Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 06-20-2024, 03:44 AM #3001
darmstrong darmstrong is offline
darmstrong is on a distinguished road
96í runner Coolant issues
Just got a 96í 4Runner and the radiator is leaking, itís got Toyota red coolant so Iím not sure if itís the pink milkshake problem. Got new radiator coming. Going to replace it and upper and lower hoses. If it is the pink milkshake of death what do yall suggest I do? Not sure if the tranny has been flushed during its 240k mile lifespan. Iíve got pictures if any one yall are experts on the milkshake problem. Thanks in advance!
darmstrong is offline   Reply With QuoteReply With Quote
Old 06-20-2024, 07:13 AM #3002
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all
JoeT4R's Avatar
A new radiator with Toyota red, plus new hoses/clamps should serve you well coupled with a transmission drain and fill. Drain the trans fluid, observe the color and generally speaking you should be able to determine if coolant is mixing with it.
As an added precaution, you could always add an external transmission cooler, like many others have, myself included, and bypass the radiator to help further prevent the forbidden milkshake.
Old 06-20-2024, 12:55 PM #3003
-any suggestions on the external trans cooler? Also you think it will. be alright draining the trans fluid if it hasnít been changed in 240k?
Old 06-20-2024, 02:22 PM #3004
A single drain and fill (well, drop the pan to check - nearly the same thing) will not cause any harm that hasn't already been done.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-21-2024, 02:35 PM #3005
yuckscott yuckscott is offline
yuckscott is on a distinguished road
Does anyone know if I will lose my DRL functionality if I upgrade to a negative-switched relay harness? I can't find any headlight relay harnesses that advertise as being positive switched or otherwise compatible with DRL. I feel like there must be other Canadians who have gone through this, just looking to eliminate the voltage loss at my halogen OEM style headlights.
99 Limited - E locker, Wildpeaks, Millennium Silver.
yuckscott is offline   Reply With QuoteReply With Quote
Old 06-21-2024, 05:23 PM #3006
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I don't have an answer but when I was searching the forum to see how to easily disable the DRL on my US rig, there were a lot of Canadian forum users discussing DRL issues. "Have you searched to forum using the Google bar and scrolled down to the forum-specific results?" - sorry, but it might help.
262K - Y2K/E - Clock still works
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 06-21-2024, 07:57 PM #3007
Many manufacturers use positive switched headlights - but not most Toyotas (or Subarus, for that matter). The DRL signal will probably turn on the headlights full for whatever filament it uses if you have an aftermarket harness in there. You can be clever and use the DRL signal to trigger some sort of separate DRL setup (weak light bar or similar) or just run it as-is. It is not a modern PWM-style setup that can really mess with relays, so you are safe there.
Old 06-25-2024, 05:10 AM #3008
JoeT4R's Avatar
JoeT4R's Avatar
I trust what Charlie mentioned. As far as a trans cooler, I like B&M products although they are getting harder and harder to find. I bought mine for my 4Runner in 2016, and just bought one for my other ride, a Honda, but I had to buy it from someone privately. It was a discontinued cooler. Iíve heard Hayden is a big name and also TruCool, although I donít have any firsthand experience with either of those brands.
Old 06-25-2024, 11:16 AM #3009
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
If you dont have pink milkshake then your good. replace radiator, hoses, flush sustem, toyota red coolant and a drain and fill on tranny , or a mbtm style flush. Just be careful with drain bolt, they can strip easy, get a new crush washer
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 06-25-2024, 01:05 PM #3010
Real Name: Blair
Real Name: Blair
I have been running a Tru-Cool I got from Oregon Performance Transmission about 3 years ago. They carry Hayden, Derale, and Tru-Cool.
Transmission Coolers: Oregon Performance Transmission
Old 06-25-2024, 04:47 PM #3011
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I've been wanting to upgrade my smaller B&M trans cooler to the Tru-Cool LPD4589 but it's impossible to find right now.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 06-27-2024, 03:08 PM #3012
ryedog ryedog is offline
Real Name: Riley
ryedog is on a distinguished road
Real Name: Riley
AC question
Hi all, I’ve been lurking for a while and used lots of threads here to help me diagnose and work on my truck.
Recently I have been working on a 97 SR5 that I picked up last November. The AC hasn’t worked since I bought it and now that it is getting hot I am working on repairing it. Last week I did an inspection of my components since I couldn’t get the compressor to engage and I noticed my liquid return line that runs from the drier to evaporator through the bumper is completely cut through. I know the vehicle was in a minor front end collision and I got it safety inspected, anyway I am presuming the broken line is the cause and the system lost all if not most the refrigerant when it happened. Moving forward I bought a new hose and a new drier and am curious if it is stupid to just replace those parts, run the system under a vacuum overnight and check to see if it leaks after, then getting it filled. I live in Utah and that’s where this truck has been located too so the air is usually very dry. I understand it’s almost 30 years old too and it runs great and would like to keep it for as long as possible. Would it behoove me to just bite the bullet and replace everything else or just see what happens with the drier and new hose?
Anyway, that was long winded! I look forward to any insights and feedback!
ryedog is offline   Reply With QuoteReply With Quote
Old 06-27-2024, 04:41 PM #3013
Unless you think a ton of grit got in there, a new hose, drier, a bit of oil and a vacuum before refilling should be all you need. The compressor won't engage if there is 0 pressure in the system.
Old 06-27-2024, 04:58 PM #3014
Real Name: Riley
Real Name: Riley
Great, just got the parts delivered today! Going to grab a pump and a set of gauges and see if it holds a vacuum over night. Thanks!
Old 06-30-2024, 03:43 PM #3015
dell30rb dell30rb is offline
dell30rb is on a distinguished road
I am interested in buying a 3rd Gen 4 Runner as a wheeling rig. I'm mechanically inclined and had jeeps in the past.
I need something a little bit bigger than a jeep and i've already been down that road so interested in something new. I have two young kids and would like to be able to carry stuff for us to all go hit some trails and go camping.
I want to have a build roughly planned out before I buy anything. About a 3" lift, clear 33" tires, bumpers, some skid plates, rocker guards. Locker in the rear.
What parts you buying? What locker? Any durability issues with the stock steering and drivetrain with 33"s that needs to be addressed, or stock axles etc... gonna work fine?
dell30rb is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
