Okay, here we go. I'm verbose, but try to use language to pain a clearer picture, so I can get the best info. If long posts bug you, please move along.
I'm a vehicular mechanical moron, as my other postings should have already pointed out. I'm also really busy as a one man business, and don't have endless hours to pore over endless reams of info, all from individuals with varying degrees of knowledge, cross referencing to confirm validity etc. I'm a long time bicycle mechanic and in that world, I am well versed in how many, just horrible ideas and bad info is available for the picking, on line.....
So, with that in mind, I have two different things I need help with understanding better.
Front end suspension/wheel anatomy. I've done a bunch of stuff over the last few years, much of it without knowing WTF I was doing. What I am looking to figure out is, what, if anything else, I should be addressing on a vehicle with 140K on her, given the updates I've done, how they interact with the rest of the system, and my plans to start to use it a bit more off road.
Done:
34" tires (working on clearancing, but I'm close).
New axles/CV's since the boots all exploded seemingly at once.
New lower ball joints (OEM as strongly suggested).
2" OME suspension lift.
2.5" leveling kit pucks at the tops of the strut towers.
In the works come April when she gets out of the barn:
Lower control arm bushings.
Caster adjustment cam since mine are frozen, preventing a full, proper alignment (but I'm really close, so it drives well).
Brand new JBA upper control arms to help with moving the tires forward in the wheel wells a bit for clearance.
What else is in that system? Sway bars and Stabilizer arms. Is that it?
I know I have little boots on one of those items (sorry, told you I was clueless) that are shredded, and my mechanic said not a big deal as they seemed tight and functional, and I just drive it in the summer.
I've found sway bars that are adjustable to deal with lifts, which I have. Smart, for the price? And, are these guys a good choice if it is a good idea?
Sway Bar Links
– DRZ OFF ROAD
I don't even understand what stabilizer bars do, but my reading seems to imply they are good till they break, and not to worry otherwise. I am thinking those are the things with the torn boots though, which bugs me.
And second.
On here, I was told by a few members, in passing, that "suspension lift and leveling blocks are fine, but do have drawbacks".
I have the same 2" OME suspension lift out back, as well as a 1.25" spring block to get rid of the out of level look created when the 2.5's up front, simply flipped the problem I was trying to correct.
What other lift types exist, and how serious a safety or mechanical failure issue am I facing with the parts I have.
No rock crawling or crazy extreme articulation plans, but who knows how big a rock, or log, or something I might encounter is and I don't want the body falling off the frame or whatever befalls the less than proper lifting that's been done.
With these things answered, I'll be able to hand my mechanic a pile of smart parts come Spring, wait a week, and be driving a nice, stable, good looking, highly functional off road truck without worrying about some $100 part that I shoulda, coulda, woulda....
Thanks all!
