switch, 00550-35976. Instinctively I checked the fuse in the harness to see if it popped and it did. it's a 15A fuse. So it popped the fuse and started melting the wires on the switch side of the wires. My guess is that it is the switch. I thought since the fuse was 15A and the switch says it's a 20A that it was too much and that caused it but my toyota OEM switch says it's a 21A switch, so that doesn't make any sense. Again, we had everything wire right, polarity, everything was right. Any input? Lol I know this is dumb but I am genuinely confused why it happened.
https://www.oreillyauto.com/detail/c...an+85909&pos=0
Amazon.com
The 3rd Gen All Questions Allowed Thread-imagestack_lbarhrns2p_2-jpg
gh25_ is offline   Reply With QuoteReply With Quote
Old 12-09-2023, 01:02 PM #2713
Dubz25_ Dubz25_ is offline
Dubz25_ is on a distinguished road
Hey everyone! Iím going to be replacing my rear lower control arms soon and have a quick question. Is it necessary to have the truck on jack stands? The bolts seem pretty accessible while the car is on the ground and I donít have a ratchet strap to hold the axel in place. Just thought Iíd ask before going out and buying a strap. On a side note, if lifting is required, does the suspension need to be dropped too or can I keep the jack under the rear diff during the entire job?
Dubz25_ is offline   Reply With QuoteReply With Quote
Old 12-09-2023, 04:41 PM #2714
88íLuda 88íLuda is offline
88íLuda is on a distinguished road
Too much rust??
Hi everyone, Iím looking at an 01 4Runner and worried about the frame. I have some pictures. What do you guys and girls think.
The 3rd Gen All Questions Allowed Thread-img_0312-jpg  The 3rd Gen All Questions Allowed Thread-img_0311-jpg  The 3rd Gen All Questions Allowed Thread-img_0310-jpg  The 3rd Gen All Questions Allowed Thread-img_0309-jpg  The 3rd Gen All Questions Allowed Thread-img_0308-jpg
88íLuda is offline   Reply With QuoteReply With Quote
Old 12-09-2023, 07:50 PM #2715
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Iíd poke it with a screwdriver and see what happens.
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
