03-01-2024, 05:06 PM
#2896
Real Name: Evan
Real Name: Evan
Originally Posted by NachesPass4x4
I need to track down a rear axle housing for a 2000 4runner 4wd, 5speed, w/ABS.
Is it correct that these axle housings are all the same and 2wd/4wd doesn't matter? The only thing I need to watch out for is that it has ABS?
2001-2002 has a different hard brake line configuration than previous years. As far as I’m aware, that’s the only exception assuming you’re differentiating a 1996-2000 non elocker axle housing from an elocker housing since there is a notch in it.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
03-01-2024, 06:29 PM
#2897
Originally Posted by Devbot
Which side of the Naches are you on? If on the west side you can make a drive here to Marysville, I know DeathCougar has some
I'm on the west side, not far from Greenwater. Thanks for the info, I'll keep it in mind.
03-10-2024, 01:14 AM
#2898
If a 3rd gen hits rev limiters and stalls in the forest trying to crawl harder than stock allows...does anyone hear it?...
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
03-10-2024, 12:33 PM
#2899
I hope that's a rhetorical question......
My other 4Runner is a ford
03-13-2024, 08:53 PM
#2900
Shifting to L4L
New owner of a '99 with the button/lever style 4WD shifter. When I shift from H4L to L4L using the procedure indicated in the owner's manual, I feel a bit of gear chatter (like shifting without a clutch in a manual transmission.). Not a lot, but enough to make me worry that something isn't syncing up right. I feel the same thing when I shift from N to H4L. Is this normal?
03-14-2024, 01:07 PM
#2901
If you have an automatic transmission the gear selector must be in park or neutral and the vehicle at a full stop to go from 4H to 4L, or vice-versa. A manual transmission must be in neutral and at a full stop. And the shifter throw should be swift and assertive.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
03-14-2024, 04:15 PM
#2902
The High to Low shift is worse than that - it is a manual transmission gear shift between 2.73:1 and 1:1 - which is about like shifting from 2nd to 4th in most transmissions. It is also non-synchronized. So, no clutch, no synchros, big ratio change. Stop fully, put in neutral, wait for 1-3 seconds, then 'bang' that shift quickly and with authority. The longer you take/wait, the worse it will be - even in neutral there is some residual output shaft speed if the transmission is unloaded (transfer case in neutral). Think banging the shift in a dog box and all will be happy. NEVER do it while moving or any other transmission gear than Neutral or Park.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-14-2024, 04:30 PM
#2903
Throttle position sensor
Hey everyone, I have a 2001 4runner 4x4 with a reading of "throttle /pedal position sensor switch A circuit showing up. I changed the sensor out two times but after driveing for 5 minutes i lose the first 3/4 of the throttle and have to limp back home pushing the pedal almost all the way and the auto transmission shifts real hard when its in that mode ? any thoughts ?
03-15-2024, 02:32 PM
#2904
The 01/02 4Runners have an electronic throttle with a slight mechanical backup. It is more complicated than it looks like from the outside... search the forums here (use the "advanced" search via google) to find more information - it is more than we can get into in this thread.
03-15-2024, 05:48 PM
#2905
Real Name: Mark
Real Name: Mark
Hey everyone, I have a 2001 4runner 4x4 with a reading of "throttle /pedal position sensor switch A circuit any thoughts ?
I've been learning with my 01 TPS dtc for about a year. Last 2-3 months been going into limp mode and
or a high idle rpm around 1200. Have tapped TPS with screwdriver handle solves problem. Clear code with reader.
Hard shifting comes from TPS-ECM-Trans signal tied together part of limp mode.
3 parts on TB, Accel pos sens, Throttle pos sens, Throttle control motor.
Your case I'd guess maybe the motor setting chain of events
but then Accel pos sens.
Drive by wire TB 23 yr old figure system has a service life. New TB last month on shelf.
Waiting to see what other symptoms arise or it dies.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
03-15-2024, 05:53 PM
#2906
Some questions for the question thread
Greetings everyone!
I ve bought a 1999 4runner a few months ago and use it as my daily. This forum has been incredibly helpful and a great resource! Thank you all for that!
Recently a few things have puzzled me and i havent been able to identify the issues nor resolve them. I ll try to list said issues, maybe someone finds the time to give me pointers! I would appreciate any help!
Some info:
1999 4runner - 300k+ miles
2.7 motor 3RZ
Automatic
4x4
1. I went uphill 4x4 engaged (full tank of gasoline) /
Motor was already warm, i came to a halt on flat ground, wanted to put the car in reverse, but the motor had turned off on its own. The car would crank but wouldnt start. All electronics worked fine. - had to wait for another car to jumpstart mine, and it worked. I thought it might have been the battery, but i had replaced that 2 months ago….
A few days later i had the same issue a couple of times, which made me think it must be something related to engaging the 4x4- and going uphill,needing more power,or draining the battery. Thats if the issue has anything to do with the battery… I dont have trouble cold starting, and i certainly dont have trouble starting the car warm after using 4x4 on flat ground. Only uphill 4x4 and on a warm motor.
2. Check engine light keeps coming on an off after it had given me the code for bad oxygen sensors. Replaced both, bank 1 and 2 along with the catalytic conv.
3. Did a recent oil change and new filter. The mechanic advised me to use pennzoil 20w 50 - specifically pennzoil as it is widely available where i live. -always warm never below 65 degrees F. Any thoughts on the type of oil? I did some research and have a feeling it might actually be quite uncommon ?
Thanks in advance
Wishing you all a great weekend!
03-20-2024, 11:38 PM
#2907
Are there any resources kicking around for a LHD to RHD swap? Thinking about shipping my 4runner down under...
03-21-2024, 12:56 AM
#2908
Real Name: Devan
Real Name: Devan
If I remember right there was some forum member who attempted it, or perhaps considered it, but it is an extreme amount of work and next to impossible if you don't have a Surf to pull parts from. Otherwise good luck getting, well, practically anything. You'd have to rebuilt/replace nearly everything from the front seats to the bumper.
03-21-2024, 06:24 PM
#2909
Working on the rear axle seal replacement and replacing everything else I can while I'm at it. I'm not sure what I'm looking for exactly with the grease test..
https://imgur.com/a/FKPnp77
did I push the abs gear and retainer on too far?
03-22-2024, 08:47 AM
#2910
Real Name: Devan
Real Name: Devan
Been a year or two but I believe that should be good, seeing how the grease was pushed to the center of the ring. The ABS wheel should be easy to check if you just insert the axle and peep through the speed sensor hole to make sure it's covering the width of it
